Topic: lack of compression (Read 7491 times) previous topic - next topic
lack of compression
experiment:
track: Biosphere - Disparu
flac -8 bitrate: 267kbps
vorbis aoTuVb5.7 q8(~256kbps) bitrate: 208kbps
nero aac q0.66(~250kbps) bitrate: 75kbps
vorbis aoTuVb5.7 q9.4(~392kbps) bitrate: 347kbps
nero aac q0.97(~400kbps) bitrate: 91kbps
lack of compression
I ... really don't understand what that means.  What are you trying to accomplish that produces the above files?
Edit:  On further reflection, I think I get it.  Adding file sizes to the above results will probably be extremely helpful.  I suspect you aren't reporting average bitrate for the produced files.
lack of compression
is the average bitrate
I do not know how it is called. but should be more compressed than cut. (m.b lossless part. i don't know  )
lack of compression
Do you have file sizes for each file?  Also, how long is the track?
lack of compression
146 seconds
lack of compression
If you are asking if there are situations in which lossy compression can be less efficient than lossless compression, then the answer is yes.
lack of compression
Given that several media player programs exist that mis-report average bitrates, I think no further insight can be had until we have the files' sizes.
lack of compression
foobar2000. I have already deleted the files and their sizes can not lead.
the average bitrate is correct.
You can calculate it by multiplying on the seconds
lack of compression
Those are indeed very strange bitrates. What kind of music/sound is it? Can describe the sound? Maybe you can upload a small part of it (<30seconds).
lack of compression
I noticed that some good lossless codecs compress files with low volume. This track is one of them.
file (20 sec.)
in lossless vbr because of the heterogeneity of data. in lossy seems that vbr is due only to the use of different cuttings. vorbis bitrate always aligns to the average of the selected level of compression, regardless of the track itself (excluding silence). so I wanted to mention and that is as correct
lack of compression
but in the practical application of aac always sounds like it dry
