ResidualDecoding Help
2012-09-13 22:44:48
I read the documention of here http://flac.sourceforge.net/format.html#residual about the residual. And I think I ve got a quite good overview but I still wasn t able to write a full decoder. So I searched after that on the internet and I found two different codes. The first one is the official libflac libary. That code is very very big if you take a look at the FLAC__bitreader_read_rice_signed_block function in bitreader.c. The other libary was the flake libary of cuetools (also posted in this forum): That libary does all that very very easy and in much less code. But I dont understand the code. So may anyone of you explain me what that code does and how is it possible that the code is so small. So I thought about that it may does not support highest compression level. And I got it right. It does not support all flac files export from audacity. If I use compression level 8 it will fail. So may someone of you tell me a bit about it and how the residual is stored ... here is the code of cuetools: unsafe void decode_residual(BitReader bitreader, FlacFrame frame, int ch) { // rice-encoded block // coding method frame.subframes[ch].best.rc.coding_method = (int)bitreader.readbits(2); // ????? == 0 if (frame.subframes[ch].best.rc.coding_method != 0 && frame.subframes[ch].best.rc.coding_method != 1) throw new Exception("unsupported residual coding"); // partition order frame.subframes[ch].best.rc.porder = (int)bitreader.readbits(4); if (frame.subframes[ch].best.rc.porder > 8) throw new Exception("invalid partition order"); int porder = frame.blocksize >> frame.subframes[ch].best.rc.porder; int res_cnt = porder - frame.subframes[ch].best.order; int plen = 4 + frame.subframes[ch].best.rc.coding_method; // residual int order = frame.subframes[ch].best.order; int* r = frame.subframes[ch].best.residual + order; int partitions = 1 << frame.subframes[ch].best.rc.porder; for (int p = 0; p < partitions; p++) { if (p == 1) res_cnt = porder; int n = Math.Min(res_cnt, frame.blocksize - order); int k = frame.subframes[ch].best.rc.rparams[p] = (int)bitreader.readbits(plen); if (k == (1 << plen) - 1) { k = frame.subframes[ch].best.rc.esc_bps[p] = (int)bitreader.readbits(5); for (int i = n; i > 0; i--) *(r++) = bitreader.readbits_signed((int)k); } else { bitreader.read_rice_block(n, (int)k, r); r += n; } order += n; } } Please help me
