Topic: CUETools versions 1.9.5 through 2.1.6 (Read 1924766 times) previous topic - next topic
CUETools versions 1.9.5 through 2.1.5 (current)
Reply #2000
I know that I ripped the CD accurately. But why there are 2 different CTDBIDs who confirm this?
Is it possible that 'Has no data track' is missing for the 1st one?
[CUETools log; Date: 10.10.2012 23:11:13; Version: 2.1.4]
CD-Extra data track length 07:33:60.
[CTDB TOCID: nd2_lfG342KoooYh.9YZYju3Ywo-] found.
        [ CTDBID ] Status
        [9f992239] (02/14) , Accurately ripped
        [cde4cd51] (08/14) Accurately ripped
        [a0061e98] (02/14) No match
        [c5d25191] (01/14) Has no data track, No match
        [0d1f3470] (01/14) No match
Track | CTDB Status
  1  | (10/14) Accurately ripped
  2  | (10/14) Accurately ripped
  3  | (11/14) Accurately ripped
  4  | (11/14) Accurately ripped
  5  | (11/14) Accurately ripped
  6  | (11/14) Accurately ripped
  7  | (11/14) Accurately ripped
  8  | (11/14) Accurately ripped
  9  | (11/14) Accurately ripped
10  | (11/14) Accurately ripped
11  | (14/14) Accurately ripped
12  | (14/14) Accurately ripped
Reply #2001
The first one should say something like "has data track length 08:05:15," (link).
I'm sure Gregory will address in the next build.
korth
Reply #2002
I still do not really understand. Does the CD exist with 2 different data track length or why a length of 07:33:60 is reported in my report?
Reply #2003
Nothing is actually stored about the data track in the CTDB except for the length. The length is more important when calculating the correct AccurateRip ID than for verifying within the CTDB. Entries under the same CTDB TOCID can include different pressings which may have different CD-Extra data track lengths or no CD-Extra data track at all.
[ CTDBID ] Status
[9f992239] (02/14) Has data track length 08:05:15, Accurately ripped
(added corrected text)
There are two database entries with a CD-Extra data track length 08:05:15. All 12 audio tracks match your rip.
There are  eight database entries with a CD-Extra data track length 07:33:60. Data track length and all 12 audio tracks match your rip.
There are two database entries with a CD-Extra data track length 07:33:60. Data track length matches but one or more tracks don't match.
There is one database entry without a data track. One or more tracks don't match.
There is one database entry with a CD-Extra data track length 07:33:60. Data track length matches but one or more tracks don't match.
CUETools log wiki page.
korth
Reply #2004
Here's another example of the CTDB numbers not adding up:
[CUETools log; Date: 10/11/2012 3:18:51 PM; Version: 2.1.4]
Pregap length 00:00:32.
[CTDB TOCID: bjRBzVtEMk2_s9NYv_2Zbcz7LTI-] found.
        [ CTDBID ] Status
        [1fc0dcb6] (1/2) Accurately ripped
        [061116fa] (1/2) No match
Track | CTDB Status
  1   | (2/2) Accurately ripped
  2   | (2/2) Accurately ripped
  3   | (2/2) Accurately ripped
  4   | (2/2) Accurately ripped
  5   | (2/2) Accurately ripped
  6   | (2/2) Accurately ripped
[AccurateRip ID: 000e3fb7-0048d2c6-490d3306] found.
Track   [  CRC   |   V2   ] Status
01     [cc741c29|0af09c97] (02+00/21) Accurately ripped
02     [dfb97852|053ed17d] (02+00/21) Accurately ripped
Reply #2005
If I leave the track naming to the default in CueTools (%tracknumber%. %title%) and do a conversion, my track number tags come out correct.
However, if I modify the track naming to look more like Picard (%discnumber%-%tracknumber%. ...), all tracks on disc 1 are tagged as track 1, and all tracks on disc 2 are tagged as 2. CueTools seems to be extracting part of the filename to insert as the track tag? Is there a way to change this behavior?
I've got the code checked out and I've got functional builds, so I might look at fixing it myself. Is there any particular reason it behaves this way at present?
