Opus 1.1 alpha version (not BABYEATER), [split from the good old megathread]
IgorC
post Feb 10 2013, 02:00
If somebody hasn't seen there is an official Opus 1.1 alpha.
https://ftp.mozilla.org/pub/mozilla.org/opu...alpha-win32.zip
Also some kinda settings to play with
https://wiki.xiph.org/Opus_tuning
LithosZA
post Feb 13 2013, 06:39
I compiled opus-tools with libopus 1.1-alpha using the sources posted at http://www.opus-codec.org/downloads/
I expected to see the same results as the 1.1 builds posted a page or two ago, but the encodes with my build are different. The files encoded with the build I compiled have a much greater range of bitrates within the file. At the default 96kbps you might have a bitrate range of 50 to 510 kbps, and on average, files encoded with my build had an average bitrate of about 5 kbps greater than the other 1.1-alpha builds. It's not just one or two frames encoded at 510 kbps that drives the range up either. Looking at a listing of bitrates of each frame, it seems to be driving up the bitrate fairly often compared to the other builds.
I encoded the eig test sample at the default 96kbps bitrate just to see what it would do, and the resulting opus file had an average bitrate of 222 kbps for some reason.
Is this intended behavior, or did something just not turn out right on my end?
I am not sure why your alpha build would produce different results, but you are using VBR. It should average around 96Kbps on a large set of files. If you want to target exactly around 96Kbps then you have to use CVBR.
- IgorC   Opus 1.1 alpha version (not BABYEATER)   Feb 10 2013, 02:00
- - Seren   QUOTE (IgorC @ Feb 10 2013, 09:00) If som...   Feb 10 2013, 10:53
- - moosehunter   I compiled opus-tools with libopus 1.1-alpha using...   Feb 13 2013, 04:54
- - LithosZA   QUOTE I compiled opus-tools with libopus 1.1-alpha...   Feb 13 2013, 06:39
- - Jplus   Since eig is known to be a hard sample it shouldn...   Feb 13 2013, 10:05
- - Banned   And what are these graphs supposed to show? Why do...   Feb 14 2013, 07:19
|- - softrunner   QUOTE (Banned @ Feb 14 2013, 10:19) And w...   Feb 14 2013, 09:15
|- - saratoga   QUOTE (softrunner @ Feb 14 2013, 03:15) Q...   Feb 14 2013, 20:16
|- - db1989   QUOTE (saratoga @ Feb 14 2013, 19:16) QUO...   Feb 14 2013, 20:25
- - jensend   Plenty of people ready to ream the guy with knee-j...   Feb 15 2013, 00:02
|- - db1989   QUOTE (jensend @ Feb 14 2013, 23:02) Plen...   Feb 15 2013, 16:39
- - softrunner   QUOTE (saratoga @ Feb 14 2013, 23:16) Spe...   Feb 16 2013, 02:11
|- - db1989   QUOTE (softrunner @ Feb 16 2013, 01:11) D...   Feb 16 2013, 03:48
- - IgorC   After performing some blind tests on Opus 1.1a and...   Feb 23 2013, 19:12
- - CoRoNe   Although I'm no expert in detecting audible di...   Feb 23 2013, 23:06
- - CoRoNe   I didn't think my post would fit in either of ...   Feb 23 2013, 23:51
- - IgorC   A single result for sample http://www.rarewares.or...   Mar 14 2013, 03:14
|- - jmvalin   QUOTE (IgorC @ Mar 13 2013, 22:14) A sing...   Mar 14 2013, 21:41
- - mzso   Is it normal to get weird gap/crackly artifacts at...   Mar 14 2013, 20:32
|- - IgorC   QUOTE (mzso @ Mar 14 2013, 16:32) Is it n...   Mar 15 2013, 03:59
|- - mzso   QUOTE (IgorC @ Mar 15 2013, 04:59) QUOTE ...   Mar 15 2013, 09:45
- - IgorC   The noise is constant during the whole tonal part ...   Mar 15 2013, 03:37
|- - jmvalin   QUOTE (IgorC @ Mar 14 2013, 22:37) The no...   Mar 16 2013, 00:37
- - IgorC   OK. And yes, You're right. This isn't a ...   Mar 16 2013, 02:28
|- - jmvalin   QUOTE (IgorC @ Mar 15 2013, 21:28) Also t...   Mar 16 2013, 02:50
- - IgorC   It behaves exactly the same. Both beginnings have ...   Mar 16 2013, 03:05
|- - jmvalin   QUOTE (IgorC @ Mar 15 2013, 22:05) It beh...   Mar 16 2013, 03:35
- - IgorC   No hurry at all. If it will be improved at some po...   Mar 16 2013, 03:56
- - darkbyte   I wonder if there's any new builds we can try....   Apr 1 2013, 18:10
|- - lithoc   QUOTE (darkbyte @ Apr 2 2013, 01:10) I wo...   Apr 2 2013, 06:33
- - eahm   Every codec knows how to trick our earing, don...   Apr 2 2013, 06:42
- - wswartzendruber   I'm sitting here telling myself that Google Mu...   Apr 6 2013, 03:46
- - Mach-X   Coffee. Oh and as long as Starbucks coffee exists,...   Apr 6 2013, 04:20
- - softrunner   As I wrote before, Opus 1.1 alpha has some bugs, t...   Apr 7 2013, 23:11
|- - saratoga   QUOTE (softrunner @ Apr 7 2013, 17:11) Wh...   Apr 7 2013, 23:15
|- - jmvalin   QUOTE (softrunner @ Apr 7 2013, 18:11) Fo...   Apr 8 2013, 03:01
- - softrunner   QUOTE (saratoga @ Apr 8 2013, 02:15) Sure...   Apr 7 2013, 23:19
|- - saratoga   QUOTE (softrunner @ Apr 7 2013, 17:19) QU...   Apr 8 2013, 00:35
- - Gainless   Ok, so here's another ABXable issue with tonal...   Apr 8 2013, 20:36
- - Gainless   I've played a bit around with different frames...   May 6 2013, 17:13
RSS Lo-Fi Version Time is now: 26th January 2015 - 14:46
