IPB
> foobar2000 Tech Support Forum Rules
Please read foobar2000 Tech Support Forum Rules before posting and comply with all the points.
Failure to provide all the information pointed out in the above document in your post is considered wasting other people's time and in extreme cases will lead to your topic getting locked without a reply.
See also: Hydrogenaudio Terms of Service.
I have to launch foobar2000 as administrator, was: "foobar2000 on Windows 8 64-bit"
Robert2
post Feb 25 2013, 19:28
Post #1
Group: Members
Will there be a version of foobar2000 supporting Windows 8 64-bit any time soon? As things stand, I have to launch foobar2000 as administrator, and confirm that I want to do so each time I launch it. Properly installed and configured applications do not require such a heavy procedure.
Thank you.
Robert
Go to the top of the page
+Quote Post
[JAZ]
post Feb 25 2013, 19:52
Post #2
Group: Members
I have no problems running foobar2000 in Windows 7 x64 in a normal user account. I believe your problem is how you installed it. Uninstall it, and when installing, allow it to use the user directory for preferences (I believe that's the default, but i can't check now without uninstalling it).
Also, note that there is a specific forum for foobar2000.
+Quote Post
Canar
post Feb 25 2013, 20:37
Post #3
Group: Super Moderator
foobar2000 runs fine for me on 64-bit Windows 8 as a limited user.
You cannot ABX the rustling of jimmies.
No mouse? No problem.
+Quote Post
Marcus Vinicus
post Feb 25 2013, 20:58
Post #4
Group: Members
Have you checked the UAC settings in the Control Panel?
+Quote Post
DustMagnet
post Feb 26 2013, 06:13
Post #5
Group: Members
To be more specific, make sure you do not install in Portable Mode into the "Program Files" or "Program Files (x86)" folders. Since Portable Mode makes no changes to the registry by design, it will not have the proper permissions.
+Quote Post
Robert2
post Feb 26 2013, 07:48
Post #6
Group: Members
Thank you all.
I installed the Portable Mode. I will reinstall in normal mode.
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 25th July 2014 - 16:07
