Problems encoding with Monkey's Audio 4.11 in fb2k
themanintheshado...
post Jan 28 2013, 11:42
The new version of Monkey's Audio (v4.11) is out, and I've been putting it through it's paces with foobar2000. The results? Not pretty.
In the transcodes I've done (FLAC to APE), there's always 1 to 3 files that won't encode correctly, and I end up getting that "Files converted with major problems, object not found" message. Transcoding the same exact files, though via command line (i.e via Multi-frontend) gives me the total opposite results. No problems at all. Even weirder, when I transcoded all the files of one album (literally) one at a time, the process went smoothly. And with another, trying to do the same brought back the same problems again.
The albums get two thumbs up via Accuraterip, and an md5 check shows no problems, so they're not the cause. What is?
1) Something in Monkey's Audio needs to be fixed?
2) foobar2000 has a problem with...
a) The MA plugin?
b) Lack of pipe support causing problems with conversions?
I vaguely remember having to do a transcode with TAK awhile back using temp wav and having problems. Switching back to pipe encoding made the problem go away. Could the problem be the result of foobar2000 not being that great with temp wav encoding?
themanintheshado...
post Jan 29 2013, 19:58
The whole anti-virus theory doesn't work in my case because I shut that off before I convert anything. And then I get a message like this"
2 out of 10 tracks converted with major problems.
Source: "C:\Downloads\U2 - 1983 - War (Island, 900167-2)_flac\03. New Year's Day.flac"
  An error occurred while finalizing the encoding process (Object not found) : "C:\Documents and Settings\RKA\My Documents\My Music\Converted\U2\1983 - War (Island 900167-2) [Target CD] (West Germany)\03. New Year's Day.ape"
  Conversion failed: Object not found
Source: "C:\Downloads\U2 - 1983 - War (Island, 900167-2)_flac\09. Surrender.flac"
  An error occurred while finalizing the encoding process (Object not found) : "C:\Documents and Settings\RKA\My Documents\My Music\Converted\U2\1983 - War (Island 900167-2) [Target CD] (West Germany)\09. Surrender.ape"
That's just one version of this type of error message I've gotten converting the same album, because the amount of problem tracks always changes every single time. One, three, two...it's totally random.
washu
post Jan 29 2013, 20:59
QUOTE (themanintheshadows_2451 @ Jan 29 2013, 13:58) *
Shutting down or disabling anti-virus software does not always remove its interference. The fact that the affected tracks changes each time points very strongly to AV or other software accessing the files. The only way to be sure is to uninstall your AV completely.
Do you have any other "security" software on your PC? Remove them as well.
This post has been edited by washu: Jan 29 2013, 20:59
RSS Lo-Fi Version Time is now: 27th May 2015 - 05:42
