Topic: TAudioConverter (Read 324081 times) previous topic - next topic
TAudioConverter
Reply #150
Awesome program.  I've been wanting something like this for awhile now.  And the pace of development is unreal!
Added ALAC support, I was just thinking about that!
Now for some nitpicking.
When encoding:
1.  I have four threads running, why do I need to see four more progress bars sitting at 0%?
2.  Option to show encoding speed rather than percents.
3.  Labels on the bottom two narrow progress bars.  I'm assuming its a buffer?  Necessary?
And for completeness:
1.  Add WavPack
2.  Add WMA/WMA Pro/WMA Lossless (bash it all you want, that's not the point)
TAudioConverter
Reply #151
Love to see all the active development on this.  So many audio tools and apps have gone stagnant in the past couple of years.
"You can fight without ever winning, but never win without a fight."  Neil Peart  'Resist'
TAudioConverter
Reply #152
Because all you need is foobar2000. No offense to ozok, I actually really like TAudioConverter.
TAudioConverter
Reply #153
None taken eahm. I love foobar2000, I even wrote a music player inspired by it a few years ago, tho I can't spare time on it now.
@antman
1) You see 8 progress bars, because I wanted to keep UI integrity. I was planning to use a list showing progress for each file, but the skinning component I use is "light edition" and it does not support skinning of such lists (listviews). Therefore I decided to use 8 progress bars otherwise it looked really ugly.
2) Added it my to-do list.
3) First one is CPU usage, second one is memory usage. You can disable them in settings window. Many users asked for them and I implemented them  .
What else can I use for WMA encoding besides FFMpeg?
TAudioConverter
Reply #156
TAudioConverter Ver 0.7.5
FhG AAC Encoder:Bit Depth setting is broken at CBR/80kbps/LC.
All files encoded at 24bits.
Apple  Macmini  Intel Core i5 (2.6 GHz)
TAudioConverter
Reply #157
@kokuyo a sample would be nice.
TAudioConverter
Reply #158
Hi ozok,
TAudioConverter just gets better and better - thanks so much. Love that it can now do ALAC.
May I please place one more thing on your "to do" list?
Would it be possible to parse all metadata text fields from the source (FLAC) to (QAAC) or (ALAC)? eg Album Artist, Album Artist Sort, Artist Sort, Album Sort etc.
With gratitude
TAudioConverter
Reply #159
When copying audio from videos the option of "Encoding mode:" , "Quality" and "Bitrate" is not grayed out, but not possible to edit. Should be grayed out so users (like me ) don't get confused, or think that TAudioConverter recodes lossy->lossy from videos.
TAudioConverter
Reply #160
Ozok: How about adding a trimming function? Cut off a given file without re-encode would have been sweet! Then we would not need all those small extra tools like "mp3DirectCut" or "mp3splt" etc.
TAudioConverter
Reply #161
Hi ozok,
Saw there was a new version of SoX released today. Have you got it yet, and if so when can we expect to see it in TAC?
TAudioConverter
Reply #162
Hi jkauff,
I've seen it too. I didn't have a chance to test it but it should work if you replace it manually. I cannot give you a time about next release at the moment, I'm a bit busy these days.
Cheers.
TAudioConverter
Reply #163
Hi jkauff,
Cheers.
Take your time. You've done quite enough already!
TAudioConverter
Reply #164
New SoX doesn't work as a manual replacement. Converted some 24/96 FLACs to 24/48, and the resulting files were truncated. Reinstalled the old files and it worked perfectly.
Not much of a test, I know, but I wouldn't recommend a manual replacement. Better to wait until you've had time to work with the new version.
TAudioConverter
Reply #166
jkauff, actually ffmpeg is used for bit depth and channel changes and resampling. Normalization, volume change is done with SoX. I do not know which (ffmpeg-SoX) is better for which operation, I simply implemented what worked.
No worries, kokuyo, I hope your problem is solved now .
TAudioConverter
Reply #167
Sorry I missed this post. It seems with QAAC only "Album Artist" can be implemented (feel free to correct me if I'm wrong). In command line help it says something about "iTunes Pre-defined tags" but i do not know what they are.
@o-l-a-v, I've changed controls' behaviours so that they get greyed too. Trimming would require a preview tool, maybe MPlayer can be used for it.
TAudioConverter
Reply #168
Interesting. I wonder if foobar is now relying on ffmpeg for those operations as well instead of the plugins. SoX always had the reputation of being the best at resampling, but maybe that's no longer true. Or maybe ffmpeg is now using the same algorithms as SoX.
Apparently my problem was that the SoX developers inadvertently left out FLAC support in the new code. If you process through ffmpeg first, that would explain why the files truncated--probably at the point you turned over the processing to SoX. That would also explain why the old SoX files worked.
TAudioConverter
Reply #170
Hi jkauff,
No it is not how i used it. But I'll use it with if it is better than FFMpeg's built-in resampler. Zeranoe builds I've been using do not have libsoxr support, I've posted a requested for that in Zeranoe's forum and I'm waiting for a response.
Cheers.
TAudioConverter
Reply #171
Thank you ozok for replying. I do not know any command line syntax so I don't know and because I don't know, I love your programme  If "Album Artist" can be implemented, it would be greatly appreciated.
Thank you again
TAudioConverter
Reply #172
Update:
-Added: Support for WMAEncoder
-Added: Changed "Copy Audio" to "Extract Audio"
-Added: Selecting "Extract Audio" will disable all the codec-related controls (thx to o-l-a-v)
-Added: Donation button
-Added: SoXr library will be used for resampling (thx to jkauff)
-Added: New icon set
-Fixed: SoX effects/filters were not applied because created temp files were not uniquely named
-Fixed: Volume effect info was shown in summary even if it was not enabled
-Fixed: Speed will be shown correctly for "Extract Audio" option
-Fixed: Progress was wrong if SoX effects were enabled
-Fixed: WAV output could not be created due to empty file name
-Updated: SoX to 14.4.1
-Updated: AlphaControls to 8.17
-Updated: QAAC and refalac to 2.15
-Updated: FFmpeg to latest static build from ffmpeg.zeranoe.com/builds/ (thx to Zeranoe for libsoxr support)
Homepage: http://taudioconverter.sourceforge.net/
Download page: https://sourceforge.net/projects/taudioconverter/
TAudioConverter
Reply #173
Link?
