Lossless Extensions for Opus (Backwards Compatible), How to embed lossless deltas inside an Opus stream
wswartzendruber
post Feb 24 2013, 19:58
After reading a good chunk of the Opus RFC, I believe it may be possible to use Opus padding to embed lossless deltas for each packet. It states that this padding may be of any size, and that while an Opus encoder itself must set any padding to zero, the decoder must accept any value. It also states that when the decoder has finished reading bytes from a frame for decoding, it may not spill over into the padding for further input. Hrm... Sounds like an arbitrary extension field to me.
My only concern is about just how much padding decoders would be willing to accept before deciding that the packet is a DOS attack.
saratoga
post Feb 24 2013, 22:54
Mp3, aac.
wswartzendruber
post Feb 24 2013, 23:00
QUOTE (saratoga @ Feb 24 2013, 17:54) *
Mp3, aac.
Why yes, MP3 does have lossless extensions. It's also heavily patented.
saratoga
post Feb 25 2013, 00:10
Do you really care? The MP3 patent license is almost always paid anyway on hardware devices (e.g. android, dvd players, etc) and no one is going to go after some niche hybrid lossless format for royalties since theres no money in it.
It sounded like you wanted compatibility. If so, just use MP3 or AAC.
This post has been edited by db1989: Feb 25 2013, 12:55
Reason for edit: deleting pointless full quote
wswartzendruber
post Feb 25 2013, 01:32
mp3HD can't go beyond stereo and 16-bit. I'm also unaware of any lossless extensions for AAC. And I do care about patents because this isn't just about me. I would also like for others to be able to use this, as well.
Reason for edit: "
saratoga
post Feb 25 2013, 01:36
QUOTE (wswartzendruber @ Feb 24 2013, 19:32) *
There are actually lossless extensions for both, but aren't you planning to implement your own system? Who cares what already exists?
Realistically the number of people who would ever use something like this is so small you will never attract enough attention for patent licensing to matter.
wswartzendruber
post Feb 25 2013, 01:43
QUOTE (saratoga @ Feb 24 2013, 20:36) *
Interestingly enough, you answered your own question. The new system must remain compatible with existing decoders precisely because nobody will have a new one. At least at first.
Think of it like this, "Hey, here's this lossless codec you can use, and it still plays on anything that can decode Opus."
This post has been edited by wswartzendruber: Feb 25 2013, 01:44
saratoga
post Feb 25 2013, 02:54
There are no existing hybrid lossless decoders for Opus, so if your goal is to be compatible with an existing lossless implementation (which is not what you said above but what you seem to be implying here), you cannot use Opus. You would have to use the existing Mp3 or AAC variants.
If your goal is to be compatible only with an existing lossy format, then you can use any of the above mentioned formats, either extending it to your needs or simply using existing software and standards. In this case, I'd probably recommend just using MPEG-4 SLS, as it is backwards compatible with anything that supports AAC and is already standardized. You could also use MP3 and simply define your own correction format, but since you want 5.1 support, it would probably be easier to use AAC since there is already widespread support for 5.1 AAC.
This post has been edited by db1989: Feb 25 2013, 11:14
wswartzendruber
post Feb 25 2013, 03:10
QUOTE (saratoga @ Feb 24 2013, 21:54) *
There are no existing hybrid lossless decoders for Opus, so if your goal is to be compatible with an existing lossless implementation...
Now I think I see the problem. There is a fundamental misunderstanding of what I am saying. Here is the principal of operation for the encoder:
1. Take the current chunk of input PCM and use an Opus encoder to generate a compressed, lossy, Opus packet.
2. Decode this packet (probably with the fixed-point decoder) and hang on to the PCM values it returns.
3. Subtract these PCM values from the input PCM values and compress those with a lossless codec.
4. Store this this new, losslessly-compressed chunk of data in the Opus padding area.
Here's the principal of operation for a standard Opus decoder:
1. Take the current input Opus packet and decode it to PCM.
2. Ignore the padding.
Here's the principal of operation for the decoder I would make.
