Topic: Channel Mixer (foo_channel_mixer) (Read 533721 times) previous topic - next topic
Reply #300
Exactly what I was looking for...A matrix mixer.
Reply #301
Don't know, if I did it right. This is how I set the plugin up for my 5.1 Teufel Magnum M. It seems to work nicely.
Reply #302
2Chaser
If you wish to get a "surround" effect, your setup should be changed like this:
| BL | 2     | -1.6  |
| BR | -1.6  | 2     |
-1.6 gives "soft" surround, -2.0 - "full".
My English is very good!
...in comparison with my Korean language...
Reply #303
OH YEAAHHH!!!! You are a jewel!!!!!! Thank you very much!!!!!
JUAJUAJUAJUAJUA
Now...could you add some functions??
- presets managing
And, automatic bypassing if stereo source play...but...i think this actually implemented. don't?? If don´t add plleeaasseee.
Bye. Greetings. Víctor, from Argentina (in the dark side of the earth)
Reply #304
You're welcome
- presets managing
While config is simple you may use foobar's builtin preset system.
If you setup such matrix:
   |FL    FR    FC    LFE   BL    BR
FL |0.369       0.261 0     0.369
FR |      0.369 0.261 0           0.369
then for 5-channels source it will downmix to 2 channels, but for 2-channels source the matrix will be truncated at runtime to:
   |FL    FR
FL |0.369
FR |      0.369
then normalized to:
   |FL    FR
FL |1
FR |      1
So it may be called "automatic bypassing"
Reply #305
Some things...
I'm doing some probes with SoundForge...
No matter the number putting in the matrix boxes i always obtain -12db in all channels when doing 5.1 to stereo downmixing.
Why????????????
Please explain to me.
Reply #306
2bertox
Matrix normalization in action
   |FL    FR    FC    LFE   BL    BR
FL |1     0     0     0     1     0
FR |0     1     0     0     0     1
Such matrix will be normalized to:
   |FL    FR    FC    LFE   BL    BR
FL |0.5   0     0     0     0.5   0
FR |0     0.5   0     0     0     0.5
This behaviour is perfectly normal. Why? Imagine that FL & BL channels has full amplitude at the same point. Without normalization the left channel will have double amplitude and will be clipped.
Reply #307
OK...but...Why i can´t manage this levels at my own taste??
I SAY: "No matter the number putting in the matrix boxes".
What are these boxes if no matter what number putt inside nothing changes at all??????
Understand me??
Reply #308
2bertox:
Because of matrix normalization it is no matter how big the numbers in the boxes, the only thing is important - their ratios. My English is not perfect, so I can't explain this thing in details.
PS. Preferences -> Playback -> Preamp. Grow up both sliders to the right if you like distorted sound.
Reply #309
Very interesting plugin. Thank you very much.
I'm not the most well versed with matrix math so can someone help me duplicate the Dolby Prologic II matrix to upconvert 2.0 to 5.1 (I want to use this plugin with Dolby Headphone).
Reply #310
2skipyrich:
OK. OK. I REALLY know this. But...-12db??? Is too much down unnecessarily!!!
With -9db or -8db is very fine mix without clipping at all....please...
Do you understand my point??
At this instance i'll prefer de "old" Channel_mixer which have -9.5db in 5.1 to 2.0 downmixing at least.
And i don't like distorted sound...please...this is not very funny___...
I hope you'll ndrstnd me...
And... AlleyMan, here is a post who may help to your ProLogic II matrixing: http://forum.doom9.org/showthread.php?p=1005866#post1005866
BYe.
Reply #311
@bertox: A clipping-proof matrix requires that the maximum possible sum of the amplitudes of all channels per row is not greater than 1.
   |FL    FR    FC    LFE   BL    BR   |SUM
FL |1           0.707 0     1          |2.707
FR |      1     0.707 0           1    |2.707
Dividing by the sum results in the normalized matrix:
FL, FR, BL, BR: 1 / 2.707 = 0.369
FC: 0.707 / 2.707 = 0.261
LFE: 0 / 2.707 = 0
FL |0.369       0.261 0     0.369      |1
FR |      0.369 0.261 0           0.369|1
Dividing by 2.707 is like multiplying by 0.369 which equals an attenuation of 8.659 dB. But it is quite possible that a sum of 1 will not be reached in a practical case. That might give you the impression that the attenuation is greater than necessary. But in fact it isn't.
Reply #312
i've been looking at the matrix mixer. at first i didn't quite understand it, but now i get how it works. very nice.
