Topic: Discussion of "Default UI Gallery" (Read 380069 times) previous topic - next topic
Reply #50
Added Cover-arts to my UI and removed that Album-list when i figured it was totally useless...
I really love this customizable UI!
Reply #53
Here is my setup. I am using builtin titile format.
Custom buttons? How? And what is that spectrum thing?
As far as i know:
$if(%discnumber%,'(Disc '%discnumber%')',) =
$if($meta(discnumber),'(Disc '%discnumber%')',) =
['(Disc '%discnumber%')']
Would  $if2('(Disc '%discnumber%')',)  work the same way?
Btw: i got used to put all plain text in quotes because i think it's more strict. Or do i only have to put qoutes around brackets so they won't be confused with string brackets?
I got that disc thing already solved. Or was that about that...? Now I just want to get rid of these numbers.
Reply #54
The custom buttons ara made with columns ui and dockable panels (i think). Look at the border around the button segment. It is not really included in the default ui layout.
With the first 4 lines i just wanted to show you that there are different ways to show the same result. You said you don't know how to make these things from scratch. Maybe that could help you to understand how it works.
The "$if2"-thing and the question about where to put the quotes was something i wanted to know. Nothing to do with you.
But if someone wants to know: it does the same thing as the other three lines.
How to get rid of the discnumbers in tracknumber columns:
Did you try creating a custom column "Track" = [%tracknumber%]?
Reply #55
Sorry for a question asked already somewhere, but anyway: How can you take playback controls and such from the toolbar to the layout itself?
Reply #56
Apostrophs are only required around characters with a special meaning in the titleformat syntax:
%, $, (, ), [, ], commas inside of functions, and the apostroph itself - use '' to display one.
You can add a toolbar above or below any UI element.
Enable the layout editing mode, right-click on an element, choose "Replace", and select "Toolbar Header".
Now right-click on the new toolbar to customize it.
Reply #57
Thanks! Now I got it (:
Moderation: Removed the fullquote.
Reply #58
is there any way to get some sort of scale for the spectrum tool? Or is there some other way to get a basic idea what the current lowpass is?
Reply #60
For people that have problems displaying the rating stars. You can use the free to use Deja Vu font. I like the font myself and it has the star symbol.
http://dejavu.sourceforge.net/
Reply #61
It is explained in the following topic:
http://www.hydrogenaudio.org/forums/index...
For the correct font be sure to ready my post on the 3rd page.
Reply #62
Edit:
Download theme file here.
how can I get the spectrum monitor look like this? What are the color codes?
thanks
Reply #63
Found this to be the most useful setup for me.
I really like this new UI. It's what Columns UI should have been all along. Damn that tree-view based editing. UI elements is easy to use.
Moderation: Replaced full image by a thumbnail.
Reply #64
small screen
wide with lyrics panel showing
Looks awesome. Would you please post your config for me ? I would love to use it on my  foodbar, thank you!
Reply #65
Is it posible to customize the grouping headers font?
I can only change the lists and playlists from what I can see, and the grouping font is chosen by foobar automatically (increasing the point size).
Am I missing something or is it just like that?
Reply #66
pretty much one of the defaults
http://blog.somestuff.org/images/fb2k_095b3.png
Hi smok3, can you please give the font and special $char codes you've used for the top of your foobar window ? (between 3:14 and fb2k). In fact a copy/paste of the code would be best. Thanks.
Another question for everybody : here's my current config (work in progress, so don't pay much attention to it). Notice the 20 small filled / empty dots in the status bar (lower part of the window, between "1:37" and "-2:32". I don't understand why they aren't vertically aligned with the rest of the line (they are too low, I'd want them to be centered). Can you guys help me out ?
Thanks !
Reply #67
That's most likely how those characters are positioned within the font itself. The solution would be to pick new hollow/filled characters or pick a new font.
Reply #68
Yes, that's what I thought, but when I look at the Windows character table (Start > Programs > Accessories > System utilities), these circles (hex codes 25CC and 25CF from Arial Unicode) are perfectly centered vertically. Same thing if I copy/paste them into Wordpad. So there must be a problem somewhere within foobar.
I have seen screens from people @ HA Forums with the same circles correctly positioned. So I guess there must be a solution (either there are other working $char codes, or something else). Thanks in advance for your help.
EDIT : I've found it - it's just a matter of which font you select under foobar for the status bar. Some fonts display the circles centered, others display the circles down. That's all.
EDIT2 : I've even managed to create a small piece of code that displays a progress bar, but unlike other progress bars,
this one gives the impression to progress on a pixel-by-pixel basis. Try it out and let me know what you think (it's one of my first attempts, but I'm pretty happy with it  ).
Simply copy/paste this into Prefs > Default UI > Status Bar (in only ONE LINE, without carriage returns) :
%codec%' ('%bitrate% kbps')'   -   %samplerate% Hz %channels%'   ¤   '%playback_time%'   '$puts(a,20)$repeat($char(9608)' ',$put(b,$div($mul(%playback_time_seconds%,$get(a)),%length_seconds%)))$ifgreater(%length_seconds%,%playback_time_seconds%,$char($sub(9615,$div($mul($sub( $div($mul(%playback_time_seconds%,$mul($get(a),10)),%length_seconds%),$mul($get(b),10)),8),10)))' ',)$repeat($char(9480)' ',$sub($sub($get(a),1),$get(b)))'  '-%playback_time_remaining%
You can replace the "20" in "$puts(a,20)" with the total number of characters you want in the progress bar (34 is the limit for me).
Of course it requires an Unicode font like Arial Unicode for instance : Prefs > Default UI > Colors and Fonts > Status Bar.
Reply #69
The progress bar code is great. Thanks for sharing!
Reply #70
My current foobar2000 beta 6 setup using the facet plugin. Which is a nice and simple setup with everything i just need.
Hi, I really love this setup!! Is there any way you could post the theme file or whatever it is? I have no idea how to change things and would really like something along these lines. Thanks!!
Reply #71
I made a copy of my foobar config file and theme import file aswell to try out.
http://www.sendspace.com/file/e98cfr
Also you will need a the Facet Plugin and foobar2000 0.9.5 beta.
Notes:
VBR display is set to 0.
Status bar and Windows Title bar is a complete re-written custom format code which displays usefull info.
Mouse wheel focus is switched on.
ID3 Tag compat mode is switched on.
Foobar my ask to remove some settings for missing plugins but can click keep or remove but that should not be a major problem but make sure the Facet plugin is installed.
"I never thought I'd see this much candy in one mission!"
Reply #72
@gordolindsay
You will be able to create any theme you like - just go to main menu -> view and look there for calling the scratchbox: then just play around and create what you like. It is not necessary anymore sharing themes when using the DefaultUI.
Reply #73
I'm not familiar yet with the scratchbox. Is there some topic about it or something ?