1. Take the current input Opus packet and decode it to PCM with the fixed-point decoder.
2. Take the padding and feed it into the lossless decoder.
3. Add the decoded Opus value and the decoded lossless value together and store it as output PCM.
Does this make more sense now?
This post has been edited by wswartzendruber: Feb 25 2013, 03:11
saratoga
post Feb 25 2013, 20:54
QUOTE (wswartzendruber @ Feb 24 2013, 21:10) *
This is just what I said above:
This is still your best bet to come up with something actually useful.
- wswartzendruber   Lossless Extensions for Opus (Backwards Compatible)   Feb 24 2013, 19:58
- - NullC   QUOTE (wswartzendruber @ Feb 24 2013, 10...   Feb 24 2013, 20:58
|- - Garf   QUOTE (NullC @ Feb 24 2013, 20:58) The op...   Feb 24 2013, 21:09
- - lvqcl   And how to losslessly encode 44.1 kHz audio?   Feb 24 2013, 21:23
|- - Garf   QUOTE (lvqcl @ Feb 24 2013, 21:23) And ho...   Feb 24 2013, 21:25
- - wswartzendruber   When I came up with this idea, my primary use case...   Feb 24 2013, 21:36
|- - saratoga   QUOTE (wswartzendruber @ Feb 24 2013, 15...   Feb 24 2013, 22:08
|- - C.R.Helmrich   QUOTE (wswartzendruber @ Feb 24 2013, 21...   Mar 19 2013, 21:45
- - wswartzendruber   Compatibility with existing Opus decoders.   Feb 24 2013, 22:10
|- - saratoga   QUOTE (wswartzendruber @ Feb 24 2013, 16...   Feb 24 2013, 22:34
|- - wswartzendruber   QUOTE (saratoga @ Feb 24 2013, 17:34) QUO...   Feb 24 2013, 22:43
- - db1989   Which, as has already been explained, is not possi...   Feb 24 2013, 22:14
- - wswartzendruber   Nowhere in this thread has it been explained that ...   Feb 24 2013, 22:21
- - saratoga   Mp3, aac.   Feb 24 2013, 22:54
|- - wswartzendruber   QUOTE (saratoga @ Feb 24 2013, 17:54) Mp3...   Feb 24 2013, 23:00
|- - saratoga   Do you really care? The MP3 patent license is alm...   Feb 25 2013, 00:10
|- - wswartzendruber   mp3HD can't go beyond stereo and 16-bit. I...   Feb 25 2013, 01:32
|- - saratoga   QUOTE (wswartzendruber @ Feb 24 2013, 19...   Feb 25 2013, 01:36
|- - wswartzendruber   QUOTE (saratoga @ Feb 24 2013, 20:36) The...   Feb 25 2013, 01:43
|- - saratoga   There are no existing hybrid lossless decoders for...   Feb 25 2013, 02:54
|- - wswartzendruber   QUOTE (saratoga @ Feb 24 2013, 21:54) The...   Feb 25 2013, 03:10
|- - saratoga   QUOTE (wswartzendruber @ Feb 24 2013, 21...   Feb 25 2013, 20:54
- - wswartzendruber   I also missed the part above where this propositio...   Feb 25 2013, 05:18
|- - jmvalin   QUOTE (wswartzendruber @ Feb 24 2013, 23...   Feb 25 2013, 05:43
|- - wswartzendruber   Your first paragraph raises a very good and valid ...   Feb 25 2013, 06:02
|- - 2Bdecided   QUOTE (jmvalin @ Feb 25 2013, 04:43) we h...   Feb 25 2013, 12:23
|- - jensend   QUOTE (wswartzendruber @ Feb 24 2013, 22...   Feb 25 2013, 20:17
|- - wswartzendruber   QUOTE (jensend @ Feb 25 2013, 15:17) Assu...   Feb 25 2013, 20:48
- - wswartzendruber   Why does DTS-HD have a lossy core stream?   Feb 25 2013, 17:00
|- - 2Bdecided   QUOTE (wswartzendruber @ Feb 25 2013, 16...   Feb 25 2013, 17:17
