Lossless Extensions for Opus (Backwards Compatible), How to embed lossless deltas inside an Opus stream
wswartzendruber
post Feb 24 2013, 19:58
After reading a good chunk of the Opus RFC, I believe it may be possible to use Opus padding to embed lossless deltas for each packet. It states that this padding may be of any size, and that while an Opus encoder itself must set any padding to zero, the decoder must accept any value. It also states that when the decoder has finished reading bytes from a frame for decoding, it may not spill over into the padding for further input. Hrm... Sounds like an arbitrary extension field to me.
My only concern is about just how much padding decoders would be willing to accept before deciding that the packet is a DOS attack.
Porcus
post Feb 27 2013, 00:20
There is a “tie your hands to commitment” story to tell here. Maximum flexibility is always a good as long as you are a wise dictator and nobody knows about your flexibility. But if not?
This is a codec where some deliberate restrictions have been made. E.g., a short list of allowed sample rates, of which only one single value covers the audible range. Not only is it a restriction, it is a very clear-cut way to verify compliance, and it is so much to the core that messing with it is a very serious violation of the format. Which means, it discourages fragmentation. If you want to play the “let's make this twist and maybe sooner or later it becomes so widespread that it will be retrofitted into the de facto format if not the formal standard” game, then go somewhere else. That is a benefit of a narrow specification with few but simple rules.
And it works. Not that I would expect the OP to rule the world hacking the format to allow lossless, but in addition to the “it's not compliant” there is this “even if you do it for 48, you still have only a fraction of what you were after”.
(Another benefit is of course ease of implementation.)
This post has been edited by Porcus: Feb 27 2013, 00:22
wswartzendruber
post Feb 27 2013, 02:49
QUOTE (Porcus @ Feb 26 2013, 18:20) *
I am not trying to change how Opus works. My (maybe) future encoder covers a completely different use case: Lossless compression. It utilizes standardized Opus decoding for graceful fallback.
By the way, why bring up sample rates? If I do decide to support 96 kHz, the Opus frames themselves will still be sampled at 48 kHz, and the extra frequency response will be in the deltas. I will not violate RFC 6716 decoding constraints.
- wswartzendruber   Lossless Extensions for Opus (Backwards Compatible)   Feb 24 2013, 19:58
- - NullC   QUOTE (wswartzendruber @ Feb 24 2013, 10...   Feb 24 2013, 20:58
|- - Garf   QUOTE (NullC @ Feb 24 2013, 20:58) The op...   Feb 24 2013, 21:09
- - lvqcl   And how to losslessly encode 44.1 kHz audio?   Feb 24 2013, 21:23
|- - Garf   QUOTE (lvqcl @ Feb 24 2013, 21:23) And ho...   Feb 24 2013, 21:25
- - wswartzendruber   When I came up with this idea, my primary use case...   Feb 24 2013, 21:36
|- - saratoga   QUOTE (wswartzendruber @ Feb 24 2013, 15...   Feb 24 2013, 22:08
|- - C.R.Helmrich   QUOTE (wswartzendruber @ Feb 24 2013, 21...   Mar 19 2013, 21:45
- - wswartzendruber   Compatibility with existing Opus decoders.   Feb 24 2013, 22:10
|- - saratoga   QUOTE (wswartzendruber @ Feb 24 2013, 16...   Feb 24 2013, 22:34
|- - wswartzendruber   QUOTE (saratoga @ Feb 24 2013, 17:34) QUO...   Feb 24 2013, 22:43
- - db1989   Which, as has already been explained, is not possi...   Feb 24 2013, 22:14
- - wswartzendruber   Nowhere in this thread has it been explained that ...   Feb 24 2013, 22:21
- - saratoga   Mp3, aac.   Feb 24 2013, 22:54
|- - wswartzendruber   QUOTE (saratoga @ Feb 24 2013, 17:54) Mp3...   Feb 24 2013, 23:00
