Listening test using 2013-03-09 build
RobertM
post Mar 9 2013, 10:49
I completed a listening test against Opus files encoded with the latest build (as of 2013-09-03). This time I've actually been more thorough - ABX test results from foobar2000 are attached along with the Opus-encoded files. I also took azaqiel's advice and updated the version reported by the encoder, to prevent any confusion.
"Sample 01" from the page below was used for the test. May repeat the test later with other difficult samples.
http://people.xiph.org/~greg/opus/ha2011/
Summary:
Results were very much as expected. Opus quality has definitely improved over time and gets closer to transparency with higher bitrate.
1. 64kb/s from the above page (old opus version) and 64kb/s from the newest Opus version
There was a noticeable improvement in quality with the new Opus version
2. 64kb/s vs original
It was fairly easy to tell the difference, but still quite good quality
3. 96 kb/s vs original
Could still tell the difference but artifacts were noticably improved from the 64kb/s file
4. 128 kb/s vs original
Still can hear a very subtle artifact introduced by the codec (which appears on the note between 2.155 seconds and 2.423 seconds) but had to strain to hear it.
5. 256 kb/s vs original
Very close to transparent. I managed to tell the difference sometimes by listening very hard for the artifact. However, my ability to tell the two apart was far from perfect.
6. 500 kb/s vs original
This was transparent to me.
Attached File(s)
kabal4e
post Mar 12 2013, 02:54
Thanks to RobertM I have an opus-tools build from 2013.03.09.
I mistakenly believed it had variable framesize as in opus_exp branch built in. Unfrtunately, it didn't, but after some ABX-ing I realised I couldn't distinguish the difference between the latest general and experimental builds anyway.
However, a while ago, maybe not in Opus branch of HA, a sweep sample was tested. And Opus performed very bad. I was hoping to see some improvement, but there wasn't any. Please, listen to samples attached and judge yourself.
This post has been edited by kabal4e: Mar 12 2013, 03:35
Attached File(s)
- RobertM   Listening test using 2013-03-09 build   Mar 9 2013, 10:49
- - zerowalker   Isnīt that pretty bad, to not be able to reach tra...   Mar 10 2013, 22:44
|- - saratoga   QUOTE (zerowalker @ Mar 10 2013, 16:44) I...   Mar 10 2013, 22:56
|- - jmvalin   QUOTE (saratoga @ Mar 10 2013, 16:56) Its...   Mar 11 2013, 00:05
- - db1989   Yes, it was a sample that is known to be difficult...   Mar 10 2013, 22:55
|- - zerowalker   QUOTE (db1989 @ Mar 10 2013, 22:55) Yes, ...   Mar 10 2013, 23:00
- - IgorC   RobertM, Let me comment two things. First, one s...   Mar 10 2013, 23:53
|- - RobertM   QUOTE (IgorC @ Mar 11 2013, 09:53) Robert...   Mar 11 2013, 08:30
- - eahm   Is there a Windows compiled 2013-09-03?   Mar 11 2013, 00:26
- - wswartzendruber   Is there a place that houses updated builds of the...   Mar 11 2013, 02:51
- - RobertM   In an effort to be "fair" to the Opus en...   Mar 11 2013, 10:05
- - kabal4e   Thanks to RobertM I have an opus-tools build from ...   Mar 12 2013, 02:54
|- - jmvalin   QUOTE (kabal4e @ Mar 11 2013, 20:54) Than...   Mar 12 2013, 03:17
|- - kabal4e   QUOTE (jmvalin @ Mar 12 2013, 15:17) As m...   Mar 12 2013, 03:34
||- - jmvalin   QUOTE (kabal4e @ Mar 11 2013, 21:34) Howe...   Mar 12 2013, 03:45
|- - jmvalin   QUOTE (jmvalin @ Mar 11 2013, 21:17) Wow...   Mar 12 2013, 18:45
|- - RobertM   QUOTE (jmvalin @ Mar 13 2013, 03:45) QUOT...   Mar 12 2013, 20:14
|- - jmvalin   QUOTE (RobertM @ Mar 12 2013, 15:14) I...   Mar 12 2013, 20:44
|- - kabal4e   QUOTE (jmvalin @ Mar 13 2013, 08:44) I hi...   Mar 12 2013, 23:39
|- - db1989   QUOTE (kabal4e @ Mar 12 2013, 22:39) Foob...   Mar 13 2013, 00:13
|- - jmvalin   QUOTE (db1989 @ Mar 12 2013, 19:13) QUOTE...   Mar 13 2013, 03:04
|- - db1989   QUOTE (jmvalin @ Mar 13 2013, 02:04) If t...   Mar 13 2013, 09:35
|- - bawjaws   QUOTE (db1989 @ Mar 13 2013, 00:35) QUOTE...   Mar 14 2013, 17:54
- - db1989   Please explain how a bit-comparison provides any i...   Mar 14 2013, 18:49
- - jmvalin   QUOTE (db1989 @ Mar 14 2013, 13:49) Can a...   Mar 14 2013, 21:38
- - db1989   I definitely don’t disagree, and I can appre...   Mar 14 2013, 22:00
- - jmvalin   QUOTE (db1989 @ Mar 14 2013, 17:00) I def...   Mar 14 2013, 23:09
- - kabal4e   QUOTE (jmvalin @ Mar 15 2013, 11:09) What...   Mar 15 2013, 00:15
- - db1989   I do apologise if I misread anything or underestim...   Mar 15 2013, 01:33
RSS Lo-Fi Version Time is now: 22nd May 2015 - 22:57
