Topic: How to use foo_dsp_winamp? (Read 6079 times) previous topic - next topic
i am an idiot.
i downloaded it, it's unzipped and in the foobar folder.
how do i make it work??
thanks.
i don't know the component you're talking about, but did you unzipped it to the \foobar2000\components folder?
I never heard of something called "winamp bridge". Is it a component? Please provide more information!
OK, then it's not difficult.
Preferences--->Playback--->DSP-Manager---->Activate Winamp DSP Bridge--->Configure selected---->Winamp Plugin Path
Once installed into the component's dir. you need to have a at least one winamp plugin installed, most of those plugin will require winamp to be installed. But you can by pass that by creating a winamp dir then create a winamp.exe file i it: "winamp/winamp.exe".
after that, you can go to foobar and follow the steps listed in the previous post.
By the way, im using the winamp's DFX plugin with foo_dsp_winamp.
A teacher is a student in denial.
ugh!! every time i try to put it in the component's folder it crashes foobar. what the hell am i doing wrong??