Reply #2006
Could not duplicate your result using "Audio Filenames: Track format: %discnumber%-%tracknumber%. %title%" and converting with flac input/output in windows.
All CUE file text, audio file tags and file names output as expected. Perhaps some additional information needed that you did not disclose?
BTW, I would use "[%discnumber%-]%tracknumber%. %title%" making "%discnumber%-" conditional.
korth
Reply #2007
Thanks for the quick response. I guess I may have oversimplified the problem.
I went back and looked, and here is the exact string I was using in the Filename field in the options box:
$ifgreater($max(%discnumber%,%totaldiscs%),1,%discnumber%-,)%tracknumber%. %artist% - %title%
Which does the same thing as the conditional notation you suggested (which I was unaware of previously -- thanks for that)
I had also unchecked "Write basic tags from CUE data." Enabling this seems to cause the issue to stop. Which tags does this copy? Sometimes artist, trackname, etc, is changed in the files and I would rather copy those tags from the tracks than from the CUE. Either way, this should work around the issue I have for now!
Reply #2008
Not exactly. The conditional [%discnumber%-] will exclude if placeholder is blank so if %discnumber% = 1, the value is still written. The function $ifgreater($max(%discnumber%,%totaldiscs%),1,%discnumber%-,) requires %discnumber% or %totaldiscs% to be greater than 1 so if both are = 1 or blank, nothing is written.
Should have thought of that. Needs to be checked for TRACKNUMBER tag.
korth
Reply #2009
I ripped a CD with EAC & CUEripper:
Exact Audio Copy V1.0 beta 3 from 29. August 2011
EAC extraction logfile from 13. October 2012, 23:00
Texas / The Hush
Used drive  : PLEXTOR DVDR  PX-716A  Adapter: 3  ID: 0
Read mode              : Secure
Utilize accurate stream : Yes
Defeat audio cache      : No
Make use of C2 pointers : No
Read offset correction                      : 30
Overread into Lead-In and Lead-Out          : Yes
Fill up missing offset samples with silence : Yes
Delete leading and trailing silent blocks  : No
Null samples used in CRC calculations      : Yes
Used interface                              : Native Win32 interface for Win NT & 2000
Range status and errors
Selected range
    Range quality 100.0 %
    Copy CRC 09BA44B4
    Copy OK
No errors occurred
AccurateRip summary
Track  1  cannot be verified as accurate (confidence 153)  [DE6C07CB], AccurateRip returned [9250BCF3]  (AR v2)
Track  2  cannot be verified as accurate (confidence 156)  [F2A6AF28], AccurateRip returned [1D8AF52A]  (AR v2)
Track  3  cannot be verified as accurate (confidence 159)  [D1637C4C], AccurateRip returned [64FD9888]  (AR v2)
Track  4  cannot be verified as accurate (confidence 155)  [D879924D], AccurateRip returned [476B85B9]  (AR v2)
Track  5  cannot be verified as accurate (confidence 155)  [A37502B4], AccurateRip returned [350B04D2]  (AR v2)
Track  6  cannot be verified as accurate (confidence 159)  [12AEBE11], AccurateRip returned [61FC51CA]  (AR v2)
Track  7  cannot be verified as accurate (confidence 156)  [85C9B051], AccurateRip returned [45EA6F35]  (AR v2)
Track  8  cannot be verified as accurate (confidence 157)  [1E1057B5], AccurateRip returned [6AF9FCFA]  (AR v2)
Track  9  cannot be verified as accurate (confidence 155)  [CFE693C0], AccurateRip returned [EB88AAA3]  (AR v2)
