WAV and MP3 simultaneously and LAME Settings
dms802
post Feb 4 2013, 21:25
I am archiving my collection of over 1,000 CDs. Itís a big job, and I want to get it right so I donít have to repeat it. I already started to rip CDs using iTunes and Roxio, but I noticed quite a few songs had pops, crackles, and/or distortion. At first I thought it was a problem with my CD reader, and I went out and purchased a lens cleaning disc. When that didnít solve the problem, I did more research online and realized the problem might be with the programs I was using. That is how I cam across EAC, which I really love but find a tad confusing. So, I have a few questions.
My goal is to back-up every CD in two formats: 1) WAV files to store on an external hard drive as a true archive, and 2) MP3 files to use for iTunes and portable MP3 players. Here are my questions:
1. Is it possible to save in both MP3 and WAV files while only reading the disc once? At this point, I am reading it once for the WAV files and a second time for the MP3 files. I tried just reading it once and saving as WAV files and then converting to MP3s; however, when I did that, none of the info regarding artist, track number, etc. were saved and I had to manually edit the info for use in ITunes and other players. I already have two profiles save in EAC Ė one for WAV and one for MP3. In each case, I have file naming set to save the files in folders under the artist name, with a subfolder for the artist name.
2. Regarding compression settings, I am using the latest version of LAME (I think it is 3.99.5). I would be happy with VBR and a minimum bit rate of 256 kbps, but I found it simpler to just go with 320 kbps CBR. I am not too worried about the difference in file size. I am not sure if I have the correct settings or if I could reduce the number of additional commands. Here are the additional command-line options I have entered for External Compression:
-b 320 %islow%-V 5%islow%%ishigh%-V 2%ishigh% --vbr-new %source% %dest%
And here is a screenshot of my External Compression tab:
3. Does anybody know the easier way to import the ripped MP3 tracks to iTunes? At this point, I am ripping straight to the iTunes folder, with a folder for artist and subfolder for album. After the files are ripped, I go into iTunes and add the folder to the library.
4. In terms of playback, is one player better than another? Specifically, is one player better than iTunes for playback? I also have used WinAmp. For my home stereo, I can simply play the WAV files stored on my external hard drive, but I use an iPod for traveling and the car.
Sorry for all the questions on my first post. If it would be better, I can break them down to separate posts. I am most concerned only with Questions 1 and 2 above.
phofman
post Feb 5 2013, 16:34
And then there is the wonderful mp3fs filesystem in linux which handles the flac-mp3 conversion on the fly when accessing the flac files stored on the hard drive smile.gif
- dms802   WAV and MP3 simultaneously and LAME Settings   Feb 4 2013, 21:25
- - pdq   The biggest mistake that I can see that you are ma...   Feb 4 2013, 21:54
|- - dms802   QUOTE (pdq @ Feb 4 2013, 15:54) The bigge...   Feb 4 2013, 22:02
- - Nessuno   Out of curiosity: did the pops, clicks, distortion...   Feb 4 2013, 22:54
|- - dms802   QUOTE (Nessuno @ Feb 4 2013, 16:54) Out o...   Feb 5 2013, 00:51
|- - Nessuno   QUOTE (dms802 @ Feb 5 2013, 00:51) QUOTE ...   Feb 6 2013, 08:58
|- - dms802   QUOTE (Nessuno @ Feb 6 2013, 02:58) QUOTE...   Feb 7 2013, 18:54
|- - 2Bdecided   QUOTE (dms802 @ Feb 7 2013, 17:54) I had ...   Feb 7 2013, 19:09
- - dms802   So, it sounds like the issue of ripping the disc o...   Feb 5 2013, 04:32
- - Mach-X   Those settings are rather needlessly complex. the ...   Feb 5 2013, 04:46
|- - 2Bdecided   QUOTE (Mach-X @ Feb 5 2013, 03:46) A...   Feb 7 2013, 19:07
- - db1989   Good catch on --vbr-new being unnecessary, althoug...   Feb 5 2013, 04:51
- - dms802   I had a feeling that the additional commands were ...   Feb 5 2013, 05:03
|- - db1989   QUOTE (dms802 @ Feb 5 2013, 04:03) I had ...   Feb 5 2013, 12:45
- - Aleron Ives   VBR settings target a specific quality level; spec...   Feb 5 2013, 07:06
- - phofman   And then there is the wonderful mp3fs filesystem i...   Feb 5 2013, 16:34
- - dms802   Thanks guys. I did try to figure out what all the...   Feb 5 2013, 19:52
- - pdq   That IS the case in LAME, but its use is generally...   Feb 5 2013, 20:01
- - Aleron Ives   Yes, you can use the -b switch to specify a minimu...   Feb 5 2013, 20:03
- - Mach-X   Perhaps to put in simpler terms what others are sa...   Feb 6 2013, 09:45
RSS Lo-Fi Version Time is now: 7th May 2015 - 05:55
