Problems encoding with Monkey's Audio 4.11 in fb2k
themanintheshado...
post Jan 28 2013, 11:42
The new version of Monkey's Audio (v4.11) is out, and I've been putting it through it's paces with foobar2000. The results? Not pretty.
In the transcodes I've done (FLAC to APE), there's always 1 to 3 files that won't encode correctly, and I end up getting that "Files converted with major problems, object not found" message. Transcoding the same exact files, though via command line (i.e via Multi-frontend) gives me the total opposite results. No problems at all. Even weirder, when I transcoded all the files of one album (literally) one at a time, the process went smoothly. And with another, trying to do the same brought back the same problems again.
The albums get two thumbs up via Accuraterip, and an md5 check shows no problems, so they're not the cause. What is?
1) Something in Monkey's Audio needs to be fixed?
2) foobar2000 has a problem with...
a) The MA plugin?
b) Lack of pipe support causing problems with conversions?
I vaguely remember having to do a transcode with TAK awhile back using temp wav and having problems. Switching back to pipe encoding made the problem go away. Could the problem be the result of foobar2000 not being that great with temp wav encoding?
ghostman
marc2003
post Jan 28 2013, 12:49
someone has already replied to your post in the main MA 4.11 thread....
QUOTE (Case @ Jan 21 2013, 12:17) *
I just converted three albums (50 files) from FLAC to APE with foobar2000 and had zero problems. The files have their md5 checksums visible in the Properties view and Integrity Verifier also reports all files to be fine. Monkey's Audio decoder doesn't need changes since nothing in the file format has changed.
perhaps you should post your encoder settings if you're expecting any more help....
This post has been edited by marc2003: Jan 28 2013, 12:49
RSS Lo-Fi Version Time is now: 5th September 2015 - 00:30
