flac 1.3.0 pre-release
romor
post Mar 4 2013, 07:56
Announced here: http://lists.xiph.org/pipermail/flac-dev/2...rch/003695.html
Git change log: https://git.xiph.org/?p=flac.git;a=summary
scripts: http://goo.gl/M1qVLQ
zfox
post Mar 7 2013, 09:25
QUOTE (ktf @ Mar 6 2013, 22:45) *
Have you found the cause? This might be an interesting case.
All tests from “check build” passed, so I guess this is not an issue.
ktf
post Mar 7 2013, 09:41
QUOTE (zfox @ Mar 7 2013, 09:25) *
Yes, but flac 1.2.1 decodes and 1.3.0pre1 gives an error, that would be a serious regression right? Or some big bad bug in 1.2.1 which we didn't know about but fixed anyhow.
This post has been edited by ktf: Mar 7 2013, 09:41
zfox
post Mar 7 2013, 10:43
It's difficult to spot this file again in my library. I will try though, later.
- romor   flac 1.3.0 pre-release   Mar 4 2013, 07:56
- - FreaqyFrequency   Whoa. They've been on 1.2.1 for six years now...   Mar 4 2013, 07:59
|- - chi   QUOTE (FreaqyFrequency @ Mar 4 2013, 07:5...   Mar 4 2013, 10:51
- - skamp   Works fine on Arch Linux.   Mar 4 2013, 11:01
- - mudlord   As usual, Fidel Castro Loco ignored Windows.   Mar 4 2013, 11:36
|- - skamp   QUOTE (mudlord @ Mar 4 2013, 11:36) As us...   Mar 5 2013, 13:14
- - romor   mudlord, don't overkill. You spent so much ink...   Mar 4 2013, 11:52
- - AiZ   -=-=-=-=-=-=-=-=-=-= Configuration Complete =-=-=-...   Mar 4 2013, 12:13
|- - marc2003   QUOTE (AiZ @ Mar 4 2013, 11:13) flac-1.3....   Mar 5 2013, 03:46
|- - Brazil2   QUOTE (AiZ @ Mar 4 2013, 12:13) flac-1.3....   Mar 5 2013, 12:35
- - zfox   Configuration summary : FLAC version : .........   Mar 4 2013, 12:36
- - Case   Compiling it with MSVC required some modifications...   Mar 4 2013, 13:22
- - zfox   I encoded 5 full random jazz/rock albums (-8) and ...   Mar 4 2013, 13:27
- - ktf   QUOTE (zfox @ Mar 4 2013, 12:36) My own L...   Mar 4 2013, 20:20
|- - zfox   QUOTE (ktf @ Mar 4 2013, 22:20) Does the ...   Mar 4 2013, 21:36
|- - ktf   QUOTE (zfox @ Mar 4 2013, 21:36) Actually...   Mar 4 2013, 22:53
||- - C.R.Helmrich   QUOTE (ktf @ Mar 4 2013, 22:53) I tried a...   Mar 5 2013, 00:08
||- - zfox   QUOTE (ktf @ Mar 5 2013, 00:53) I tried a...   Mar 5 2013, 12:52
|- - eahm   QUOTE (zfox @ Mar 4 2013, 13:36) QUOTE (k...   Mar 5 2013, 01:05
- - eahm   Agree, 1% is a good improvement. Why still no 2GB...   Mar 4 2013, 21:14
|- - db1989   Yes, still being limited to 2 GB is a glaring prob...   Mar 4 2013, 21:22
|- - ktf   QUOTE (eahm @ Mar 4 2013, 21:14) Why stil...   Mar 4 2013, 21:23
|- - benski   QUOTE (ktf @ Mar 4 2013, 15:23) QUOTE (db...   Mar 4 2013, 21:34
- - eahm   But there is a "patch", I am using Case...   Mar 4 2013, 21:27
- - Kohlrabi   Maybe Case could provide the patch file instead of...   Mar 4 2013, 22:12
|- - Case   QUOTE (Kohlrabi @ Mar 4 2013, 23:12) Mayb...   Mar 5 2013, 13:12
- - kurtnoise   ./configure --enable-static --disable-shared   Mar 5 2013, 06:59
