Topic: List of recommended LAME settings (Read 652032 times) previous topic - next topic
Reply #251
in wiki the links are missing, the wiki contains only the pure lame settings.
Reply #252
Correct since these links should be in the relevant pages around the wiki.
Reply #253
Why is the Wiki list sorted differently ? It is much clearer here. Can I change it so that AltPreset standard is recommended as better quality / size ratio ?
Reply #254
How is it better sorted here?
It should be a direct copy...
Reply #255
Here :
Recommended encoder settings (APS green, APE yellow , API red)
ABR settings
CBR settings
APS is on top, in green in the recommended section.
In the Wiki ( http://doc.hydrogenaudio.org/wikis/hydroge...RecommendedLAME ) :
CBR best : API
VBR (APE, then APS)
ABR Settings
CBR Settings
API appears as the best, then, for the one who understands than VBR is superior to ABR and CBR, APE, and then only APS
Reply #256
ah yes... Yes that should be changed...
edit: problem is that with current css there no difference between <h1>, <h2> and <hX>...
So we'd have to use bold or something now...
Reply #257
OK, I must go shopping right now, I'll take care of it within 24 hours if it is not done in the meantime.
Reply #258
Stupid question (must be my work with user-related stuff):
Why recommeded settings aren't distributed with lame distribution files?
It is quite funny that in HA Forums developers say "don't use this or that swithc, use presets" but with the distro comes with "Full command line switch reference" which guarantees the newbies to either
a) "Run! This is for nerds!" or
b) to completely screw up their mp3's
If there is a higher reason for not to put recommeded settings to the first (or only) page of the manual, I would be interested to know.
"There's nothing as pathetic as an aging hipster."
Reply #259
Ask the lame creators to include these recommendations.
Reply #260
Have you really read the documentation? I guess no
Reply #262
Thanks for the answer, Gabriel.
Yes, I have read the documentation that comes with recommended compile. That's why I ask.
They might be part of documentation but not part of the distribution.
http://rarewares.hydrogenaudio.org/files/l...lame-3.90.3.zip
No link to the sourceforge or hydrogen anywhere on the documentation, just links to http://www.mp3encoder.org or http://www.r3mix.net/, which both go to a commercial site, nothing to do with lame.
Reply #263
The absence of the preset.html from the 3.90.3 distro is my fault!!
Because 3.90.3 is hybrid compile, I had omitted to think to include the later presets.html doc within the bundle. I have now corrected this, so end of argument!!
Reply #264
Woohoo I contributed to lame development!
* gets a beer from fridge *
Thanks john33
Reply #265
I think that the link from index.html to presets.html is missing. Without it, I think that many people will miss presets.html
Reply #266
You're probably right. I'll update that too!!
Reply #267
Edit:
How to
Reencode mp3 (high bitrate with ID3 tags) to mp3 (low bitrate) and include tags to new mp3 file : Try Monkeys Audio http://www.monkeysaudio.com/, or maybe better: foobar 2000, use the CLI encoder: http://www.saunalahti.fi/cse/html/foobar.html
I hope, mp3 to mp3 works with the CLI (if not correct me),
for mpc -> mp3, it worked just great !
Reply #268
Hi, I need a little advice, please...
1. I use RazorLAME, but I haven't updated it since about version 3.90 and I know there are newer versions of LAME. Could anyone tell me the simplest way to update RazorLAME so it runs the latest LAME? (Presumably I can do this without having to reinstall RazorLAME from scratch?)
2. Can anyone tell me what the best place is to check when it's "safe" to download the latest LAME update? (I heard there were a few bugs a few releases ago and I don't want to download a buggy version.) Is there some site that keeps you informed of which is the latest stable version of LAME?
3. I went to a site that says there's a v3.94 alpha version of LAME out (http://www.mp3dev.org/mp3/history.html) but to enable one of the new features that makes it better quality, you have to type "-h". I normally just use alt preset extreme. How would I add this "-h" to the preset, or would RazorLAME do it for me?
Sorry to sound like a big fat lamer. I guess I am. Apologies if this is the wrong place to ask. Thanks to anyone who can help me with any of these questions!
Reply #269
The wiki page and this thread will be updated with the compile we recommend. replace the lame.exe in the razorlame dir with this compile.
Reply #270
There's a reason why it's called alpha. It should be used for testing only. So far quality isn't better than 3.90.3 + alt presets, probably there'll be cases where it's much worse.
Reply #271
Jan S. and tigre >> THANK YOU for your help!
tigre >> Your avatar... wow! That's the coolest thing I've seen on the Web in a long time! And all for only 29k!
Reply #272
is there a lame preset that that would correspond to 160 bitrate?
IE  Insane - 320 ish
Standard - 190 ish
is there a preset that would be about 160 ish?
Reply #273
IE  Insane - 320 ish
Standard - 190 ish
MEDIUM
Reply #274
simple enough, I probably should have guessed that one.  THANKS!
