Topic: Why is WMA so bad? (Read 41584 times) previous topic - next topic
Why is WMA so bad?
I keep hearing that WMA is a bad codec... how true is this?  Why?
Does it matter if I'm aiming at 160 - 200 bitrates?
Why is WMA so bad?
People are gonna chime in with a lot of answers, but alot of has to do with bad marketing by MS.  Basically making claims of "CD Quality at 64kbps."
Another reason is format portability and closed source.
"You can fight without ever winning, but never win without a fight."  Neil Peart  'Resist'
Why is WMA so bad?
- It is not very good a lower bitrates. Just look at the various listening tests conduced here (which are blind). Maybe your bitrate is OK, but people over here generally want lower rate for obvious reasons.
- Not open source
- Not cross-platform. No binaries for Linux or Mac
- You are at a whim of Microsoft
A bit of search would answer this and probably more.
Why is WMA so bad?
No binaries for [...] Mac[a href="index.php?act=findpost&pid=315221"][{POST_SNAPBACK}][/a]
vevy wrong
Why is WMA so bad?
Nothing is wrong with WMA if you like WMP 10 and use a "Plays for Sure" portable. It's quality is very similar to MP3 at 128 although slightly behind the best implementation of LAME with the V5 preset. It is also slightly inferior to AAC and OGG per Roberto's listening test.
At 192 and above, unless you have trained ears or great hearing , you are not likely to notice artifacts.
Having said that, people here do not like it becuase it's Microsoft. They view WMA acceptance as M$ eventually squashing digital audio.
Why not use MP3 though? WMA has no advantage over MP3
Why is WMA so bad?
I was just looking for a codec that would give the same quality as the lame -aps but at a lower bitrate.  I was under the impression that wma was better than mp3...
I like ogg, but it's not as compatible, and tends to wear my battery out more quickly.
I'd try AAC, but my player doesn't support it.
all I really care about is the sound quality/bitrate and compatibility, not who makes it.
but all advice and info is welcome.  I did try searching, but all I found was people talking about lower bitrates (below 128) and the fact that it is M$.
Why is WMA so bad?
For a user WMA really doesn't offer anything that MP3 doesn't, apart from perhaps acceptable quality at sub-128 bitrates.
And, besides Triza's excellent list of arguments, i don't think it's been publicly tested as extensively as LAME and the other common formats on HA have been. So at a bitrate of 192 you can't be as sure of how your encode will sound as you could be with Lame 3.90 for example. Not that it is very likely WMA has severe flaws or weak points, but still.
Does anyone know if WMA is gapless? I don't expect it to and it is probably a moot point if your player doesn't support it. I couldn't find the information in the wiki. Tagging WMA's may not be as easy as tagging the other formats, too.
Try testing OGG at various bitrates and pick the lowest that still sounds good to you. Besides more capacity lower bitrates also tend to increase battery life.
Veni Vidi Vorbis.
Why is WMA so bad?
The thing is ... why would i use it? it would have ti give such a better experience, when compared with MP3 (the general standard), or AAC (MP4, iTunes Standard). Problem is:
- Is not better than MP3/AAC, not even by a thin marging
- The implementation is closed
- Microsoft is bad for competition
so, then again, why would people us it?
- cause it is included by default in WMP, and people tend to use whatever cames with their PCs.
Why is WMA so bad?
WMA, by virtue of its imprecise tuning and annoying manner of artifacting, probably never reaches a "safe" level of perceptual transparency like MPC or AAC. That's why I dislike it. When I was on Windows and had a flash player, I tried playing around with WMA9, both CBR and VBR, and couldn't get rid of annoying ringing artifacts on a handful of songs, even at high bitrates! WMA Pro seems to scale better, but it's not supported by any portable that I know of.
Why is WMA so bad?
vevy wrong
[a href="index.php?act=findpost&pid=315224"][{POST_SNAPBACK}][/a]
Indeed. Windows Media Player is available for Macs, and there are third party solutions which allow you to export from QuickTime to Windows Media formats. However Windows Media DRM doesn't work  in the Mac port.
Why is WMA so bad?
I don't like WMA because it was easy to ABX vbr encodings at all but the highest level the encoder would go. If it can't do high bitrates very well, there is little hope for low bitrates. I ended up going with OGG for my portable and am very happy with the quality.
Why is WMA so bad?
rjamorim's 128kbps comparison results:
I know, that I know nothing (Socrates)
Why is WMA so bad?
that about sums it up.
thanks!
Why is WMA so bad?
does anyone need to say more?
[a href="index.php?act=findpost&pid=315278"][{POST_SNAPBACK}][/a]
All codecs except wma have evolved since that test.
Why is WMA so bad?
I think WMA Pro is the true competitor from Microsoft. It's just too bad that there's no portable player support (yet).
Why is WMA so bad?
[a href="index.php?act=findpost&pid=315317"][{POST_SNAPBACK}][/a]
I still would never use a closed-implementation codec. And I think most people here wouldn't also.
That is what is so wrong about WMA.
It could even achieve perceptual transparency at 64k, but I would never use it for serious archiving.
