level matching when comparing lossy to lossless
krabapple
post Feb 7 2013, 19:42
I probably should have had this settled in my mind long ago, but -- how necessary is it to level match when you are comparing a lossless track, to its mp3 counterpart?
By way of investigation, I compared foobar2k's reported replaygain and track peak values for the same track encoded (LAME 3.98) as V2 (195kbps VBR) and at 320 kbps CBR
lossless:
Track gain -1.08
Track Peak 0.938171
195kbps VBR:
+0.11
0.954459
320kbps CBR:
+.10
0.934477
The track peak differences are negligable, but whence comes the >1db difference in RPG gain of lossless vs. lossy? Does this mean that one should level match according to those RPG values when doing an ABX?
This post has been edited by krabapple: Feb 7 2013, 19:42
2Bdecided
post Feb 8 2013, 17:56
ReplayGain developer
It's made me realise that I ought to do a table with two columns, comparing ReplayGain and R128 step-by-step.
But I think I'll wait until someone who has actually coded R128 confirms my understanding of it.
The big differences are the different filter, the different block sizes + overlapping, and most importantly the -10dB gate + all-sample RMS of R128 vs just taking the 95th percentile RMS in ReplayGain.
The original reference levels are only a fraction of a dB out (-23LUFS is about 83.3dB SPL); ReplayGain was raised to 89dB, which, interestingly, is within about 1dB of SoundCheck.
To put it another way, you need a filter, you need some blocks, you need to add the results for each channel together, you need a dB scale, you need to ignore the quieter blocks, and you need to use a reference level of about 83dB (-20dBFS RMS, -23LUFS) to cover everything, or 89dB (-14dBFS RMS, -17LUFS) to cover mostly pop music.
It all ties in very nicely. Or to put it another way, different people "independently" came to almost the same conclusions.
EDIT: Sorry for going further off topic. Just wanted to record this somewhere having worked it all out.
This post has been edited by 2Bdecided: Feb 8 2013, 17:56
- krabapple   level matching when comparing lossy to lossless   Feb 7 2013, 19:42
- - lvqcl   The difference between lossless original and LAME...   Feb 7 2013, 20:01
- - Garf   If they're encoded from the same source I see ...   Feb 7 2013, 20:03
|- - krabapple   QUOTE (Garf @ Feb 7 2013, 14:03) If they...   Feb 7 2013, 20:28
- - Arnold B. Krueger   QUOTE (krabapple @ Feb 7 2013, 13:42) I p...   Feb 7 2013, 20:12
- - greynol   QUOTE (Arnold B. Krueger @ Feb 7 2013, 11...   Feb 7 2013, 20:32
|- - krabapple   QUOTE I find there is too great a tendency to trea...   Feb 7 2013, 20:46
|- - greynol   QUOTE (krabapple @ Feb 7 2013, 11:46) But...   Feb 7 2013, 20:59
- - krabapple   Here's what I get when I run the three tracks ...   Feb 7 2013, 20:37
|- - db1989   QUOTE (krabapple @ Feb 7 2013, 19:37) (So...   Feb 7 2013, 20:59
- - greynol   Thanks for the data. I believe those average RMS ...   Feb 7 2013, 20:41
- - lvqcl   Do you have foo_hdcd or use foo_dsp_effect for de-...   Feb 7 2013, 20:48
|- - krabapple   QUOTE (lvqcl @ Feb 7 2013, 14:48) Do you ...   Feb 7 2013, 20:51
- - lvqcl   foobar2000 always uses postprocessing plugins such...   Feb 7 2013, 20:56
|- - krabapple   QUOTE (lvqcl @ Feb 7 2013, 14:56) foobar2...   Feb 7 2013, 22:23
- - greynol   Without going into a prolonged discussion about it...   Feb 7 2013, 21:03
|- - [JAZ]   QUOTE (greynol @ Feb 7 2013, 21:03) Witho...   Feb 7 2013, 22:57
|- - greynol   QUOTE ([JAZ] @ Feb 7 2013, 13:57)...   Feb 7 2013, 23:11
|- - Kees de Visser   For critical work I still prefer to adjust for equ...   Feb 8 2013, 11:24
- - db1989   foobar2000 uses libebur128 since v1.1.7, so a diff...   Feb 7 2013, 21:15
- - 2Bdecided   If I understand it correctly, EBU R128 / ITU BS.17...   Feb 8 2013, 13:06
|- - DonP   QUOTE (2Bdecided @ Feb 8 2013, 07:06) Bef...   Feb 8 2013, 14:18
|- - 2Bdecided   QUOTE (DonP @ Feb 8 2013, 13:18) QUOTE (2...   Feb 8 2013, 14:56
- - 2Bdecided   I do not use automatic (RG/R128) loudness matching...   Feb 8 2013, 13:15
- - greynol   I'm glad that is all spelled out, though you c...   Feb 8 2013, 16:58
- - 2Bdecided   It's made me realise that I ought to do a tabl...   Feb 8 2013, 17:56
- - lvqcl   QUOTE (krabapple @ Feb 7 2013, 23:28) QUO...   Feb 8 2013, 23:19
RSS Lo-Fi Version Time is now: 4th May 2015 - 03:35
