De-emphasis components, Postprocessor and a DSP plugin
lvqcl
post Feb 10 2013, 22:58
Plugins to do de-emphasis of pre-emphasized CDs:
* Postprocessing (foo_deemph): works only with lossless sources; always active during playback and ReplayGain scan.
* DSP plugin (foo_dsp_deemph): works with any source
* To de-emphasize a track, add a tag named PRE_EMPHASIS or PRE-EMPHASIS with a value 1, on or yes. Other tracks are unaffected.
* There's no reason to use both components at the same time.
* Don't use both foo_deemph and foo_dsp_effect (the latter has its own de-emphasis postprocessor).
* Note that even foo_dsp_deemph works only when a track is tagged: just adding it to the list of active DSPs is not enough to make it work.
Version 0.0.3:
Postprocessing plugin (works only with lossless sources): Attached File  foo_deemph.zip ( 47.29K ) Number of downloads: 1178
DSP plugin: Attached File  foo_dsp_deemph.zip ( 53.33K ) Number of downloads: 716
sources: Attached File  deemph_sources.rar ( 9.59K ) Number of downloads: 292
Version 0.1.0:
Postprocessing plugin (works only with lossless sources): Attached File  foo_deemph_0.1.0.zip ( 47.79K ) Number of downloads: 341
DSP plugin: Attached File  foo_dsp_deemph_0.1.0.zip ( 53.78K ) Number of downloads: 264
sources: Attached File  deemph_sources_0.1.0.rar ( 9.84K ) Number of downloads: 127
This post has been edited by lvqcl: Apr 25 2014, 19:29
Porcus
post May 9 2013, 19:29
Is there any reason why these components are not in the official repository?
- lvqcl   De-emphasis components   Feb 10 2013, 22:58
- - Porcus   Nice. QUOTE (lvqcl @ Feb 10 2013, 22:58)...   Feb 10 2013, 23:34
- - mudlord   I should deprecate deemphasis support and just get...   Feb 11 2013, 04:50
|- - Sandrine   Why another component? Mudlord already had a nice ...   Feb 11 2013, 09:39
|- - Porcus   QUOTE (Sandrine @ Feb 11 2013, 09:39) Why...   Feb 11 2013, 12:12
|- - Sandrine   QUOTE (Porcus @ Feb 11 2013, 13:12) it st...   Feb 12 2013, 00:20
|- - Porcus   QUOTE (Sandrine @ Feb 12 2013, 00:20) QUO...   Feb 12 2013, 01:18
- - lvqcl   QUOTE (Porcus @ Feb 11 2013, 02:34) Assum...   Feb 12 2013, 16:58
|- - Porcus   QUOTE (lvqcl @ Feb 12 2013, 16:58) QUOTE ...   Feb 12 2013, 20:37
- - mudlord   But end users might not want the extra DSPs, like ...   Feb 12 2013, 21:43
|- - Porcus   QUOTE (mudlord @ Feb 12 2013, 21:43) But ...   Feb 13 2013, 14:30
|- - mudlord   thank you for alerting me to the bugs, I really sh...   Feb 16 2013, 12:11
- - mjb2006   I just tested with a sine sweep, generated with So...   Feb 14 2013, 05:44
- - lvqcl   foo_dsp_effect postprocessing service vs. SoX: ...   Feb 14 2013, 16:01
|- - nu774   Quickly glanced at the code: https://github.com/Fa...   Feb 15 2013, 04:03
- - mjb2006   Something else of note: foo_convolve results in mo...   Feb 14 2013, 18:29
|- - lvqcl   QUOTE (mjb2006 @ Feb 14 2013, 21:29) Some...   Feb 14 2013, 18:36
- - mjb2006   Oh, thanks...that did the trick. All is well with ...   Feb 15 2013, 00:57
- - Sandrine   I forgot to say thanks for keeping tag support the...   Feb 16 2013, 19:02
- - kumbbl   How good is the de-emphasis applied by the foo_dee...   Feb 17 2013, 19:59
|- - lvqcl   QUOTE (kumbbl @ Feb 17 2013, 22:59) How g...   Feb 17 2013, 22:03
|- - mjb2006   I'm just eyeballing graphical frequency-analys...   Feb 17 2013, 22:19
- - kumbbl   just tested with some preemphasis CDs and works li...   Feb 18 2013, 16:55
|- - kumbbl   QUOTE (kumbbl @ Feb 18 2013, 09:55) just ...   Feb 19 2013, 05:59
- - mjb2006   With mudlord's new DLL I'm getting the sam...   Feb 18 2013, 21:03
- - mudlord   needs rewriting i suppose. people can use lvqcl...   Feb 19 2013, 00:57
- - mudlord   fair enough. in the foo_dsp_effect thread, I made ...   Feb 19 2013, 10:39
- - mjb2006   The latest update to foo_dsp_effect has resolved t...   Feb 19 2013, 23:21
- - EpicForever   OK, I have the question - what is the practical di...   Feb 24 2013, 19:49
- - lvqcl   I highlighted the relevant part in the 1st post wi...   Feb 24 2013, 20:06
- - EpicForever   That blue text was there before I asked the questi...   Feb 24 2013, 20:17
