Topic: Discussion of "Default UI Gallery" (Read 383980 times) previous topic - next topic
Reply #500
hmm true but i still much prefer buttons
Reply #501
I'm not too much into customizing, I want to keep Foobar the way it was meant to be - simple and efficient.
Hi, is it possible for you to mention the components that you use?
Thanks in advance.
Reply #502
I see one component a playlist viewer that allows inline album art. Esplaylist or more likely foo_simplaylist. Playlist Viewer is inserted in a standard Playlist Tabs container
Reply #505
There are settings you can adjust in Advanced preferences.
Reply #506
@falstaff
awesome work as always...now downloading d config...
Reply #509
Top level is a Tab container. The current tab in view is a vertical stack presentation of Facets element.
Reply #513
Too simple?
Reply #514
Mine. 2 screenshots, stopped and with void "default" playlist first and then working with playlist and lyrics:
Love simple UIs like mine and the one in the post above.
Reply #515
You don't need to double-post as you did here... this thread should be for DUI discussion only.
Reply #516
Hi all,
After many years of using FB2K + CUI, I am now looking to see whether I can have the same (or the most important anyway) features using FB2K + DUI (as CUI is not updated)
My first hurdle... Filters (that can be assigned to custom tag fields, not just the standard ones like Artist, Album etc.). Am I right in thinking DUI does not have Filters like this? How do people overcome this?
Thanks,
Rohit
Reply #517
... (as CUI is not updated)
is it a reason to leave it ? it's working fine and for now, there is no need for some update, curious way of thought...
a similar component in DUI for Filters is foo_facets, this components is better in many ways as the default CUI Filters Panel : http://www.foobar2000.org/components/view/foo_facets
HTH
Reply #518
HTH
Great thanks. I came across this component also and shortlisted it to install - but I could not tell if it did indeed have filters. Thanks for the confirmation.
It's more of an experiment, definitely haven't decided to leave CUI for good at the moment - who knows, maybe FB2k+DUI will suit me even more
The other couple of components I think are quite popular from what I have read and searched so far, are:
- foo_simplaylist
- quicksearch toolbar
If you have any thoughts on these with any pros/cons feel free to share!
Reply #522
it needs a few more tweaks to be usable. i'll post it tomorrow.
i should say right now the "playlist" is purely for display purposes. it won't be very functional at all. all you can do is scroll (it's really meant for displaying a single album) and double clicking a track to start playback.
Reply #524
Thanks in advance.
How do you add a library tab ? Is that in fact a playlist ?
Because in my config, the only Library tab does not gave support of the albumart
Thnak you for the tip if it exists.
