DAC Benchmark?
zerowalker
post Mar 8 2013, 19:11
Just wondering, how can i know if a DAC is good or bad, is there a way to Benchmark?
I remember using some kind of software from Speaker Output to Line In to compare, but not sure it that was testing the DAC or something else.
saratoga
post Mar 8 2013, 21:19
Those results are pretty good, but keep in mind that if you are using the DAC to directly drive a pair of headphones (that is without an amp), performance will be worse when the actual load is hooked up. In that case, you would want to test by splitting the output between the line in and headphones to simulate normal use more directly.
If you're just using the device as a DAC (and have a separate amp or powered speakers), then you are basically done.
zerowalker
post Mar 8 2013, 21:29
QUOTE (saratoga @ Mar 8 2013, 21:19) *
I currently only use it directly with my Headphones (though not the same connector, i use HD Audio connection from the motherboard to get it to the front panel).
But itīs the same sound card, built in.
But as i said in my other topic where i asked about Amps, i have now orderes Objective2 headphone Amp, so i should be set when i get them i guess:)
Though as i have read, my headphones HD 280 Pro, doesnīt seem to need amping, so i guess i wonīt notice any real difference.
RSS Lo-Fi Version Time is now: 28th January 2015 - 01:18
