What features would you like to see in opus-tools?
NullC
post Jan 22 2013, 21:13
I'm looking for suggested features to get into opus-tools prior to the libopus 1.1 release.
Before I get 1001 suggestions for it: One frequently requested feature which was recently added is flac input in opusenc. I'm contemplating changing opusdec to use the new opusfile libraryŚ which would give it seeking and integrated http(s) streaming support. Also already on my todo list are default comment packet padding so updating metadata doesn't require rewriting the files and adding a replaygain tool.
Some people would really like it if opusenc/opusdec supported taking multiple input files e.g. opusenc *.flac but the implicit output file naming is pretty ununixy, and would break the interface and I got flamed all to heck last time I changed the opusenc interface.... so I'm not sure if/how I want to accommodate that usage.
What other things have you found missing?
moosehunter
post Feb 10 2013, 05:43
There are a few things that I'd like to see. In opusenc, an option to force SILK or CELT. Goldwave already does this, and when I encode a 24kbps with SILK in Goldwave, it sounds much better than the opusenc file. This changes when you get down to 16kbps.
Going along with the voice/music detection in the 1.1-alpha, I don't know if it would be feasible, but it would be nice to dynamically scale the bitrate between detected music and voice portions of a clip with user specified bitrates for each, where the user might choose to set a bitrate of, say, 24kbps for voice, and a higher bitrate of 128 kbps for music.
And in opusinfo, a printout or graph of the bitrate vs time in the file, or maybe just a printout of the bitrate each frame, or the average bitrate at a user specified interval, so you could get a listing of the average bitrate every second, or whatever the user might specify. This might be useful for analyzing how your audio is being encoded.
jensend
post Feb 15 2013, 20:22
Wrote much of this almost a week ago; realized I still had the unfinished reply sitting around, and though it's late it still seemed worth saying.
QUOTE (moosehunter @ Feb 9 2013, 21:43) *
I find it somewhat odd that you're getting better results by forcing SILK-only at those rates; it'd normally be using hybrid. Once you get down to 16kbps it'll usually be doing SILK-only even if you don't force it. Have you looked at the output bandwidth and verified that it's only wideband? ABC/HR type blind test data confirming your preference for forced SILK would be interesting.
The mode decisions in the present encoder are fairly reasonable and will continue to be refined; thus I don't think forcing a mode is usually going to be beneficial. Also, the developers are understandably reluctant to give people options that either give them a false sense of control or allow them to shoot themselves in the foot. Nevertheless, I do want to echo the request for ways to constrain the encoder's mode and bandwidth decisions with opusenc, because I do think there are legitimate use cases. For instance, for playback on very constrained devices (e.g. many Rockbox targets), it'd be nice to be able to restrict the encoder for performance and/or battery life reasons.
With the 1.0.x encoder you could just choose a bitrate which would reliably give you the mode and bandwidth you wanted, but the adaptability of the master branch eliminates that predictability.
Another use case: I have speech recordings where the master branch encoder encodes them as fullband or keeps switching between FB and SWB but the content above 12kHz seems unhelpful. Some consonants, applause, and some noises (like dropping stuff on the podium) have appreciable HF content, but I think they're adequately represented by their energy below 12kHz. There are some noises in a few recordings- like background silverware- that are audibly affected by a 12kHz cutoff, but that's actually an improvement, since the noise is made slightly less distracting. Outside of that I don't know that I can even ABX 12kHz lowpassed versions of this material. I'd rather have those bits go to lower frequencies, and though the FB<->SWB transitions often aren't audible I think there's more danger of such transitions being audible than there is of the >12kHz content being missed. I think this situation is pretty common for speech, and while I could of course pass the encoder versions that I've lowpassed or resampled myself, it would be convenient to be able to just tell the encoder to not do FB.
This seems to come up frequently- one discussion has been moved from the old huge "ready for testing thread" to its own thread.
opusenc's --save-range already dumps each frame's framelength and size, mode and bandwidth info, etc. Not the most handy format for visualization etc, and the only documentation that tells you what's what is reading the code, but the info is there for the parsing. Obviously that doesn't help if you're trying to analyze files you encoded with some other program or files you received from a third party.
moosehunter
post Feb 18 2013, 01:49
(Can you not edit your posts?)
QUOTE (jensend @ Feb 15 2013, 13:22) *
Ahh, that was the difference. Goldwave was encoding it as super-wideband. The difference was usually night and day, depending on the voice of the person. One of the samples with the least difference between the two was the speech sample on the opus example page. I attached the two different encodes.
Given that discovery, I'd agree with the option to let the user choose the bandwidth of the output file.
Well, just feed the data into Excel, and it displays it just fine. And nevermind about my question about documentation, I didn't read this before I posted that.
Attached File(s)
jensend
post Feb 18 2013, 17:00
You can edit your posts- but only for one hour after you post, since following a discussion gets pretty strange when you can't see what people were replying to. I can appreciate that this is sometimes inconvenient. For instance, my post above looks a little silly, as though I hadn't read the last part of NullC's reply, since I clearly didn't know --save-range was available in opusdec when I wrote most of the reply a week ago. (I'd frequently used it in opusenc but hadn't ever had reason to think about it on the decoding side.) I didn't notice the anachronism until just over an hour after I posted it, and it wasn't worth another reply by itself.
