Restricted Listening Tests?, Restricted bandwidth and high-end DAC's
dbmcclain
post Jan 28 2013, 23:06
Hi All,
I have been doing a lot of web research on high-end DAC's. Just ordered a Lavry DA11 to see some things for myself. But of the top 3 that I have found -- Mytek, Lavry, and Benchmark, I hear consistent comments about how much they open up the soundstage, compared to lesser systems like my MOTU 828 and Ultralights.
I do research into full-spectrum musical hearing correction for musicians and audiophiles. Many of us have lost portions of our hearing due to a variety of factors -- industrial noise, illness, misspent youth...
I wonder if anyone has tried an audio shootout among these high end converters using explicitly restricted bandwidth, say a steep lowpass filter at 10 kHz. For those with hearing impairment, there isn't much to be done about losses above 10 kHz. So apart from my anticpated comparison between a Lavry DA11 and the MOTU 828mk3, I would be interested to hear the impressions from avid, careful, listeners under conditions of restricted bandwidth playback. Can any difference be detected? or do you really need the "air" above 10 kHz to realize the differences so often noted for low-jitter accurate playback systems?
- DM
Roseval
post Jan 29 2013, 00:24
If e.g 10 kHz is the upper threshold of once hearing you won’t hear anything above 10 kHz.
But if the IMD of signals above 10 k maps into below 10 k, band limiting the signal might have an audible effect.
A steep lowpass filter at 10 kHz might yield audible pre-ringing too.
Personally I wonder if the difference between low priced and higher priced DACs got anything to do with the frequency response.
Maybe you should look at the linearity of DACs.
The cheap ones are linear up to 12 bits, the more expensive ones up 18 bits and the $4000,- up to 22 bits. I wouldn’t be surprised if “opening up”, “air”, etc. etc. is about the linearity of a DAC
TheWellTemperedComputer.com
- dbmcclain   Restricted Listening Tests?   Jan 28 2013, 23:06
- - AndyH-ha   What is needed to hear the difference is a good im...   Jan 28 2013, 23:10
|- - dbmcclain   QUOTE (AndyH-ha @ Jan 28 2013, 15:10...   Jan 28 2013, 23:15
- - greynol   You're going to have a hard time finding objec...   Jan 28 2013, 23:17
- - dbmcclain   Interesting... When I feed some worst-case wavefor...   Jan 28 2013, 23:20
|- - saratoga   QUOTE (dbmcclain @ Jan 28 2013, 17:20) In...   Jan 28 2013, 23:59
||- - dbmcclain   QUOTE (saratoga @ Jan 28 2013, 15:59) QUO...   Jan 29 2013, 00:59
||- - saratoga   QUOTE (dbmcclain @ Jan 28 2013, 18:59) My...   Jan 29 2013, 03:31
|- - Arnold B. Krueger   QUOTE (dbmcclain @ Jan 28 2013, 17:20) In...   Jan 29 2013, 15:36
- - greynol   Before going any farther in your pursuit of presen...   Jan 28 2013, 23:24
- - dbmcclain   I do agree, although "Graphs" is puzzlin...   Jan 28 2013, 23:29
- - greynol   Puzzling or not, the point is that we want to ensu...   Jan 28 2013, 23:41
- - skamp   OP: the default hypothesis here is that all DACs t...   Jan 28 2013, 23:49
- - greynol   To add, we do grant a certain degree of leniency w...   Jan 28 2013, 23:55
- - Roseval   If e.g 10 kHz is the upper threshold of once heari...   Jan 29 2013, 00:24
|- - greynol   QUOTE (Roseval @ Jan 28 2013, 15:24) I wo...   Jan 29 2013, 02:12
|- - saratoga   QUOTE (Roseval @ Jan 28 2013, 18:24) The ...   Jan 29 2013, 03:26
- - krabapple   QUOTE (dbmcclain @ Jan 28 2013, 18:06) Hi...   Jan 29 2013, 04:59
|- - Arnold B. Krueger   QUOTE (krabapple @ Jan 28 2013, 22:59) I ...   Jan 29 2013, 15:43
- - RonaldDumsfeld   I also would be interesting in this proposal. I h...   Jan 29 2013, 19:51
RSS Lo-Fi Version Time is now: 31st March 2015 - 08:07