|- - wswartzendruber   QUOTE (2Bdecided @ Feb 25 2013, 12:17) QU...   Feb 25 2013, 19:22
- - wswartzendruber   I can't really say that I feel motivated to ex...   Feb 25 2013, 21:47
- - Garf   The problem here is on 2 levels: a) Technical one...   Feb 26 2013, 10:50
- - Jplus   wswartzendruber: The very reason that saratoga men...   Feb 26 2013, 13:57
- - wswartzendruber   I knew of an MPEG-4 scheme that involved an AAC tr...   Feb 26 2013, 19:59
|- - saratoga   QUOTE (wswartzendruber @ Feb 26 2013, 13...   Feb 26 2013, 20:54
- - wswartzendruber   I'm looking more towards the future, in terms ...   Feb 26 2013, 21:57
|- - Soap   If your response to saratoga's comments about ...   Feb 26 2013, 22:16
- - Porcus   There is a “tie your hands to commitment...   Feb 27 2013, 00:20
|- - wswartzendruber   QUOTE (Porcus @ Feb 26 2013, 18:20) If yo...   Feb 27 2013, 02:49
|- - saratoga   QUOTE (wswartzendruber @ Feb 26 2013, 20...   Feb 27 2013, 03:22
||- - wswartzendruber   QUOTE (saratoga @ Feb 26 2013, 21:22) QUO...   Feb 27 2013, 03:25
|- - Porcus   QUOTE (wswartzendruber @ Feb 27 2013, 02...   Feb 27 2013, 19:55
|- - wswartzendruber   QUOTE (Porcus @ Feb 27 2013, 13:55) OK, s...   Feb 27 2013, 22:27
|- - Porcus   QUOTE (wswartzendruber @ Feb 27 2013, 22...   Feb 28 2013, 01:07
- - saratoga   It sounding more and more like you're going to...   Feb 27 2013, 03:32
|- - wswartzendruber   QUOTE (saratoga @ Feb 26 2013, 21:32) It ...   Feb 27 2013, 04:06
- - wswartzendruber   World domination is irrelevant. Anyway, I looked ...   Mar 1 2013, 00:52
- - wswartzendruber   OptimFROG is showing promise.   Mar 1 2013, 03:05
- - wswartzendruber   The 1.1 alpha build has further increased the effi...   Mar 15 2013, 04:47
- - wswartzendruber   Crap, I meant to say that I'm going use R5 vio...   Mar 15 2013, 07:13
- - LithosZA   Lossless extensions to Opus would be completely po...   Mar 15 2013, 08:37
- - wswartzendruber   Yeah, I hear you there. I've contacted the Op...   Mar 16 2013, 23:53
- - wswartzendruber   I have heard back from the OptimFROG developer. H...   Mar 19 2013, 04:42
|- - NullC   QUOTE (wswartzendruber @ Mar 18 2013, 20...   Mar 25 2013, 22:28
|- - wswartzendruber   QUOTE (NullC @ Mar 25 2013, 16:28) QUOTE ...   Mar 25 2013, 23:23
|- - jmvalin   QUOTE (wswartzendruber @ Mar 25 2013, 18...   Mar 25 2013, 23:53
|- - Soap   QUOTE (wswartzendruber @ Mar 25 2013, 17...   Mar 25 2013, 23:54
- - wswartzendruber   I solicited Florin for interest in the project and...   Mar 20 2013, 01:12
- - wswartzendruber   I am no longer seeking to use Opus padding. I now...   Mar 26 2013, 00:44
|- - jmvalin   QUOTE (wswartzendruber @ Mar 25 2013, 19...   Mar 26 2013, 00:55
||- - wswartzendruber   QUOTE (jmvalin @ Mar 25 2013, 18:55) QUOT...   Mar 26 2013, 03:53
||- - jmvalin   QUOTE (wswartzendruber @ Mar 25 2013, 22...   Mar 26 2013, 04:47
|- - Soap   QUOTE (wswartzendruber @ Mar 25 2013, 18...   Mar 26 2013, 01:15
- - 2Bdecided   I wonder why you've chosen opus? Rather than a...   Mar 26 2013, 10:35
- - wswartzendruber   MP3 stops at stereo. Besides that, there is alrea...   Mar 26 2013, 20:59
