Topic: 6-bit PCM sample (Read 3407 times) previous topic - next topic
6-bit PCM sample
Noise shaping would probably help a lot.
6-bit PCM sample
True, and amplifiyng the sample to peak at 0 db would also help. Loud samples like the next examples sound quite ok with 6-bit. I just uploaded this sample to dispel any notion that MP3s have a 25 dB dynamic range (actually it has around 125 dB) http://www.hydrogenaudio.org/forums/index....;f=1&t=6377 .
I don't know how to do noise shaping or dithering with 6 bits as the bitcrusher I use does not have that (which is understandable as the very reason for a bitcrusher is to color/distort the sound).
EDIT - Actually not even 6-bit PCM has just 25 dB of dynamic range/signal to noise ratio. It is cca 36 dB for 6-bits.