|- - saratoga   Do you really care? The MP3 patent license is alm...   Feb 25 2013, 00:10
|- - wswartzendruber   mp3HD can't go beyond stereo and 16-bit. I...   Feb 25 2013, 01:32
|- - saratoga   QUOTE (wswartzendruber @ Feb 24 2013, 19...   Feb 25 2013, 01:36
|- - wswartzendruber   QUOTE (saratoga @ Feb 24 2013, 20:36) The...   Feb 25 2013, 01:43
|- - saratoga   There are no existing hybrid lossless decoders for...   Feb 25 2013, 02:54
|- - wswartzendruber   QUOTE (saratoga @ Feb 24 2013, 21:54) The...   Feb 25 2013, 03:10
|- - saratoga   QUOTE (wswartzendruber @ Feb 24 2013, 21...   Feb 25 2013, 20:54
- - wswartzendruber   I also missed the part above where this propositio...   Feb 25 2013, 05:18
|- - jmvalin   QUOTE (wswartzendruber @ Feb 24 2013, 23...   Feb 25 2013, 05:43
|- - wswartzendruber   Your first paragraph raises a very good and valid ...   Feb 25 2013, 06:02
|- - 2Bdecided   QUOTE (jmvalin @ Feb 25 2013, 04:43) we h...   Feb 25 2013, 12:23
|- - jensend   QUOTE (wswartzendruber @ Feb 24 2013, 22...   Feb 25 2013, 20:17
|- - wswartzendruber   QUOTE (jensend @ Feb 25 2013, 15:17) Assu...   Feb 25 2013, 20:48
- - wswartzendruber   Why does DTS-HD have a lossy core stream?   Feb 25 2013, 17:00
|- - 2Bdecided   QUOTE (wswartzendruber @ Feb 25 2013, 16...   Feb 25 2013, 17:17
|- - wswartzendruber   QUOTE (2Bdecided @ Feb 25 2013, 12:17) QU...   Feb 25 2013, 19:22
- - wswartzendruber   I can't really say that I feel motivated to ex...   Feb 25 2013, 21:47
- - Garf   The problem here is on 2 levels: a) Technical one...   Feb 26 2013, 10:50
- - Jplus   wswartzendruber: The very reason that saratoga men...   Feb 26 2013, 13:57
- - wswartzendruber   I knew of an MPEG-4 scheme that involved an AAC tr...   Feb 26 2013, 19:59
|- - saratoga   QUOTE (wswartzendruber @ Feb 26 2013, 13...   Feb 26 2013, 20:54
- - wswartzendruber   I'm looking more towards the future, in terms ...   Feb 26 2013, 21:57
|- - Soap   If your response to saratoga's comments about ...   Feb 26 2013, 22:16
- - Porcus   There is a “tie your hands to commitment...   Feb 27 2013, 00:20
|- - wswartzendruber   QUOTE (Porcus @ Feb 26 2013, 18:20) If yo...   Feb 27 2013, 02:49
|- - saratoga   QUOTE (wswartzendruber @ Feb 26 2013, 20...   Feb 27 2013, 03:22
||- - wswartzendruber   QUOTE (saratoga @ Feb 26 2013, 21:22) QUO...   Feb 27 2013, 03:25
|- - Porcus   QUOTE (wswartzendruber @ Feb 27 2013, 02...   Feb 27 2013, 19:55
|- - wswartzendruber   QUOTE (Porcus @ Feb 27 2013, 13:55) OK, s...   Feb 27 2013, 22:27
|- - Porcus   QUOTE (wswartzendruber @ Feb 27 2013, 22...   Feb 28 2013, 01:07
- - saratoga   It sounding more and more like you're going to...   Feb 27 2013, 03:32
|- - wswartzendruber   QUOTE (saratoga @ Feb 26 2013, 21:32) It ...   Feb 27 2013, 04:06
- - wswartzendruber   World domination is irrelevant. Anyway, I looked ...   Mar 1 2013, 00:52
- - wswartzendruber   OptimFROG is showing promise.   Mar 1 2013, 03:05
- - wswartzendruber   The 1.1 alpha build has further increased the effi...   Mar 15 2013, 04:47
- - wswartzendruber   Crap, I meant to say that I'm going use R5 vio...   Mar 15 2013, 07:13
- - LithosZA   Lossless extensions to Opus would be completely po...   Mar 15 2013, 08:37
- - wswartzendruber   Yeah, I hear you there. I've contacted the Op...   Mar 16 2013, 23:53
- - wswartzendruber   I have heard back from the OptimFROG developer. H...   Mar 19 2013, 04:42
|- - NullC   QUOTE (wswartzendruber @ Mar 18 2013, 20...   Mar 25 2013, 22:28
|- - wswartzendruber   QUOTE (NullC @ Mar 25 2013, 16:28) QUOTE ...   Mar 25 2013, 23:23
|- - jmvalin   QUOTE (wswartzendruber @ Mar 25 2013, 18...   Mar 25 2013, 23:53
|- - Soap   QUOTE (wswartzendruber @ Mar 25 2013, 17...   Mar 25 2013, 23:54