Reply #313
@Hancoque:
I KNOW ALL THIS STUFF.
This is not an "impression" of me. really. I probe this like a concrete fact in SoundForge.
There is -12db attenuate in Matrix Mixer DSP. First fact.
There is -9.5db (with LFE controller in 0.33 too. < -9.6db >) attenuate in Channel_Mixer DSP. Second fact.
Why this difference...??? only god knows...
All talking about downmixing to stereo obviously...
Reply #314
Thanks, Hancoque!
2bertox:
Do the test. Add location tone://1000 to playlist, set "Repeat track" playback order. Set 0dB preamp. Clear DSP chain. Add Channel Mixer at the top of DSP chain. Setup Channel Mixer to upmix to 6 channels with all sliders set to 1, center to 2.
Start playback, control the levels. It should be about 0dB.
BTW, to control the output levels I recommend foo_uie_peakmeter.
Add Matrix Mixer to the DSP chain with the following setup:
   |FL    FR    FC    LFE   BL    BR
FL |1     1     1     1     1     1
FR |1     1     1     1     1     1
Check the output level. Should be the same ~0dB. Is not it?
Remove '1's from BR column. Check the output level. ~0dB again.
Remove '1's from BL column. Check the output level. ~0dB again.
....... and again, and again.
Six bottles of beer can't be placed to a single bottle
Reply #315
The subwoofer channel must also be activated in the subwoofer tab. I just did the test and the output channels always peak at 0 dB. So it works absolutely as it should.
Reply #316
@skipyrich:
I don't know where you going...
Perhaps i like to read fact conclusions and not funny says (Six bottles...)
What's has to do your words with the real attenuate difference in two plugins (-12db against -9.5db)?
Explain more please.
And thank you for notice me of the foo_uie_peakmeter plugin, which is usefull to me.
Reply #317
Matrix Mixer 0.2
Changes (+: added, *: fixed):
  • + Some performance optimizations.
  • * Incorrectly calculated normalization factor in some rare cases.
  • * Pressing OK does not apply matrix.
http://skipyrich.com/store/foo_dsp_mm.7z
2bertox
It is "feature" of the Channel Mixer. Here is the pseudocode for downmix 6->2:
L = (FL+BL*downmix_rear+FC*downmix_center)/3+LFE*downmix_sub
R = (FR+BR*downmix_rear+FC*downmix_center)/3+LFE*downmix_sub
Channel Mixer don't do normalizing, so it is your responsibility to properly setup the plugin.
Reply #318
@skipyrich:
Ok. ("is your responsibility to properly setup the plugin.") but the Channel Mixer don't offer a control to level front channels, only rears, center and LFE.
Now i repeat my old request to you: could you add a controller for the fronts too?
Thanks for the new Matrix Mixer (0.2) and all your works.
Reply #319
2bertox: You have persuaded me.
Version: 0.9.6.4
Changes:
+ added front volume control to the downmix page
http://skipyrich.com/store/foo_channel_mixer.7z
Reply #320
oh yeah baby!!!
I can clip all channels together now and break off my soundcard, my amplifier, my speakers and my ears at same time and blown my brain. Yeeaaahh!!!!!!!!!!!!!
Juajuajuajajarajakaka.
This is the perfect plugin now. well...he doesn't Pizza for me...but it's ok.
You just add the Matrix plugin to the Channel Mixer and he becomes in greatest history mixing plugin.
Good luck and sweet dreams (you work hard...)
Reply #321
this is my favorite components of foobar!!
a question,
does anybody know about alternatives of this components in other Audio Players in Linux? any player?
i would use foobar with WINE but it makes problems with Hebrew Characters.
Reply #322
Thank you for your further improvements on this component. Could you please say a little more on the topic of normalizing and what the end-user has to do, in order to do it right?
Reply #323
2Chaser:
I don't know what to add to these words.
Ah, yes, I know!
Switch to the MM and forget the CM as a nightmare
I will add missing features to the MM soon, as soon as I complete my own grid control...
Reply #324
mmmmm. I don't forget the Channel Mixer Dsp at all.
Actually i like this plugin which let you setup downmixing without matrix auto normalization.
The last version (0.9.6.4)....is the one.
Or... could you add an option to disable auto normalization in MM like AC3Filter (the directshow & winamp plugin) has??
Thinkin'...mmm..your plugins are becoming more and more similar to AC3Filter...if you sum both of them in one strongest dsp. Which is good...; and for Foobar.....which is very very good.
Thinkin', Thinkin'....