- - lvqcl   The text was there, the color wasn't   Feb 24 2013, 21:20
- - ManekiNeko   QUOTE (lvqcl @ Feb 10 2013, 22:58) * To d...   May 6 2013, 00:52
- - lvqcl   If all tracks were made with pre-emphasis then you...   May 6 2013, 15:35
- - Porcus   Is there any reason why these components are not i...   May 9 2013, 19:29
- - themanintheshadows_2451   QUOTE (lvqcl @ Feb 10 2013, 23:58) * To d...   Jun 26 2013, 21:07
- - themanintheshadows_2451   Added PRE_EMPHASIS to the file names, nothing. Als...   Jun 27 2013, 00:57
- - marc2003   you add tags via the properties dialog. highlight ...   Jun 27 2013, 01:01
- - themanintheshadows_2451   Finally got the damn thing to work. The results? N...   Jun 27 2013, 07:51
- - drSeehas   I have two questions: What does "always activ...   Aug 18 2013, 08:33
|- - lvqcl   QUOTE (drSeehas @ Aug 18 2013, 11:33) Wil...   Aug 18 2013, 09:14
|- - drSeehas   QUOTE (lvqcl @ Aug 18 2013, 10:14) ... As...   Aug 19 2013, 17:08
|- - db1989   QUOTE (drSeehas @ Aug 19 2013, 17:08) BUT...   Aug 19 2013, 17:54
|- - drSeehas   QUOTE (db1989 @ Aug 19 2013, 18:54) ... W...   Aug 19 2013, 18:14
- - EpicForever   QUOTE (themanintheshadows_2451 @ Jun 27 2013,...   Aug 18 2013, 08:55
- - lvqcl   Use postprocessing if you want to add correct Repl...   Aug 19 2013, 19:24
|- - gism   QUOTE (lvqcl @ Aug 19 2013, 20:24) Use po...   Jul 3 2015, 18:14
- - SEMteXXL   @lvqcl Thanks for this very interesting alternati...   Dec 16 2013, 13:17
- - SEMteXXL   Ok I tried some files which I de-emphasized by thi...   Dec 16 2013, 14:21
- - lvqcl   QUOTE (SEMteXXL @ Dec 16 2013, 16:17) My ...   Dec 16 2013, 17:40
|- - SEMteXXL   QUOTE (lvqcl @ Dec 16 2013, 10:40) QUOTE ...   Dec 16 2013, 18:48
- - lvqcl   No, it is implemented as a biquad filter, it doesn...   Dec 16 2013, 18:58
- - SEMteXXL   I see. I tried a little with status bar syntax and...   Dec 16 2013, 20:17
|- - milavla   QUOTE (SEMteXXL @ Dec 16 2013, 21:17) I s...   Yesterday, 11:16
- - Hotsoup   I'm experiencing a strange problem - I've ...   Sep 17 2014, 15:33
- - eahm   Is there an effective way to know if a CD/track ha...   Sep 17 2014, 16:03
|- - Hotsoup   QUOTE (eahm @ Sep 17 2014, 08:03) Is ther...   Sep 17 2014, 16:13
|- - eahm   QUOTE (Hotsoup @ Sep 17 2014, 08:13) I ha...   Sep 17 2014, 16:20
- - lvqcl   foo_dsp_effect also has its own deemph postprocess...   Sep 17 2014, 16:05
|- - Hotsoup   QUOTE (lvqcl @ Sep 17 2014, 08:05) foo_ds...   Sep 17 2014, 16:47
||- - eahm   QUOTE (Hotsoup @ Sep 17 2014, 08:47) @eah...   Sep 17 2014, 17:50
|- - Hotsoup   QUOTE (lvqcl @ Sep 17 2014, 08:05) foo_ds...   Sep 18 2014, 04:04
- - madman5150   Hi, I have downloaded the foo_deemph.zip and have ...   Dec 28 2014, 19:06
- - lvqcl   1) "How do I install additional components?...   Dec 29 2014, 16:41
- - milavla   lvqcl What's the difference between 0.0.3 and ...   Apr 8 2015, 11:00
- - lvqcl   0.0.3 works only with audio with 44100 Hz samplera...   Apr 8 2015, 11:39
- - milavla   lvqcl thanks   Apr 9 2015, 10:03
- - Steve Forte Rio   QUOTE Postprocessing (foo_deemph): works only with...   Jun 29 2015, 07:46
|- - Rollin   QUOTE (Steve Forte Rio @ Jun 29 2015, 09...   Jun 29 2015, 11:35
- - lvqcl   Pre-emphasis increases the loudness of audio, and ...   Jul 3 2015, 18:39
- - mjb2006   QUOTE this means that their loudness will always b...   Jul 3 2015, 22:09
- - lvqcl   I have an image+cue for Dark Side of the Moon, and...   Jul 3 2015, 22:52
- - mjb2006   Oh, good catch. I was actually comparing the wrong...   Jul 4 2015, 00:19
- - milavla   lvqcl: foo_deemph works with any lossless sources ...   Aug 28 2015, 08:19
|- - lvqcl   QUOTE (milavla @ Aug 28 2015, 10:19) lvqc...   Aug 28 2015, 14:34
- - marc2003   read the first post... QUOTE Plugins to do de-...   Aug 28 2015, 09:37
- - milavla   lvqcl: I have Monkey's Audio and WavPack lossl...   Aug 31 2015, 12:56
- - lvqcl   What versions of foobar2000 and foo_input_monkey d...   Aug 31 2015, 15:11
- - milavla   lvqcl: I tested it again and the problem is with f...   Sep 1 2015, 10:27
RSS Lo-Fi Version Time is now: 3rd September 2015 - 18:23
