Topic: batch scan playlists for dead entries (Read 3648 times) previous topic - next topic
hi,
i am looking for a portable tool, that will batch scan playlists (m3u8) for dead entries and list playlists & files that need to be corrected.
its not exactly what i was looking for, but with mediamonkey it is possible to drop m3u8 and sort for dead entries.
anyone knows, how to add a column which will show the relating playlistnames?
It's probably also not exactly what you are looking for but you could
  • install the freeware audio player foobar2000 in portable mode,
  • then open your m3u8 files with it and then
  • choose from the menu Edit -> Remove dead items.
foobar2000 imports the m3u8 to a playlist and the 'Remove dead items' command removes all missing files from it, which are also listed in foobar's console [menu: View]. The console's content can be copied or written to a file.
In addition you could try the component foo_playlist_revive in order to adjust links to missing files automatically if possible.
Finally export foobar2000's updated playlist back to m3u8.
i am already using foobar, the problem is, when importing playlists, dead entries are left out and ''only'' shown in the console.
thats why i would like to quick check all playlists before i import them.
thanks for linking to that plugin, might be a good solution when having many playlist tabs in foobar.