- - wswartzendruber   I solicited Florin for interest in the project and...   Mar 20 2013, 01:12
- - wswartzendruber   I am no longer seeking to use Opus padding. I now...   Mar 26 2013, 00:44
|- - jmvalin   QUOTE (wswartzendruber @ Mar 25 2013, 19...   Mar 26 2013, 00:55
||- - wswartzendruber   QUOTE (jmvalin @ Mar 25 2013, 18:55) QUOT...   Mar 26 2013, 03:53
||- - jmvalin   QUOTE (wswartzendruber @ Mar 25 2013, 22...   Mar 26 2013, 04:47
|- - Soap   QUOTE (wswartzendruber @ Mar 25 2013, 18...   Mar 26 2013, 01:15
- - 2Bdecided   I wonder why you've chosen opus? Rather than a...   Mar 26 2013, 10:35
- - wswartzendruber   MP3 stops at stereo. Besides that, there is alrea...   Mar 26 2013, 20:59
|- - db1989   QUOTE (wswartzendruber @ Mar 26 2013, 19...   Mar 26 2013, 21:04
- - wswartzendruber   First off, mp3 Surround (which I would hypothetica...   Mar 27 2013, 02:26
|- - saratoga   QUOTE (wswartzendruber @ Mar 26 2013, 20...   Mar 27 2013, 02:52
|- - Soap   QUOTE (saratoga @ Mar 26 2013, 20:52) MP3...   Mar 27 2013, 02:57
- - saratoga   Actually I suppose if the goal is to have this wor...   Mar 27 2013, 03:02
- - wswartzendruber   I see that reiteration is necessary. 1. I have no...   Mar 27 2013, 04:08
|- - saratoga   QUOTE (wswartzendruber @ Mar 26 2013, 22...   Mar 27 2013, 04:23
- - wswartzendruber   1. I am not out to extend OptimFROG, I'm out t...   Mar 27 2013, 04:44
- - wswartzendruber   I sent Florin one last email asking for input. If...   Mar 29 2013, 04:37
|- - C.R.Helmrich   QUOTE (wswartzendruber @ Mar 29 2013, 04...   Mar 29 2013, 15:10
- - wswartzendruber   I'll just use this thread as sort of a log. A...   Mar 30 2013, 22:58
- - Dynamic   With mention of an open lossy codec being a requir...   Mar 31 2013, 10:54
- - Destroid   Dynamic's suggestion is very interesting. In a...   Mar 31 2013, 11:55
- - wswartzendruber   One of the main reasons for choosing Opus is becau...   Mar 31 2013, 15:40
- - wswartzendruber   Florin got back to me. He's just in a bit of ...   Apr 1 2013, 22:52
- - wswartzendruber   One week, right. I think he's in a bit more o...   Apr 19 2013, 06:38
|- - wswartzendruber   QUOTE (wswartzendruber @ Apr 19 2013, 01...   Aug 9 2013, 22:24
|- - wswartzendruber   Florin finally got back to me! He's been ...   Nov 30 2013, 21:08
- - darkbyte   This stuff died quickly. Nevertheless i wonder w...   Aug 7 2014, 10:52
|- - wswartzendruber   QUOTE (darkbyte @ Aug 7 2014, 05:52) This...   Aug 7 2014, 14:09
|- - saratoga   QUOTE (darkbyte @ Aug 7 2014, 05:52) This...   Aug 7 2014, 19:28
|- - 2Bdecided   QUOTE (darkbyte @ Aug 7 2014, 10:52) Most...   Aug 12 2014, 13:41
|- - skamp   QUOTE (2Bdecided @ Aug 12 2014, 14:41) If...   Aug 12 2014, 14:03
|- - wswartzendruber   QUOTE (2Bdecided @ Aug 12 2014, 07:41) As...   Sep 6 2014, 18:03
|- - wswartzendruber   Good grief. Firefox can't even handle packets...   Sep 6 2014, 19:56
|- - wswartzendruber   Apparently editing posts has some kind of expirati...   Sep 7 2014, 00:01
- - darkbyte   Okay sorry, it's just there was no update for ...   Aug 7 2014, 14:35
|- - wswartzendruber   I've already decided on using the same contain...   Aug 7 2014, 19:13
|- - jmvalin   QUOTE (wswartzendruber @ Aug 7 2014, 14:1...   Aug 7 2014, 19:34
|- - wswartzendruber   QUOTE (jmvalin @ Aug 7 2014, 14:34) So wh...   Aug 7 2014, 20:07
|- - jmvalin   QUOTE (wswartzendruber @ Aug 7 2014, 15:0...   Aug 11 2014, 19:10
|- - skamp   QUOTE (jmvalin @ Aug 11 2014, 20:10) QUOT...   Aug 11 2014, 20:13
- - saratoga   I think people generally expect poorly thought out...   Aug 7 2014, 20:12
- - wswartzendruber   Well, none of the players I've tested are fall...   Sep 6 2014, 17:58
2 Pages V   1 2 >
RSS Lo-Fi Version Time is now: 29th March 2015 - 14:49
