Poll
What VBR setting do you use?
-V0 (.XXX) (--[alt-]preset [fast] extreme)
[ 128 ] (28.3%)
-V1 (.XXX)
[ 18 ] (4%)
-V2 (.XXX) (--[alt-]preset [fast] standard)
[ 173 ] (38.3%)
-V3 (.XXX)
[ 44 ] (9.7%)
-V4 (.XXX) (--[alt-]preset [fast] medium)
[ 24 ] (5.3%)
-V5 (.XXX)
[ 52 ] (11.5%)
-V6 (.XXX)
[ 7 ] (1.5%)
-V7 (.XXX)
[ 0 ] (0%)
-V8 (.XXX) or -V9 (.XXX)
[ 1 ] (0.2%)
Other
[ 5 ] (1.1%)
Total Members Voted: 613
Topic: Which LAME VBR settings do you use? (Read 136449 times) previous topic - next topic
Following memomai's thread on the subject, a poll regarding your LAME VBR habits.
NB: If you use -V5.5, choose the "-V5 (.XXX)" option.
If you don't use VBR, don't bother contributing; this poll is for LAME VBR users only.
I'm on a horse.
V5
3.98.2
No floating point
(Since today...)
thanks Synthetic_Soul, perfect poll!
FB2K,APE&LAME
I use 3.98.2 with V2. I probably could get by with a higher setting, but don't have the time to ABX and find out what the best setting would be for me...
3.98.2 + -V2
-V 0  (excessive but this is my comfort zone)
LAME 3.98.2 (higher bitrates, longer changelog against 3.97)
No floating point (too complicated)
3.98.2, -V 5, no floating point values, keep it simple amigos
we was young an' full of beans
Am still using V2, since V0 sometimes only does some minor improvements; but most of time V0 does solve my problems though. Also still using LAME 3.97, since i find regression issues are more common with 3.98.2 at V2. I even had to encode a box set with 3.90.3, since I found about 2 tracks on the first disc that was not transparent with 3.97 (even at V0) and a track was not transparent with 3.98.2, but sound fine to me with 3.90.3 at APS.
Anyway if I have to move to higher bitrate, I would use V1 over V0 since V1 is effective with only a 30kbps increase, IMO theres no difference between those settings most of the time. I have even been thinking of using V3, since on some of my personal test I find to only sound only a tad worse on tracks that are not transparent at V2.
"I never thought I'd see this much candy in one mission!"
Voted! 3.98.2 at -V3 with no floating point usage here. I do appreciate good encodings, but I'm not mega-fussy to be honest so integer values suit me fine.
Thanks to memomai for kicking this off and to Synthetic Soul for setting up the poll. Good job!
Cheers, Slipstreem.
I use v3.98.2, -V2 for my "mobile music" (in car deck and on my Sandisk Sansa with rockbox) but most probably will switch to -V3 (I have to do some more abx-tests). For my family I encode to -V4 because they don't know about artifacts and don't identify them.
Edit: I voted -V2 and I don't using floating point, I like things to be as simple as possible. For more bitrate control we have ABR.
I actually went from -V5 to V5.7 on my portable, I dont really believe I hear any difference in the enviroments i listen in =)
3.98.2, -V 2.
Winamp, foobar2000, CDex... They all allow to use floating-point values with, say, Vorbis but not with LAME.
V2, 3.98.2, no floating point values.
  • [a href='index.php?showtopic=19785']2004[/a]
  • [a href='index.php?showtopic=32741']2005[/a]
  • [a href='index.php?showtopic=45592']2006[/a]
  • [a href='index.php?showtopic=55879']2007[/a]
Standard is standard...
I think you'd need to start a new topic. If you do, bear in mind that the value is now floating point, so you may need to use options like "-V2(.X)", rather than "-V2". or maybe ask people to round their value to the nearest integer.  A separate question asking if anyone is actually using a floating point value may be interesting...
I've got no rights to start a poll.
I think anyone can make a poll
I voted 3.98.2 and -V2.
Just a sidenote, the last time there was a similar poll, -V2 was the leading choice.
I chose -V 3 with Lame 3.98.2 and no floating point values.  I have since migrated down from -V 2 with 3.97 and can now fit about 25 extra songs on a 700MB CD-RW disc and about 500 extra songs on a 16GB device.  All-in-all, I have been please with 3.98's (and 3.98.2's) encoding results and now see no need in using a high bitrate setting like -V 2.
This poll was for lame 3.97 not 3.98(.2)
FB2K,APE&LAME
Thanks for the links to other polls, it will be interesting to compare the results.  I did have a quick look, but couldn't find them.
I voted early on, but I guess I should post my preferences:
  • -V5
  • 3.98.2
  • No
I've been using -V5 for quite a while now, since guruboolez posted some favourable results (with the 3.97 betas I think).  At the time many members were using -V2/--alt-preset standard or -V0/--alt-preset extreme, and I felt quite inadequate.  Since then we have had listening tests proving that the setting is transparent to many people, which makes me feel a little better about my hearing.  I'm just happy that I can squeeze more on my pathetic 1GB Nano.
NB: I have tried testing the first three samples in the current ~128kbps listening test and I just cannot tell any difference.  I'm not sure I even found the low anchor on one.
I'm on a horse.
At the moment (210 votes), you can see that more and more people are using other presets than V2. I'm not sure if we can still call it a "standard" in 2008.
You exactly summarize my thinking Synthetic Soul.
I've followed Guru's listening tests for years (also en français) with great interest too.
-V0 -b224
best quality !!
Version: Lame 3.98.2
Music: V0
Audio Book, Radio Play, Comedy: V2
Portable: V5
Floating Point: Sometimes
.halverhahn
ABR 270 was my favorite, but now: -V0 -b224: the quality of preset extreme without the problem of VBR
version: 3.98.2
portable: V4
Using V3, because i don't keep a lossless backup, yet i consider the V2 overkill and being affected by SFB21 bloat. I do not expect my music to be "perfect" - i just want any issues to be rare and non-annoying in severity.
Don't want to go off-topic but why would VBR be a problem?  Lame was tuned for VBR encoding and forcing a minimum bitrate like you have only limits the encoder and can cause decreased quality.
I wonder who voted for 3.90.3 as that is rather old and I thought it was no longer recommended after 3.97b1 came out.