|- - marc2003   QUOTE (kurtnoise @ Mar 5 2013, 05:59) ./c...   Mar 5 2013, 10:37
- - zfox   Well, the first directory contains wav files that ...   Mar 5 2013, 07:35
- - Kohlrabi   The >4GB files patch can be found at kode54...   Mar 5 2013, 07:38
|- - romor   QUOTE (Kohlrabi @ Mar 5 2013, 08:38) The ...   Mar 5 2013, 08:11
- - zfox   Is it possible for John33's optimizations to a...   Mar 5 2013, 07:57
- - romor   [flac-dev] Answering the Hydrogen Audio thread   Mar 5 2013, 09:42
|- - C.R.Helmrich   QUOTE (romor @ Mar 5 2013, 09:42) [flac-d...   Mar 5 2013, 22:20
- - LRN   QUOTE (Erik de Castro Lopo)I will answer what I ca...   Mar 5 2013, 10:04
|- - ktf   QUOTE (LRN @ Mar 5 2013, 10:04) Depends o...   Mar 5 2013, 10:21
- - Xenion   If i may breathe a wish for 1.3 final in this thre...   Mar 5 2013, 14:09
|- - ktf   QUOTE (Xenion @ Mar 5 2013, 14:09) If i m...   Mar 5 2013, 18:45
|- - dgauze   QUOTE (ktf @ Mar 5 2013, 09:45) QUOTE (Xe...   Mar 5 2013, 19:36
|- - Xenion   QUOTE (ktf @ Mar 5 2013, 18:45) QUOTE (Xe...   Mar 5 2013, 22:22
- - romor   QUOTE On Tue, Mar 5, 2013 at 8:10 PM, Johnny Rosen...   Mar 5 2013, 20:36
- - hidn   nothing interesting in the new version   Mar 5 2013, 21:26
- - Wombat   The question to update metaflac as part of the pac...   Mar 5 2013, 23:00
- - ktf   QUOTE (zfox @ Mar 4 2013, 12:36) 03.flac:...   Mar 6 2013, 20:45
|- - ktf   QUOTE (ktf @ Mar 6 2013, 20:45) QUOTE (C....   Mar 13 2013, 14:57
|- - IgorC   QUOTE (ktf @ Mar 13 2013, 10:57) So now ...   Mar 18 2013, 20:17
- - zfox   QUOTE (ktf @ Mar 6 2013, 22:45) Have you ...   Mar 7 2013, 09:25
|- - ktf   QUOTE (zfox @ Mar 7 2013, 09:25) QUOTE (k...   Mar 7 2013, 09:41
|- - zfox   It's difficult to spot this file again in my l...   Mar 7 2013, 10:43
- - romor   flac-1.3.0pre2 release (link in first post) It st...   Mar 9 2013, 15:30
|- - benski   QUOTE (romor @ Mar 9 2013, 09:30) flac-1....   Mar 9 2013, 17:56
- - romor   patch works fine now, flac compiles out of the box   Mar 9 2013, 20:03
- - eahm   Can anyone please post the exe? ...or instructions...   Mar 9 2013, 20:17
- - romor   Here it is, flac-1.3.0pre2 exe with metaflac, comp...   Mar 9 2013, 20:33
|- - Musique-Rabbit   Thanks romor, the pre2 is working fine for me. The...   Mar 10 2013, 03:44
- - Mach-X   just out of curiosity does anyone here go all will...   Mar 10 2013, 07:05
|- - johnb   Why would you need to re-rip? Only recode (foobar ...   Mar 10 2013, 09:45
|- - Porcus   QUOTE (Mach-X @ Mar 10 2013, 07:05) ...   Mar 10 2013, 13:24
- - skamp   From what I can tell, there are no compression imp...   Mar 10 2013, 09:50
- - romor   Binary is provided as user asked for it, and it...   Mar 10 2013, 13:22
- - ktf   QUOTE (Musique-Rabbit @ Mar 10 2013, 03...   Mar 10 2013, 23:02
- - eahm   Also why the date is up to 2009 and not 2013?   Mar 11 2013, 00:24
|- - ktf   QUOTE (eahm @ Mar 11 2013, 00:24) Also wh...   Mar 11 2013, 08:26
- - SpaceAgeHero   Will this new release support compressing multiple...   Mar 11 2013, 08:57
