a response to a growing rumor...
Dibrom
post Feb 12 2002, 00:36
Founder
Group: Admin
Normally I wouldn't attempt to address an issue in this manner, but since it is getting a bit out of hand, and usually on boards I'm not participating in (or have little desire to participate in), I'll try and address it officially, once, in the place where it should be the most relevant.
The matter I'm discussing is related to the --alt-presets and their handling of the "stereo image".
There have been some completely unsubstantiated reports and rampant speculation going on in a few threads which I will list below:
1. http://66.96.216.160/cgi-bin/YaBB.pl?board...&num=1013124809
2. http://www.digital-inn.de/showthread.php?threadid=8212
3. http://www.hydrogenaudio.org/forums/showth...s=&threadid=759 (I simply hadn't gotten around to responding to this thread though its on this board).
At any rate, I'll try to make a few points as clearly as I can.
1. All of the --alt-preset VBR modes are tuned for "stereo image".
2. All of the vbr presets provide better sound quality via joint stereo than LAME on it's own with joint stereo, and in some cases should even sound better than with --nssafejoint, while at the same time providing a lower bitrate.
3. The --alt-presets do not, by design, make any sacrifice in regards to stereo image to keep bitrate down. Anyone who tells you this has no idea what they are talking about. I should know since I actually wrote the code and designed the presets.
4. An extremely high degree of stereo frames is not always needed to achieve good sound quality. I challenge anyone who believes that --alt-preset standard has poor stereo seperation, on a common basis (as a few unsubstantiated claims imply), to provide me with direct evidence of this.
5. Joint stereo is needed even at bitrates of 320kbps to achieve the best sound quality in some critical cases. Forcing stereo on everything up to 320kbps and then forcing joint stereo does not fix the problem (as user implies in one of those threads). I've tried this before.
6. There seems to be a misconception that all that the --alt-presets improve on are pre-echo. This is sorely mistaken. Indeed they do improve on pre-echo and impulse handling to a fairly large degree, but they also improve upon:
- joint stereo handling (serioustrouble is a prime example)
- dropout prevention (2nd_vent_clip is a prime example)
- fluttering (gekkou is a prime example)
- knocking (velvet is a prime example)
- ringing (bloodline is a prime example)
- noise pumping (piano, rach_original, etc, are examples)
- rasping (present with noise shaping 2 on some clips like fatboy, or on clean vocals sometimes. Mostly eliminated, even on the most critical samples, with --alt-presets)
And that's just the stuff I can think of off the top of my head.
Now, that's not to say the --alt-presets are perfect. I certainly know they aren't. But they also don't have some massive flaw in regards to stereo image which is present to the degree some people imply. In fact, the only case I've seen which I put any credence in is the few isolated cases which Wombat has found (and provided samples for I might add). I will eventually attempt to address these few samples, but note that these are exceptional cases, not common cases, and as far as I can tell, they are completely unrelated to the other complaints being made. This is especially so since Wombat doesn't describe the artifact as being a collapse of the stereo field (which isn't your typical joint stereo artifact in LAME anyway...).
At any rate, I'm always looking to improve things if I can, but claims must be substantiated which includes providing abx results (which are then verified by other parties) and providing test samples, preferrably multiple ones if you are implying a problem with general behavior.
Not to come across arrogant, but for the most part, I'm the only one who truly understands the workings behind the --alt-preset specific tunings. Not even the other developers have followed my work (though that's by their choice, not mine). The code is available for all to see, but so far I have not seen anyone attempt to reimplement my modifications or to discuss them with me on a technical level. So unless you see someone who is closely related to the work I've done (ie, they have participated in testing, JohnV for example) stating something, or you see me stating something directly about the presets, then chances are whoever is discussing the presets doesn't have the full picture. This is especially true when people begin discussing how the --alt-presets work internally or technically, and especially in relation to joint stereo.
If you see a discussion on another board about these issues, please point people to this thread. If you have a question, please ask me here, you'll likely get a much more correct answer in addition to helping to keep questions about this issue centralized and concise (which will help when the FAQs are created). Speculation is not only wasteful, but it also helps to propogate misinformation such as the old "joint stereo is bad" line of thinking.
Dibrom
post Feb 15 2002, 11:29
Founder
Group: Admin
Originally posted by cd-rw.org
Just by showing up again Roel has already done more for the audiophile MP3 community than some of the posters in this thread. He re-initiated the discussion about optimal LAME settings and that's always a good thing.
There's only one problem. The discussion he "re-initiated" appears now to be nothing more than to debate the points of the --alt-presets (or why they aren't right for --r3mix, etc, etc).
Basically, we're now back to the same old situation as before with the --dm-presets. Roel doesn't think the benefits are worth it because he can't hear them, and it doesn't matter how many other people do, it simply doesn't matter. He'll continue to state --r3mix is CD-Quality (incorrectly) and continue to advocate, if nothing else, a technically inferior preset.
I think the nature of the discussion now is actually more harmful than useful because continuing down this course is pretty much useless judging by past trials (I'm sure you remember...). Forward progress is what is necessary, and downplaying the merits of real improvements which cannot be denied serves no constructive purpose that I can see.