|- - db1989   QUOTE (wswartzendruber @ Mar 26 2013, 19...   Mar 26 2013, 21:04
- - wswartzendruber   First off, mp3 Surround (which I would hypothetica...   Mar 27 2013, 02:26
|- - saratoga   QUOTE (wswartzendruber @ Mar 26 2013, 20...   Mar 27 2013, 02:52
|- - Soap   QUOTE (saratoga @ Mar 26 2013, 20:52) MP3...   Mar 27 2013, 02:57
- - saratoga   Actually I suppose if the goal is to have this wor...   Mar 27 2013, 03:02
- - wswartzendruber   I see that reiteration is necessary. 1. I have no...   Mar 27 2013, 04:08
|- - saratoga   QUOTE (wswartzendruber @ Mar 26 2013, 22...   Mar 27 2013, 04:23
- - wswartzendruber   1. I am not out to extend OptimFROG, I'm out t...   Mar 27 2013, 04:44
- - wswartzendruber   I sent Florin one last email asking for input. If...   Mar 29 2013, 04:37
|- - C.R.Helmrich   QUOTE (wswartzendruber @ Mar 29 2013, 04...   Mar 29 2013, 15:10
- - wswartzendruber   I'll just use this thread as sort of a log. A...   Mar 30 2013, 22:58
- - Dynamic   With mention of an open lossy codec being a requir...   Mar 31 2013, 10:54
- - Destroid   Dynamic's suggestion is very interesting. In a...   Mar 31 2013, 11:55
- - wswartzendruber   One of the main reasons for choosing Opus is becau...   Mar 31 2013, 15:40
- - wswartzendruber   Florin got back to me. He's just in a bit of ...   Apr 1 2013, 22:52
- - wswartzendruber   One week, right. I think he's in a bit more o...   Apr 19 2013, 06:38
|- - wswartzendruber   QUOTE (wswartzendruber @ Apr 19 2013, 01...   Aug 9 2013, 22:24
|- - wswartzendruber   Florin finally got back to me! He's been ...   Nov 30 2013, 21:08
- - darkbyte   This stuff died quickly. Nevertheless i wonder w...   Aug 7 2014, 10:52
|- - wswartzendruber   QUOTE (darkbyte @ Aug 7 2014, 05:52) This...   Aug 7 2014, 14:09
|- - saratoga   QUOTE (darkbyte @ Aug 7 2014, 05:52) This...   Aug 7 2014, 19:28
|- - 2Bdecided   QUOTE (darkbyte @ Aug 7 2014, 10:52) Most...   Aug 12 2014, 13:41
|- - skamp   QUOTE (2Bdecided @ Aug 12 2014, 14:41) If...   Aug 12 2014, 14:03
|- - wswartzendruber   QUOTE (2Bdecided @ Aug 12 2014, 07:41) As...   Sep 6 2014, 18:03
|- - wswartzendruber   Good grief. Firefox can't even handle packets...   Sep 6 2014, 19:56
|- - wswartzendruber   Apparently editing posts has some kind of expirati...   Sep 7 2014, 00:01
- - darkbyte   Okay sorry, it's just there was no update for ...   Aug 7 2014, 14:35
|- - wswartzendruber   I've already decided on using the same contain...   Aug 7 2014, 19:13
|- - jmvalin   QUOTE (wswartzendruber @ Aug 7 2014, 14:1...   Aug 7 2014, 19:34
|- - wswartzendruber   QUOTE (jmvalin @ Aug 7 2014, 14:34) So wh...   Aug 7 2014, 20:07
|- - jmvalin   QUOTE (wswartzendruber @ Aug 7 2014, 15:0...   Aug 11 2014, 19:10
|- - skamp   QUOTE (jmvalin @ Aug 11 2014, 20:10) QUOT...   Aug 11 2014, 20:13
- - saratoga   I think people generally expect poorly thought out...   Aug 7 2014, 20:12
- - wswartzendruber   Well, none of the players I've tested are fall...   Sep 6 2014, 17:58
2 Pages V   1 2 >
RSS Lo-Fi Version Time is now: 30th January 2015 - 10:52
