Topic: foo_uie_lyrics3 (Read 895882 times) previous topic - next topic
foo_uie_lyrics3
Reply #1025
I wounder where is Online DB: Timestamped 1, 2 and 3.
I want to share my synced lyrics to others can use.
I use to submit my lyrics to lrc123.com many many many time but seems they don't care! X(
Where you guys suggest to submit synced lyrics? ~_~
foo_uie_lyrics3
Reply #1028
nope you need the prog
foo_uie_lyrics3
Reply #1029
Thanks for your plugin! It works so well!~~~ Appreciate it, man.
Here I just have a small question. How can I keep the lyrics front all the time. Sometimes you know, we open foobar as the background music. that would be great if the lyric can always been seen when we work on some other jobs.
foo_uie_lyrics3
Reply #1030
i know all of u rock guys (i wouldn't be judging). but i'm begging u for rapgenius.com
it's good there is some indie stuff like xx & others.. but besides that it's all britney-beiber(or how u spell it)-rock-other ridiculous music for american young people.
no dilla, no mos def, no nothing. how is that..
and yeah, plugin works very good, but tired filling up lyrics by myself
foo_uie_lyrics3
Reply #1031
well, you would be surprised how is people's music taste different. i listen to almost every genre with a few exceptions. but i get your point, you can't find non-mainstream rap lyrics anywhere. anyway, The vern needs to add it to lyrics plugin if possible, so we can't do anything about it:)
foo_uie_lyrics3
Reply #1032
Can we get ohhla.com too?
foo_uie_lyrics3
Reply #1033
The vern released an SDK for writing lyric sources a while ago, so he is not the only one that can write them. So you guys who want new sources may want to consider writing them and releasing them for the benefit of other users rather than waiting/hoping the vern will add them.
http://code.google.com/p/foo-uie-lyrics3/d...mp;can=2&q=
foo_uie_lyrics3
Reply #1034
Someone, please.. people need your help. people being torturing, people being dying
then getting old.. still being torturing, dying
still
foo_uie_lyrics3
Reply #1035
Hello,
is it possible to make the text run smooth? And not to stop when it's highlited?
thanks
foo_uie_lyrics3
Reply #1036
Try putting the scroll speed to minimum in the settings page (right click->panel preferences)
EDIT: Also, if anyone has any feature requests now would be a good time to tell me
foo_uie_lyrics3
Reply #1037
thanks, works for me
Feature Request:
would be nice if you implement a function wich make a scan of the full libary and search for the lyrics automatically.
foo_uie_lyrics3
Reply #1038
minilyrics http://www.crintsoft.com/
minilyrics is timestamped 3 btw.
But the program must be installed to upload lyrics into mini minilyrics, is there any web base way to upload synced lyrics?
I use MiniLyrics to upload lrc  files too! It works quite well for me and th foobar plugin seems to use that database. Later you can view/delete (but upload only possible through minilyrics client not webinterface) your uploaded lyrics in the webinterface:
http://www.minilyrics.com/user/Login.aspx?...=MyProfile.aspx
There you can see how much each of your uploaded lrc file got downloaded by other users - thats quite interesting.
foo_uie_lyrics3
Reply #1039
Is it possible to rate lyrics?
foo_uie_lyrics3
Reply #1040
Thanks for this great plugin, it works like a charm! I would apreciate an option to save both: synced and unsynced lyrics to my tags. My ipod classic 5G only reads unsynced and at my PC I prefer the synced tags! Do you think such an option could be acomplished in the future?
The other thing I am missing is the possibility to batch-save the lyrics to tags whithout having to play them. I used to do this with the mirkforce plugin, but since months I only get "network problems, aborting" with this... :-(
foo_uie_lyrics3
Reply #1041
Feature Request:
+1
At least now I have a workaround for this:
http://skipyrich.com/wiki/Foobar2000:Preview or
http://wiki.hydrogenaudio.org/index.php?ti...Seek_(foo_seek)
Set the track preview to about 8 sec, create a (Auto)Playlist "no (unsynced/synced) lyrics present", play it! Next morning it should be done... :-)
foo_uie_lyrics3
Reply #1042
Hello,
The vern, could you add customisation option for text shadow? Colour and opacity.
foo_uie_lyrics3
Reply #1043
How do I indicate that no lyrics exist for a given song with the lyrics tags?
foo_uie_lyrics3
Reply #1044
~Bug report~
Apparently there's a bug where if the lyrics are encoded in Simplified Chinese but contains traditional Chinese, using any of the simplified Chinese codepages the plugin craps itself on the traditional Chinese (showing mojibake), and then lops half the lyrics off
(have some pictures! foobar display | LRC as shown in Notepad)
Also, is there any way to find out/add/manually add the database used by TTPlayer?
Otherwise it's a great and works wonderfully
foo_uie_lyrics3
Reply #1045
Thanks for the awesome plugin!  I'm saving my lyrics to the foobar configuration folder; anyone know how to read these lyrics back using title formatting?  I want to add a column to my playlist that shows whether or not a song has lyrics...
foo_uie_lyrics3
Reply #1046
Feature Request:
+1
Awesome...but how did you create the auto playlist?  What field/code do I use to refer to the lyrics?  %lyrics% doesn't work for me because I'm saving the lyrics to the configuration folder instead of to the tags.  Thanks!
foo_uie_lyrics3
Reply #1047
Found the %lyric_exists%, %lyric_issynced%, and %lyric_current_line% global variables but they seem to work only for the currently playing song, so adding them to a playlist column doesn't work right.  Anyone know how to add a playlist column that displays whether or not a song has lyrics saved (when using files, not tags)?  Also, it'd be great if there was a way to retrieve the lyrics via a variable as one of the things I wanted to do was create an "Is Explicit" playlist column that searches lyrics for certain words and then displays the result (for listening with my kids).
Just some thoughts...thanks again for the plugin.
foo_uie_lyrics3
Reply #1048
A nice feature would be to make the lycris search more sophisticated, e.g. also checking the album title or track length if available. I have multiple songs that can be found on several albums, each with a slightly different length (or live vs studio). For these songs I always have to choose the correct synced lyrics by hand.
foo_uie_lyrics3
Reply #1049
...  e.g. also checking the album title or track length if available.
1. The ability to include album titles in searches would indeed be nice and time-saving, but it seems to me – looking at the lyrics search window – that this information all to often is missing. So sad. Thinking of e.g. Phish, Grateful Dead, and FZ - and the plethora of live recordings with these artists, sigh.
2a. The duration of songs will probably only be mentioned on lyrics sites on very rare occasions.
2b. A given song doesn't necessarily always have a 'fixed length'. Is the source a cd, a vinyl, a tape, a pure digital thing etc. etc. How  should the plugin handle minor differences – 3:08 vs. 3:11 vs. 3:05?
