Topic: LyricsDB discussion (Read 421165 times) previous topic - next topic
LyricsDB discussion
Reply #475
oops everyone. server was up and running, but after some power failures the database was corrupted. Seems I have successfuly repaired it, so the service is working again
dezisehtnys eb lliw noitulover eht
LyricsDB discussion
Reply #476
looks like it might be down again?
(not to appear thankless -- it's a great plug-in. thanks so much!)
LyricsDB discussion
Reply #478
First of all great plugin, many thanks for keeping up the work!
Now my question:
Is there a possibility to save the lyrics to a file? Because I don't want to save all of my lyrics in the %Lyrics%-Tag. Instead I save 'em all in /Lyrics/%artist%/%album%/%title%.txt
If there is no possibilty yet, could you just add a button to save the lyrics to a file?
I think it wouldn't be much work, because the files are already a *.txt on the server.
Thanks a lot!
LyricsDB discussion
Reply #480
Thanks for your fast reply.
But I don't get it. How can foo_utils be helpful to me? Could you explain it to me? Many Thanks in advance.
Otherwise, I think the easiest and fastest way is to surf the internet for the lyrics and save 'em manually in a file.
LyricsDB discussion
Reply #481
Format text from track information and copy to clipboard or save to file
Form http://foosion.foobar2000.org/components/?...on=0.6.2+beta+6
It seems to me this was mainly used to create nicely formatted HTML files, but I guess nothing would stop you from creating a plain text file containing only the LYRICS tag. And I suppose you can also create a keyboard shortcut to activate this functionality.
Please note that I never actually tried it, so this is pure speculation on my part.
HTH.
Alessandro
LyricsDB discussion
Reply #482
I am using the default foobar and i was wondering if it was possible to put the lyrics in just a tab?  like the UI elements?
thanks in advance
LyricsDB discussion
Reply #484
Ahhhh!  Thank you very much.  Greatly appreciated!
LyricsDB discussion
Reply #485
yep, going down for about 8 hours.
may be we do need a twitter account for messages like that?
LyricsDB discussion
Reply #486
Thanks for your plugin, it is exactly what I was looking for.
I'm using foobar on Linux with Wine, and lyricsdb did not work out of the box for me. It is necessary to override the wine dll msxml3.dll (and maybe msxml3r.dll) with an original windows dll. I am using the dll from my old Windows XP installation and now lyricsdb is working just fine for me.
(Just in case there are others with the same problem.)
LyricsDB discussion
Reply #487
oh, thanks, man, I'll place that somewhere on the site.
And by the way, it's still that bad with media players under linux? ;)
LyricsDB discussion
Reply #488
There are some players that are quite okay, but nothing like Foobar. The only thing I am missing with Wine-Foobar is Drag&Drop-Support, everything else is working perfectly fine and I could keep all my foobar-customizations from my old windows installation by just copying it to Linux. Could be worse
There are many lyrics in the database that have only the first 1-20 characters of the text and the rest is missing. One example is the complete "Hedniskhjärtad" album by Vintersorg, e.g. http://lyrics.mirkforce.net/vintersorg/norrland.txt and http://lyrics.mirkforce.net/vintersorg/stilla.txt
Does this happen due to a software bug, or is it just a careless edit by some users?
Other look like this: http://lyrics.mirkforce.net/ulver/ulvsblakk.txt
Is this some kind of automatic lyrics import or again careless editing?
(I know I can correct them myself and I'll do that whenever I find the time, but it's way to much to correct them all at once.)
Oh, and why is the FAQ visible only after login? (It's not very helpful yet, but anyway  )
LyricsDB discussion
Reply #489
there's a very annoying bug which happens when it says "some network problem, aborting" which cause it not to abort, ever, and the window just stays frozen, so i can only remove by restarting foobar.
great plugin, nevertheless
LyricsDB discussion
Reply #490
Just wondering if this is on my end or a server problem...
Always says - [Lyrics not available] in my player
Is there an option I am missing?
LyricsDB discussion
Reply #491
This is just the information I was looking for, thanks a lot. I was wondering why lyricsdb didn't work.
LyricsDB discussion
Reply #492
Is there an easy way to upload lyrics? Something like a, "Check if server has lyrics" or an "Only upload if lyrics are missing" command would make things easier. Maybe the component could show both server side and client side lyrics to let users compare them before submitting.
LyricsDB discussion
Reply #493
Like Right click -> Export to db you mean? But, if I'm not mistaken, it's extremely basic: if a song is already in the db, it will create a "twin" and you (or someone else) will have to use the web interface to do the cleanup.
HTH.
Alessandro
LyricsDB discussion
Reply #494
That sounds like time consuming, potentially unnecessary work. (In addition,) Its web interface seems to be kind of slow.
LyricsDB discussion
Reply #495
You are right, but I don't think dug is actively developing the plugin and the site anymore (yes, a real shame because it's a great project IMHO). We'll have to make the best out of what we have today... hoping it will be still here tomorrow.
Alessandro
LyricsDB discussion
Reply #496
Its almost a week now am facing this problem!
Says some network problems, aborting
Was working perfectly fine for more than months! Why this problem suddenly??
LyricsDB discussion
Reply #497
same here. the site is down too. is it the end of this great project?
LyricsDB discussion
Reply #498
goddddemit
I just freaking hate my hosting service and hope to change it in a week o less
sorry folks and thanks for your patience
LyricsDB discussion
Reply #499
Thanks for looking into it.
I had noticed this a couple of weeks ago, but assumed it was a work/proxy thing.  I should have spoken up earlier.