Track 10  cannot be verified as accurate (confidence 154)  [BBF9D902], AccurateRip returned [C2BF949A]  (AR v2)
Track 11  cannot be verified as accurate (confidence 153)  [02C53E65], AccurateRip returned [B53BAE1E]  (AR v2)
Track 12  cannot be verified as accurate (confidence 154)  [2022F381], AccurateRip returned [210F4576]  (AR v2)
No tracks could be verified as accurate
You may have a different pressing from the one(s) in the database
End of status report
---- CUETools DB Plugin V2.1.3
[CTDB TOCID: .9SXrH02amvrI2s1GhjWPYvMaac-] found, Submit result: .9SXrH02amvrI2s1GhjWPYvMaac- has been confirmed
[c3e9138d] (344/348) Accurately ripped
[908c9bc8] (001/348) No match
[770a7501] (001/348) No match
[fcbe9131] (001/348) No match
[344df97a] (001/348) No match
CUERipper v2.1.4 Copyright © 2008-12 Grigory Chudov
EAC extraction logfile from 14. October 2012, 8:18
Texas / The Hush
Used drive  : PLEXTOR DVDR  PX-716A  Adapter: 1  ID: 0
Read mode              : Secure
Defeat audio cache      : Yes
Overread into Lead-In and Lead-Out          : No
Selected range
    Peak level 99.2 %
    Copy CRC 09BA44B4
    Copy OK
No errors occurred
AccurateRip summary
Track  1  cannot be verified as accurate (confidence 353)  [38B33BA2], AccurateRip returned [9250BCF3]
Track  2  cannot be verified as accurate (confidence 352)  [A2601080], AccurateRip returned [1D8AF52A]
Track  3  cannot be verified as accurate (confidence 354)  [2419DB0C], AccurateRip returned [64FD9888]
Track  4  cannot be verified as accurate (confidence 353)  [ADA913C3], AccurateRip returned [476B85B9]
Track  5  cannot be verified as accurate (confidence 352)  [91C83AF1], AccurateRip returned [350B04D2]
Track  6  cannot be verified as accurate (confidence 356)  [99A95E3D], AccurateRip returned [61FC51CA]
Track  7  cannot be verified as accurate (confidence 351)  [887BD1E2], AccurateRip returned [45EA6F35]
Track  8  cannot be verified as accurate (confidence 355)  [AC37DA17], AccurateRip returned [6AF9FCFA]
Track  9  cannot be verified as accurate (confidence 351)  [F8892BE4], AccurateRip returned [EB88AAA3]
Track 10  cannot be verified as accurate (confidence 350)  [6420CF02], AccurateRip returned [C2BF949A]
Track 11  cannot be verified as accurate (confidence 350)  [BC0874C2], AccurateRip returned [B53BAE1E]
Track 12  cannot be verified as accurate (confidence 348)  [D2FBFA4A], AccurateRip returned [210F4576]
1) Why do they report 2 different adapters (1 and 3)? Which program is wrong?
2) Why do I get one time a confidence of about 150 and another of 350? EAC says ARv2 - does CUEripper not support it?
3) Why do have so many CDs a pregap of 0:33? I mean why 0:33 - I think that more than 95% of my CDs with a pregap had a pregap of 0:33. Is this only an accident?
Reply #2010
Too late to edit:
And a report from another CD. A CD with pregap - so I ripped with CUEripper first and then with EAC:
[CUETools log; Date: 14.10.2012 11:45:23; Version: 2.1.4]
Pregap length 00:00:33.
[CTDB TOCID: laDRh4eiGdmrlUa9aDSXWLcpY_U-] disk not present in database.
[CTDB TOCID: laDRh4eiGdmrlUa9aDSXWLcpY_U-] found, Submit result: discs with pregaps not supported in this protocol version
[314aa017] (32/32) Differs in 0 samples @
You can use CUETools to repair this rip.
Where does the 32/32 come from? I thought that the disc was not present? Or is the plug-in too old ( i saw 2.1.3 only now while writing this post).
