level matching when comparing lossy to lossless
krabapple
post Feb 7 2013, 19:42
I probably should have had this settled in my mind long ago, but -- how necessary is it to level match when you are comparing a lossless track, to its mp3 counterpart?
By way of investigation, I compared foobar2k's reported replaygain and track peak values for the same track encoded (LAME 3.98) as V2 (195kbps VBR) and at 320 kbps CBR
lossless:
Track gain -1.08
Track Peak 0.938171
195kbps VBR:
+0.11
0.954459
320kbps CBR:
+.10
0.934477
The track peak differences are negligable, but whence comes the >1db difference in RPG gain of lossless vs. lossy? Does this mean that one should level match according to those RPG values when doing an ABX?
This post has been edited by krabapple: Feb 7 2013, 19:42
greynol
post Feb 7 2013, 20:32
QUOTE (Arnold B. Krueger @ Feb 7 2013, 11:12) *
Level matching within +/- 0.1 dB is the general rule. No level match and I will personally guarantee you will get proper identification if you are paying attention, even if you are comparing two copies of the same file but with the level shift.
I wouldn't guarantee anything. It may be the general rule, but I would definitely make an exception for lossy. To suggest that level-shifting the same source and comparing is going to be less noticeable (usage of the word "even") than comparing a lossless vs. a high-bitrate lossy version is more than a little strange. Provided the encoder isn't scaling I would not apply a level adjustment.
I guess the question of interest is the choice of criteria for matching. Back in the days before phase disruptive things like perceptual coders even peak level was good enough. Today, if nothing else use average RMS or the closest thing to it that your software supports.
I find there is too great a tendency to treat RG figures as the absolute and perfect metric for loudness matching. It definitely is not. That said I don't think level matching using RMS is a good idea either. The ideal thing to do is determine if the encoder scaled and by how much and use this to calibrate the two signals.
This post has been edited by greynol: Feb 7 2013, 21:25
Anyone having rabbit for Easter?
krabapple
post Feb 7 2013, 20:46
I seem to recall JJ somewhere making much the same cautionary critique of current level matching schemes, RPG included.
But what about lossless vs lossless -- say, comparing two remasters (for either audible difference, or for preference)? No encoder scaling involve there. Should one even bother trying to level match when there's different EQ? To the extent I've done such comparisonsm, I've always used replaygain values to 'match' them.
This post has been edited by krabapple: Feb 7 2013, 20:47
greynol
post Feb 7 2013, 20:59
QUOTE (krabapple @ Feb 7 2013, 11:46) *
You do the best you can. Personally, I still use RG because I'm an old dog and settled in on a routine. I haven't bothered with R128 and likely never will. My guess is that it won't do that much better of a job.
- krabapple   level matching when comparing lossy to lossless   Feb 7 2013, 19:42
- - lvqcl   The difference between lossless original and LAME...   Feb 7 2013, 20:01
- - Garf   If they're encoded from the same source I see ...   Feb 7 2013, 20:03
|- - krabapple   QUOTE (Garf @ Feb 7 2013, 14:03) If they...   Feb 7 2013, 20:28
- - Arnold B. Krueger   QUOTE (krabapple @ Feb 7 2013, 13:42) I p...   Feb 7 2013, 20:12
- - greynol   QUOTE (Arnold B. Krueger @ Feb 7 2013, 11...   Feb 7 2013, 20:32
|- - krabapple   QUOTE I find there is too great a tendency to trea...   Feb 7 2013, 20:46
|- - greynol   QUOTE (krabapple @ Feb 7 2013, 11:46) But...   Feb 7 2013, 20:59
- - krabapple   Here's what I get when I run the three tracks ...   Feb 7 2013, 20:37
|- - db1989   QUOTE (krabapple @ Feb 7 2013, 19:37) (So...   Feb 7 2013, 20:59
- - greynol   Thanks for the data. I believe those average RMS ...   Feb 7 2013, 20:41
- - lvqcl   Do you have foo_hdcd or use foo_dsp_effect for de-...   Feb 7 2013, 20:48
|- - krabapple   QUOTE (lvqcl @ Feb 7 2013, 14:48) Do you ...   Feb 7 2013, 20:51
- - lvqcl   foobar2000 always uses postprocessing plugins such...   Feb 7 2013, 20:56
|- - krabapple   QUOTE (lvqcl @ Feb 7 2013, 14:56) foobar2...   Feb 7 2013, 22:23
- - greynol   Without going into a prolonged discussion about it...   Feb 7 2013, 21:03
|- - [JAZ]   QUOTE (greynol @ Feb 7 2013, 21:03) Witho...   Feb 7 2013, 22:57
|- - greynol   QUOTE ([JAZ] @ Feb 7 2013, 13:57)...   Feb 7 2013, 23:11
|- - Kees de Visser   For critical work I still prefer to adjust for equ...   Feb 8 2013, 11:24
- - db1989   foobar2000 uses libebur128 since v1.1.7, so a diff...   Feb 7 2013, 21:15
- - 2Bdecided   If I understand it correctly, EBU R128 / ITU BS.17...   Feb 8 2013, 13:06
|- - DonP   QUOTE (2Bdecided @ Feb 8 2013, 07:06) Bef...   Feb 8 2013, 14:18
|- - 2Bdecided   QUOTE (DonP @ Feb 8 2013, 13:18) QUOTE (2...   Feb 8 2013, 14:56
- - 2Bdecided   I do not use automatic (RG/R128) loudness matching...   Feb 8 2013, 13:15
- - greynol   I'm glad that is all spelled out, though you c...   Feb 8 2013, 16:58
- - 2Bdecided   It's made me realise that I ought to do a tabl...   Feb 8 2013, 17:56
- - lvqcl   QUOTE (krabapple @ Feb 7 2013, 23:28) QUO...   Feb 8 2013, 23:19
RSS Lo-Fi Version Time is now: 27th March 2015 - 21:12