|- - ktf   QUOTE (SpaceAgeHero @ Mar 11 2013, 08:57)...   Mar 11 2013, 10:10
|- - Maurits   QUOTE (ktf @ Mar 11 2013, 10:10) QUOTE (S...   Mar 11 2013, 11:24
- - lvqcl   QUOTE (Maurits @ Mar 11 2013, 14:24) Cons...   Mar 11 2013, 15:07
- - skamp   FLACCL, fpFLAC   Mar 11 2013, 15:25
|- - Maurits   QUOTE (lvqcl @ Mar 11 2013, 15:07) QUOTE ...   Mar 11 2013, 17:03
- - romor   That's quite a shift. Do you have a suspect?   Mar 13 2013, 15:13
|- - benski   QUOTE (romor @ Mar 13 2013, 09:13) That...   Mar 13 2013, 15:33
- - romor   Thanks @benski. For reference this should be it: d...   Mar 13 2013, 15:47
- - lvqcl   Anybody knows how FLAC calculates MD5? I took a 1...   Mar 14 2013, 17:53
|- - ktf   QUOTE (lvqcl @ Mar 14 2013, 17:53) Anybod...   Mar 14 2013, 18:05
- - lvqcl   When ValidBitsPerSample=16: yes, FLAC just throws ...   Mar 14 2013, 18:27
|- - ktf   QUOTE (lvqcl @ Mar 14 2013, 18:27) When V...   Mar 14 2013, 20:49
|- - Case   QUOTE (ktf @ Mar 14 2013, 21:49) Other ne...   Mar 17 2013, 13:58
|- - ktf   QUOTE (Case @ Mar 17 2013, 13:58) Edit: I...   Mar 18 2013, 09:11
|- - lvqcl   QUOTE (Case @ Mar 17 2013, 16:58) Edit: I...   Mar 18 2013, 15:31
||- - Case   QUOTE (lvqcl @ Mar 18 2013, 16:31) Does -...   Mar 19 2013, 20:56
|- - db1989   QUOTE (Case @ Mar 17 2013, 12:58) [coded ...   Mar 18 2013, 23:00
- - hidn   anyway, slower and less compression than flaccl   Mar 17 2013, 13:16
- - Porcus   15 percent increase in decoding speed? It is hardl...   Mar 19 2013, 23:27
- - birdie   I've compiled FLAC 1.3 pre3 with GCC 4.8 (vani...   Apr 4 2013, 11:44
- - birdie   It also crashes when compiled with GCC 4.5.4 witho...   Apr 4 2013, 11:52
|- - chi   QUOTE (birdie @ Apr 4 2013, 11:52) Guys, ...   Apr 4 2013, 18:38
- - birdie   GIT version has the same problems. Sigh.   Apr 4 2013, 12:02
|- - ktf   Static building never worked for me, but if you bu...   Apr 4 2013, 18:43
|- - chi   QUOTE (ktf @ Apr 4 2013, 18:43) but if yo...   Apr 4 2013, 19:57
|- - ktf   QUOTE (chi @ Apr 4 2013, 20:57) That...   Apr 4 2013, 22:28
- - Case   The problems birdie has look very much like broken...   Apr 6 2013, 12:27
|- - ktf   QUOTE (Case @ Apr 6 2013, 13:27) I upload...   Apr 8 2013, 09:07
- - Case   Ouch, thanks. I used such tiny files in testing th...   Apr 8 2013, 11:09
- - Case   Fixed the bug and repeating line bug with long fil...   Apr 8 2013, 19:40
|- - ktf   QUOTE (Case @ Apr 8 2013, 20:40) Fixed th...   Apr 8 2013, 20:06
- - Case   I should hire you as my personal beta-tester. I re...   Apr 8 2013, 20:57
- - eahm   New Winamp 5.70 Build 3364 Beta 4 * Updated: [lib...   Apr 9 2013, 20:59
|- - SpaceAgeHero   QUOTE (eahm @ Apr 9 2013, 21:59) Isn...   Apr 9 2013, 21:22
|- - benski   QUOTE (eahm @ Apr 9 2013, 14:59) New Wina...   Apr 10 2013, 00:34
- - Case   I uploaded a test binary with properly made long f...   Apr 10 2013, 08:29
2 Pages V   1 2 >
Closed TopicStart new topic
RSS Lo-Fi Version Time is now: 23rd May 2015 - 05:27