It would be nice to see some agreement from the other party on something which has been doing extremely well on all fronts and which has been proven multiple times to be superior, but I seriously doubt that is going to happen. Instead, I fear that the discussion will regress back into 2 divided camps and nothing more. It's a pity really, because in the end, its the users that suffer.
- Dibrom   a response to a growing rumor...   Feb 12 2002, 00:36
- - rc55   Dibrom, I'd say it'd be a good idea to keep this ...   Feb 12 2002, 00:52
- - Dibrom   QUOTE Originally posted by rc55 I'd say it'd be a...   Feb 12 2002, 01:03
- - ff123   It's a many-headed hydra. Just as soon as one can...   Feb 12 2002, 02:53
- - Dibrom   QUOTE Originally posted by ff123 It's a many-head...   Feb 12 2002, 06:03
- - mithrandir   The --alt-presets are some of the best improvement...   Feb 12 2002, 06:54
- - PatchWorKs   Well, sincerly i can't understand why LAME have so...   Feb 12 2002, 10:48
- - cadabra3   As a Psychologist (forgive me ahead of time); I se...   Feb 12 2002, 11:13
- - JohnV   QUOTE Originally posted by cadabra3 As a Psycholo...   Feb 12 2002, 13:47
- - brosselle   QUOTE Originally posted by ff123 I think the bes...   Feb 12 2002, 15:17
- - JohnV   Well, just read Roel's (r3mix's) comment about alt...   Feb 13 2002, 06:32
- - Dibrom   QUOTE Originally posted by JohnV Well, just read ...   Feb 13 2002, 08:22
- - Delirium   QUOTE [b]I've never really seen this verified, tha...   Feb 13 2002, 08:59
- - Gabriel   I think that an improvement for someone could be a...   Feb 13 2002, 09:23
- - Dibrom   Yes, nitpicking aside... it perhaps is possible (a...   Feb 13 2002, 09:40
- - cadabra3   JohnV- no disrespect intended- if you read a littl...   Feb 13 2002, 10:59
- - Pio2001   Roel didn't say he would never use APS, he was jus...   Feb 13 2002, 12:31
- - tangent   QUOTE Originally posted by Pio2001 Roel didn't sa...   Feb 13 2002, 14:08
- - JohnV   Also one thing to consider when comparing this sma...   Feb 13 2002, 16:02
- - Dibrom   QUOTE Originally posted by JohnV Also one thing t...   Feb 13 2002, 20:05
- - JohnV   Hey Dib, a bit OT. Could you make those pics a bit...   Feb 13 2002, 22:01
- - Dibrom   QUOTE Originally posted by JohnV Hey Dib, a bit O...   Feb 13 2002, 22:33
- - Gecko   That is some hard evidence, Dibrom! It may not exa...   Feb 13 2002, 23:00
- - Pio2001   QUOTE Originally posted by Gecko wonder how he ke...   Feb 13 2002, 23:16
- - Gecko   QUOTE Originally posted by Pio2001 It much easier...   Feb 13 2002, 23:47
- - Dibrom   Pio2001, It's a shame you didn't post your respon...   Feb 14 2002, 00:03
- - user   Hi, in r3mix and here people are referring to som...   Feb 14 2002, 00:45
- - JohnV   Uhm, user. About 7 messages above your post. Here...   Feb 14 2002, 01:05
- - JohnV   I'd say you really can't tell absolutely which one...   Feb 14 2002, 02:38
- - Pio2001   QUOTE Originally posted by Dibrom Pio2001, It's a...   Feb 14 2002, 13:09
- - JohnV   QUOTE Originally posted by Pio2001 To make it sho...   Feb 14 2002, 18:00
- - tangent   QUOTE Originally posted by Pio2001 To make it sh...   Feb 14 2002, 18:34
- - Gecko   Apart from discussing the point of the high cutoff...   Feb 14 2002, 19:52
- - Dibrom   QUOTE Originally posted by Pio2001 To make it sho...   Feb 14 2002, 21:01
- - fewtch   QUOTE Originally posted by tangent Really? Most o...   Feb 15 2002, 08:43
- - cd-rw.org   Just by showing up again Roel has already done mor...   Feb 15 2002, 10:28
- - Dibrom   QUOTE Originally posted by cd-rw.org Just by show...   Feb 15 2002, 11:29
- - johnicon   My $.02: I found the r3mix website in May of ...   Feb 15 2002, 13:25
- - brosselle   You know, I kind of liken this to the old vinyl LP...   Feb 15 2002, 14:46
- - fewtch   For some reason, I suspect Roel will "come around"...   Feb 15 2002, 15:28
- - user   Hi, during playing around with mp3gain, I found f...   Feb 15 2002, 23:08
- - Dibrom   QUOTE Originally posted by user 1.  maximize...   Feb 15 2002, 23:30
- - user   Thank you, now it is clear. yeah, as I spoke in s...   Feb 16 2002, 00:07
RSS Lo-Fi Version Time is now: 31st March 2015 - 10:56
