Topic: Accuraterip no match with confidence 1 (Read 2294 times) previous topic - next topic
Hello,
I have a question similar to the one a few topics below. I have a CD which is only in the AccurateRip DB, not in the CUETools db, and the AccurateRip confidence is only 1. All tracks are a match except one. I have ripped the cd on 4 different drives, 2 difference machines and almost always get the same CRC. One drive sometimes gives another CRC, sometimes same one as the other ones. In any case both are different from the one in the DB. There is some error correction being done in secure mode. I also tried paranoid and burst modes without c2 correction, all giving the same result. It is safe to assume there is only one pressing as it's a limited edition of 2000, never re-released.
How can I know whether my rip is fine or not, or if the rip in the database is the one having a problem? I can post logs, just tell me what would be useful.
Drives on machine 1: Optiarc 7260S, Pioneer BDR-S09
Drives on machine 2: Toshiba SD-M1612, Plextor Premium
thanks!
Exact Audio Copy V1.0 beta 3 from 29. August 2011
EAC extraction logfile from 18. November 2015, 21:31
Used drive  : Optiarc DVD RW AD-7260S  Adapter: 2  ID: 0
Read mode              : Secure
Utilize accurate stream : Yes
Defeat audio cache      : No
Make use of C2 pointers : Yes
Read offset correction                      : 48
Overread into Lead-In and Lead-Out          : No
Delete leading and trailing silent blocks  : No
Null samples used in CRC calculations      : Yes
Used interface                              : Native Win32 interface for Win NT & 2000
Gap handling                                : Not detected, thus appended to previous track
TOC of the extracted CD
    Track |  Start  |  Length  | Start sector | End sector
        1  |  0:00.00 |  3:11.47 |        0    |    14371
        2  |  3:11.47 |  4:09.48 |    14372    |    33094
        3  |  7:21.20 |  4:00.57 |    33095    |    51151
        4  | 11:22.02 |  2:51.55 |    51152    |    64031
        5  | 14:13.57 |  3:00.55 |    64032    |    77586
        6  | 17:14.37 |  3:45.30 |    77587    |    94491
        7  | 20:59.67 |  3:13.20 |    94492    |  108986
        8  | 24:13.12 |  4:50.15 |    108987    |  130751
        9  | 29:03.27 |  2:38.03 |    130752    |  142604
      10  | 31:41.30 |  4:31.32 |    142605    |  162961
      11  | 36:12.62 |  6:39.30 |    162962    |  192916
Track  2
    Peak level 98.8 %
    Extraction speed 15.7 X
    Track quality 100.0 %
    Copy CRC 335399B2
    Cannot be verified as accurate (confidence 1)  [062E41BF], AccurateRip returned [A46FC207]  (AR v2)
    Copy OK
No tracks could be verified as accurate
You may have a different pressing from the one(s) in the database
Doesn't inspire a lot of confidence that the rip was accurate.
Doesn't inspire a lot of confidence that the rip was not accurate.
Time may tell.
