Looking for papers on how small level changes are misheard as quality
mzil
post Feb 1 2013, 22:27
I've often heard it said, by many audio writers I trust, that very small level differences [on the order a 1 dB or even less] are often (if not usually) perceived as quality differences by humans, and not simply level differences. I've always accepted this without question, however in arguing with others in other forums, I need documentation to back this. What I'm asking for people's help with is in finding the original work(s) which demonstrated this, in the form of a scholarly paper(s). Anyone?
This post has been edited by mzil: Feb 1 2013, 22:42
Replies (1 - 6)
julf
post Feb 2 2013, 13:48
QUOTE (mzil @ Feb 1 2013, 22:27) *
Unfortunately I don't have any pointers to proper papers - but I can confirm that last time I did a blind listening test between different hi-res resolutions, I put in one "+1 dB" control track, and it was the one that (not surprisingly) came out on top.
mzil
post Feb 2 2013, 18:08
Thanks. I have no doubt the phenomenon is real, but I need a scholarly source to cite.
The closest I have found is in an article by veteran audio writer Tom Nousiane. He refers to a test he conducted, but I don't know if it was an informal test or one of his published works:
"For example, we tend to interpret small changes in volume as sound quality. I conducted an experiment several years ago where thirty-one subjects were asked to listen to ten sets of musical passages, with each set containing two 30-second samples.
In half of the sets, both samples were played at precisely identical volumes. In the other half, there was a 1-dB difference in level between them. Although people had a strong tendency to 'prefer' the louder alternative (especially when it came as the second of two), not one of the subjects reported volume or level as a discriminating factor. All comments on how the sound changed were couched in quality terms such as 'cleaner' or 'more harsh' even though volume was the only thing that had changed."
Source:
http://www.nousaine.com/pdfs/Can%20You%20T...Your%20Ears.pdf
He also mentions the same test in this article:
http://www.nousaine.com/pdfs/Smoke%20and%20Mirrors.pdf
I don't have access to reading his published AES papers because I am not a member, nor do I have any academic credentials or connections which would give me free access. At best, all I can get is the abstracts, but I know he has written at least some general papers about audio testing, and is mentioned in some such as this. If anyone here can access this paper and see if it is the one he speaks of in this quote I've provided, I would appreciate it. Thanks.
edit : AES paper link corrected
This post has been edited by mzil: Feb 2 2013, 18:18
Nessuno
post Feb 2 2013, 18:55
I casually found a reference to the topic at hand in the discussion to this blog article about (supposed) headphone sound quality modifications after break-in.
At a certain point a poster makes a generic reference to a test made by german speaker manufacturer Nubert (better use your browser search function on that page with "nubert" as a key, as the discussion is quite long). He says they proved that different cables are not ABXable (nothing new here) but an 1dB increase made the same cable appearing a better sounding one.
Anyway a fast Google search returned nothing. Maybe some German speaking fellow here could know (or search for) better.
This post has been edited by Nessuno: Feb 2 2013, 18:59
... I live by long distance.
Kees de Visser
post Feb 2 2013, 19:52
This is just a thesis but still interesting (and free):
http://etd.lib.fsu.edu/theses/available/et...esis-Kimura.pdf
Wombat
post Feb 2 2013, 20:32
QUOTE (Nessuno @ Feb 2 2013, 19:55) *
I quickly did read some Nubert forum posts and technical papers. One paper called "ts_klangentscheidende-faktoren.pdf" describes the same thing that you already explained in 2 sentences, not more.
It only tells that a 1dB difference to the louder resulted in 'better' or 'more dynamic' felt sound in direct comparison by listeners. There is no info or further linking to that speaker cable test itself i have found.
Arnold B. Kruege...
post Feb 3 2013, 14:10
QUOTE (mzil @ Feb 2 2013, 12:08) *
Source:
I'd try emailing Tom.
RSS Lo-Fi Version Time is now: 26th May 2015 - 16:11
