Dumped opus streams have incorrect "Durations"., [TOS #6: moved from Scientific Discussion]
bat_guano
post Jan 24 2013, 23:19
Hi
I've tried dumping some opus streams to file, but the results are strange. ohmy.gif
Dumped files have incorrect "Durations".
This makes confusion when the files are played with VLC or SMPlayer etc.
What causes opus streams to create files with incorrect "Durations"?
And how can I fix it?
For example, a 30 second sample:-
timeout 30 ffmpeg -y -i http://radioserver1.delfa.net/64.opus -c copy SmoothJazz1.opus
MediaInfo shows incorrect Duration 4mn 17s.
General
Complete name : SmoothJazz1.opus
Format : OGG
File size : 258 KiB
Duration : 4mn 17s
Overall bit rate : 8 227 bps
Writing application : Lavf54.61.102
Audio
ID : 36710742 (0x2302956)
Format : Opus
Duration : 4mn 17s
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 44.1 KHz
Compression mode : Lossy
Writing library : Lavf54.61.102
Similar results using MPlayer
rm -f fifo && mkfifo fifo; \
timeout 30 \
mplayer -nocache -noconsolecontrols -dumpstream -dumpfile fifo \
"http://radioserver1.delfa.net/64.opus" -demuxer lavf \
& ffmpeg -y -i fifo -c copy SmoothJazz2.opus \
&& rm -f fifo
MediaInfo shows incorrect Duration 2mn 18s.
General
Complete name : SmoothJazz2.opus
Format : OGG
File size : 254 KiB
Duration : 2mn 18s
Overall bit rate : 15.0 Kbps
Audio
ID : 2098600889 (0x7D161BB9)
Format : Opus
Duration : 2mn 18s
This post has been edited by bat_guano: Jan 24 2013, 23:32
2012
post Jan 25 2013, 23:47
1st of all, those are Ogg-encapsulated Opus files.
Generally speaking, life streams are implemented in a way that clients can connect at arbitrary offsets.
In this case, the duration you see is correct! It's just the stream does not start from 0!
You can see that instantly if you play the saved file in mplayer, or if you run opusinfo:
WARNING: sequence number gap in stream 1. Got page 257 when expecting page 2. Indicates missing data. (normal for live streams)
WARNING: discontinuity in stream (1)
WARNING: EOS not set on stream 1 (normal for live streams)
RSS Lo-Fi Version Time is now: 20th April 2015 - 02:00