Edit:
So it was certainly the old-Plugin:
---- CUETools DB Plugin V2.1.4
Submit result: already submitted
Track | CTDB Status
  1  | (1/1) Accurately ripped
  2  | (1/1) Accurately ripped
  3  | (1/1) Accurately ripped
  4  | (1/1) Accurately ripped
  5  | (1/1) Accurately ripped
  6  | (1/1) Accurately ripped
  7  | (1/1) Accurately ripped
  8  | (1/1) Accurately ripped
  9  | (1/1) Accurately ripped
10  | (1/1) Accurately ripped
11  | (1/1) Accurately ripped
Windows device manager reports channel 1 (if this is meant)
Why do I get 2 different CUE-Sheets? (to shorten it i cut out all tracks > 5)
REM DISCID 910AD50B
PERFORMER "The Mighty Lemon Drops"
TITLE "World Without End"
REM DATE 1988
REM DISCNUMBER 1
REM TOTALDISCS 1
REM COMMENT "CUERipper v2.1.4 Copyright © 2008-12 Grigory Chudov"
FILE "The Mighty Lemon Drops - World Without End.flac" WAVE
  TRACK 01 AUDIO
    TITLE "Inside Out"
    INDEX 00 00:00:00
    INDEX 01 00:00:33
  TRACK 02 AUDIO
    TITLE "One By One"
    INDEX 01 03:23:50
  TRACK 03 AUDIO
    TITLE "In Everything You Do"
    INDEX 01 06:56:10
  TRACK 04 AUDIO
    TITLE "Hear Me Call"
    INDEX 01 12:03:00
  TRACK 05 AUDIO
    TITLE "No Bounds"
    INDEX 01 16:20:45
REM GENRE Rock
REM DATE 1988
REM DISCID 910AD50B
REM COMMENT "ExactAudioCopy v1.0b3"
CATALOG 0075992570121
  TRACK 01 AUDIO
    TITLE "Inside Out"
    INDEX 00 00:00:00
    INDEX 01 00:00:33
  TRACK 02 AUDIO
    TITLE "One By One"
    INDEX 00 03:23:18
    INDEX 01 03:23:50
  TRACK 03 AUDIO
    INDEX 00 06:54:08
    INDEX 01 06:56:10
  TRACK 04 AUDIO
    INDEX 00 12:02:65
    INDEX 01 12:03:00
  TRACK 05 AUDIO
    TITLE "No Bounds"
    INDEX 00 16:20:03
    INDEX 01 16:20:45
Reply #2011
Too many questions
CUERipper is combining records at all offsets. EAC doesn't do that. Examine the AccurateRip results in the accurip file from the CUERipper rip.
CUERIpper 2.1.2-2.1.4 support ARv2.
According to the CTDB statistics, 33 ranks 2nd after 32 for discs with pregap.
You mean the "Index 00" values? Index [gap] detection is another feature of the 'original' Plextor manufactured drives that might require additional read commands in CUERipper to work properly. My Plextor doesn't work correctly either. Gregory said he didn't add "Overread into Lead-In and Lead-Out" for these drives because he didn't have a drive for testing. The reason may be similar for the other features as CUERipper came about after these drives were no longer manufactured.
korth
Reply #2012
Skipped your adapter question.
CUERipper doesn't need so doesn't detect this information but because the log is an emulation of the EAC log this text is expected. CUERipper adds Adapter: 1 ID: 0 for any drive rather than omit the text in the log.
EAC interprets this information from windows and adjusts as needed for use within EAC and EAC profile .cfg files.
korth
Reply #2013
I see only 33. But my CDs were published mainly between 85 and 95. would be curious to know whether the pregap ranking is also depending on the release year.
Reply #2014
Korth, a question for you. Stuff I've ripped with DbPoweramp using the HDCD plugin gives an error message when I try to verify it with CueTools.
Does ripping stuff with the HDCD plugin make the files incompatible?
I've quit ripping with it because of this and volume problems when playing mixed tracks.
Reply #2015
As far as I know, dBpoweramp’s HDCD plug-in outputs 24-bit files (with 4 bits being padded)… and you can’t really verify those with AccurateRip or the CUETools database.
Reply #2016
I would agree with that and as stated that's why I no longer rip with that plugin. I went back and ripped stuff again that I had used it on, so it was a pain.
Reply #2017
This is not CUETools related; HDCD.exe changes the audio (provided it finds a HDCD, that is), and you will never get an AccurateRip match afterwards.