So I think WMA Pro will suffer the same fate.
BTW, does WMA support ReplayGain tags on foobar2000? (Just curious)
I'm the one in the picture, sitting on a giant cabbage in Mexico, circa 1978.
Reseñas de Rock en Español: www.estadogeneral.com
Why is WMA so bad?
vevy wrong
[a href="index.php?act=findpost&pid=315246"][{POST_SNAPBACK}][/a]
And not only that, but WMP is not so great on OS X, from the non-standard installer, to the ugly UI, to the bugginess.
But more the point, why I think WMA is "so bad," or at least why it has never been promoted heavily on these forums, and why I originally never saw fit to make a forum for it:
- It was never a format that people initially discussed around here much.  There wasn't much community interest from the initial regulars.
- Player support has always been a bit shaky when not using Microsoft products.  I'd venture to guess that WMP is not the most popular player with the people on these forums. (This is a little different on DAP's, since standard WMA has good support there for the most part, but DAP users represent probably still the minority of the people on HA).
- It has not had a very good track record for portability (though this may have been changing with 3rd party playback libraries becoming available).
- It has never had the most compelling sound quality (WMA Pro is a bit different, but suffers from most of the other points to an even higher degree -- i.e., it's less accessible)
- There's never been serious interaction with the HA community from a WMA developer.  Just about every other format promoted here has had this, and this characteristic is a rather integral part of what makes HA unique.
- The tie WMA has to DRM scares many people away from the format here.  Many of the people on HA like to have flexibility with their audio files, including copying them to different machines and being able to process them with a variety of different tools.  They want to be able to do this without the kind of restriction that DRM brings with it.  Of course other formats like MP4 can have DRM too (see iTMS), but in the overall scheme it seems to be less of an issue in these other cases since there is no single company (a company which, I might add, many people are suspicious of) in charge of the way in which the DRM is handled.  Furthermore, there have been at least a handful of posts by users on HA over the years that have managed to lock themselves out of their collection by not being careful about WMA DRM.
- The format is not well documented in comparison to the others, which makes creating 3rd party utilities to process it much more difficult.  Maybe this is a little bit different now that a 3rd party playback library has been created, but even so, the format is not open in a way that makes it accessible to developers that do not either license technology from Microsoft, or rely on Microsoft provided libraries (which are usually non-portable and not open for modification).
If you ask me, WMA simply isn't a format that sits well with the spirit of HA given the above disadvantages.  Does that make it "so bad"?  Well, it depends.  It makes it not very good as a format for HA to promote.  But on an individual basis, if someone just wants a format to encode their files to so they can upload to their DAP, well, then no it doesn't necessarily make it "so bad."  But depending on the aim of the person (say quality), it still might not be their best choice (assuming they have other options).
Why is WMA so bad?
Well said, Dibrom. a fair and objective response.
Why is WMA so bad?
[a href="index.php?act=findpost&pid=315334"][{POST_SNAPBACK}][/a]
E:\Zenék\mp3\ui.wma
samplerate = 44100
channels = 2
codec = Windows Media Audio V7/V8
bitrate = 64
replaygain_track_gain = -1.51 dB
replaygain_track_peak = 0.975769
10026091 samples @ 44100Hz
File size: 1 842 060 bytes
That's the only wma file on my computer, and I could replaygain it without any problem with Foobar.
Of course RG is just a metadata field like TITLE or ARTIST, so practically every format that supports some way of tagging can use it with Foobar, even formats that natively do not support it.
Why is WMA so bad?
Like all other said
  WMA is a bad codec because:
- The implementation is closed.
- No Cross-platform.
- Is NOT better than MP3.
- It supports DRM.
- Claim something that is not true: "64kbps = CD quality".
- And my favorite is because is from Micro$oft.
If you don´t care that is from M$ and the only thing you care is find a codec that is better than MP3, well WMA is NOT that codec...
if your DAP don´t support Ogg Vorbis or AAC then use MP3... because WMA is not a good choice for all that reasons.
Edit: Bad performance.
JorSol
aoTuVb5 -q4
Why is WMA so bad?
OK, just to balance some of the obvious bias against WMA in this thread (and the painful displays of childness with writings of "Micro$oft" and "M$"), here's an advantage of WMA over MP3: Native gapless support.
Why is WMA so bad?
- Bad performance, even at high bitrate (compared with other codecs).
[a href="index.php?act=findpost&pid=315425"][{POST_SNAPBACK}][/a]
The OP asked about 160-200 kbps range. Are you aware of some tests that prove that WMA is bad "even at high bitrate"? If so, please share with the group.
Why is WMA so bad?
Unfortunately I've had issues with multiple artists and WMA files in Foobar after editing tags. Otherwise WMA ain't so bad, I guess.
Acid8000 aka. PhilDEE
Why is WMA so bad?
[a href="index.php?act=findpost&pid=315434"][{POST_SNAPBACK}][/a]
Perhaps, but few software players and even fewer (if any?) hardware players can play back WMA gaplessly. With most hardware players, it doesn't matter what format you feed it; there will be gaps regardless.
