Problems encoding with Monkey's Audio 4.11 in fb2k
themanintheshado...
post Jan 28 2013, 11:42
The new version of Monkey's Audio (v4.11) is out, and I've been putting it through it's paces with foobar2000. The results? Not pretty.
In the transcodes I've done (FLAC to APE), there's always 1 to 3 files that won't encode correctly, and I end up getting that "Files converted with major problems, object not found" message. Transcoding the same exact files, though via command line (i.e via Multi-frontend) gives me the total opposite results. No problems at all. Even weirder, when I transcoded all the files of one album (literally) one at a time, the process went smoothly. And with another, trying to do the same brought back the same problems again.
The albums get two thumbs up via Accuraterip, and an md5 check shows no problems, so they're not the cause. What is?
1) Something in Monkey's Audio needs to be fixed?
2) foobar2000 has a problem with...
a) The MA plugin?
b) Lack of pipe support causing problems with conversions?
I vaguely remember having to do a transcode with TAK awhile back using temp wav and having problems. Switching back to pipe encoding made the problem go away. Could the problem be the result of foobar2000 not being that great with temp wav encoding?
db1989
post Jan 28 2013, 14:49
Itís a bit of a long shot since you said that the same files can work in other cases, but do the affected filesí names contain any less common characters that may be interfering with the encoder?
RSS Lo-Fi Version Time is now: 22nd May 2015 - 11:19