I did unfortunately rip a bit of my collection with the HDCD plugin. There is no reason to do so if you rip to a lossless format, and many reasons not to. The volume issue is one. I posted a few others here: http://forum.dbpoweramp.com/showthread.php...ll=1#post119732
Reply #2018
I have a few questions regarding s a CUETools (GUI) Verify log:
[CUETools log; Date: 9/7/2012 2:13:59 AM; Version: 2.1.4]
[CTDB TOCID: 3oyAwpWTUNxhhoGNcmgBa3GoPH4-] found.
Track | CTDB Status
  7  | (2/2) Accurately ripped
  8  | (2/2) Accurately ripped
  9  | (2/2) Accurately ripped
[AccurateRip ID: 0013b09d-009109a0-700d6d09] found.
01    [a1fc6808|677ad65d] (4+0/4) Accurately ripped
02    [527deaee|532e0924] (4+0/4) Accurately ripped
03    [8f485bb2|30f27910] (4+0/4) Accurately ripped
04    [06692c20|6a3b2800] (4+0/4) Accurately ripped
05    [180343e7|8c2a774b] (4+0/4) Accurately ripped
06    [5c269cd6|f6fff705] (4+0/4) Accurately ripped
07    [4ef738f2|069dbe9a] (4+0/4) Accurately ripped
08    [decdd0f7|eeb83fcd] (4+0/4) Accurately ripped
09    [5e24a32a|9d5e0ae1] (0+0/4) No match
#1: Is the reason it's good on CTDB but not AccurateRip most likey because it's the last track and CTDB ignores a few more frames than AccurateRip does?
#2: CTDB is a whole CD checksum, correct? (This is perfect and awesome). Shouldn't the CTDB part just be "(2/2) Accurately ripped"?
#3: ArCueTools which I compile with mono for Linux does not seem to have any CTDB support. Any chance it will in the future?
I have the same situation as #1 for one of my logs (last track accurate in CTDB and not accurate in AR. Can anyone please explain this ?
Reply #2019
AR ignores 5 first and 5 last frames of CD, CTDB ignores 10 first and 10 last frames of CD.
Reply #2020
so the last track contains errors and those are located in the frames ignored by CTDB but taken into account by AR ?
also why does AR say no match instead of 'NOT ACCURATE' then ?
im confused
Reply #2021
You could interpret that the differences are located in the last 6-10 sectors of the track. Not enough info to determine if from read errors, padding or a different pressing than the one in the AR database.
In the CUETools log, "No Match" = "Not Accurate"
korth
Reply #2022
Do plans exist for supporting tagging with CTDB Accuracy values? Chaars, Adriaan.
Reply #2023
Re CD-extras:
I do lookups using the AccurateRip ID (dBpoweramp tags with those, I extract an ACCURATERIPID tag from that). However, CUETools then returns the error “Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: index.”
when I check the CUEToolsDB box. And then the log ends abruptly.
If I uncheck that and only attempt verifying by AccurateRip, I get a proper log (at least this far), so it is only a minor nuissance though.
An unrelated question: what is current status on how submissions to CTDB are done? I sometimes get differences in tracks which are AR verified, making me wonder whether some upload (with a ripping error) has been downloaded, attempted verified, and ... submitted? I don't pity the downloaders, but I certainly don't trust them with repairing my rips :-o
Reply #2024
An unrelated question ...
Since CTDB started per-track verification, all rip results from CUERipper and the EAC plugin are submitted but repair data is only supposed to be accepted for good rips. Per-disc verification can have several (1/x) No match results from rips with some errors by design. Those results are stored to increase confidence levels for the tracks without errors. The detailed log is Off by default so most users should only see the per-track results similar to AR.
CUETools only submits to CTDB if AR confidence is greater than 1 AND no existing entry is found in CTDB.
[EDIT]
You're probably seeing a bad repair submission from the EAC plugin. See CTDB EAC Plugin: Known_issues. Don't trust (1/x) results for repair.
But it could also be an alternate pressing. If I ever get the guide written for the wiki, I have an example of such a disc.
korth