QUOTE (moosehunter @ Feb 17 2013, 17:49) *
Interesting. I don't think Goldwave was forcing a higher bandwidth; it was just using libopus 1.0.1, which by default will simply and predictably use hybrid SWB at those bitrates. The pre-1.1 encoder adapts more to its input, and my experience has usually been that it bumps the bandwidth up at considerably lower bitrates than 1.0.x did. With this file, the opposite happened- it quickly switched from SWB to just WB and stayed there.
This file is quite quiet- peaking at -14 dB, ReplayGain of ~+10 - and the encoder must be making its bandwidth detection decisions on an absolute rather than relative basis. If you amplify the file by 12dB, then 1.1-alpha quickly switches to FB and stays there for the length of the file. This seems like undesirable behavior.
moosehunter
post Feb 19 2013, 01:56
QUOTE (jensend @ Feb 18 2013, 10:00) *
That file was just an example. Pretty much all other files I tested did the same thing.
- NullC   What features would you like to see in opus-tools?   Jan 22 2013, 21:13
- - skamp   What I'd like: an equivalent to vorbiscomment...   Jan 22 2013, 21:25
|- - nu774   QUOTE (skamp @ Jan 23 2013, 05:25) Slight...   Jan 23 2013, 13:12
||- - nu774   QUOTE (nu774 @ Jan 23 2013, 21:12) If I r...   Jan 23 2013, 15:15
|- - skamp   QUOTE (skamp @ Jan 22 2013, 22:25) an equ...   Jul 1 2013, 10:10
|- - Brazil2   QUOTE (skamp @ Jul 1 2013, 11:10) Well, F...   Jul 1 2013, 12:42
- - CoRoNe   Perhaps totally off-topic, but could you lend the ...   Jan 23 2013, 00:31
|- - Seren   Can't really think of anything atm except mayb...   Jan 23 2013, 12:04
|- - DonP   QUOTE (Seren @ Jan 23 2013, 06:04) Can...   Jan 23 2013, 13:14
|- - Banned   QUOTE (lvqcl @ Jan 23 2013, 15:40) Curren...   Jan 23 2013, 19:45
|- - DonP   QUOTE (Banned @ Jan 23 2013, 13:45) QUOTE...   Jan 23 2013, 20:39
|- - NullC   QUOTE (Banned @ Jan 23 2013, 11:45) Well,...   Jan 23 2013, 21:31
|- - Banned   QUOTE (NullC @ Jan 23 2013, 21:31) QUOTE ...   Jan 28 2013, 18:26
- - mamboman   Yes, converting flac to opus will be a very common...   Jan 23 2013, 12:56
|- - gottkaiser   QUOTE (mamboman @ Jan 23 2013, 12:56) ......   Jan 23 2013, 19:38
- - lvqcl   Currently opusenc requires the output filename and...   Jan 23 2013, 15:40
- - .alexander.   QUOTE (NullC @ Jan 23 2013, 00:13) I...   Jan 23 2013, 19:06
|- - saratoga   QUOTE (.alexander. @ Jan 23 2013, 13:06) ...   Jan 23 2013, 23:32
||- - .alexander.   QUOTE (saratoga @ Jan 24 2013, 02:32) Tha...   Jan 24 2013, 00:04
|- - jmvalin   QUOTE (.alexander. @ Jan 23 2013, 13:06) ...   Jan 24 2013, 02:02
- - Dynamic   I think there was a time when VBR quality scales t...   Jan 23 2013, 23:20
- - azaqiel   I would like an opus gain tool that ONLY TAGS the ...   Jan 24 2013, 04:41
- - LithosZA   A maximum bandwidth setting. In libopus the bandwi...   Jan 26 2013, 12:40
- - IgorC   Intensity stereo (IS) setting as all other phsycoa...   Jan 26 2013, 13:09
- - bat_guano   QUOTE (NullC @ Jan 22 2013, 21:13) I...   Jan 26 2013, 19:02
- - nu774   Bitrate might be surely enough when one is working...   Jan 27 2013, 17:42
- - Dynamic   I think QAAC's TVBR settings are roughly half ...   Jan 28 2013, 03:30
|- - NullC   QUOTE (Dynamic @ Jan 27 2013, 18:30) If p...   Feb 4 2013, 19:58
- - moosehunter   There are a few things that I'd like to see. I...   Feb 10 2013, 05:43
|- - NullC   QUOTE (moosehunter @ Feb 9 2013, 20:43) T...   Feb 15 2013, 20:02
||- - moosehunter   QUOTE (NullC @ Feb 15 2013, 13:02) Use th...   Feb 18 2013, 00:31
|- - jensend   Wrote much of this almost a week ago; realized I s...   Feb 15 2013, 20:22
|- - moosehunter   (Can you not edit your posts?) QUOTE (jensend ...   Feb 18 2013, 01:49
|- - jensend   You can edit your posts- but only for one hour aft...   Feb 18 2013, 17:00
|- - moosehunter   QUOTE (jensend @ Feb 18 2013, 10:00) This...   Feb 19 2013, 01:56
|- - jmvalin   QUOTE (jensend @ Feb 18 2013, 11:00) Inte...   Feb 19 2013, 07:11
- - LithosZA   QUOTE A maximum bandwidth setting. In libopus the ...   Feb 18 2013, 06:45
- - Omicron   It would be good to make a feature in encoder so u...   Feb 21 2013, 12:28
|- - db1989   QUOTE (Omicron @ Feb 21 2013, 11:28) It w...   Feb 21 2013, 21:22
- - azaqiel   @Omicron: impossible. how would the said encoder...   Feb 21 2013, 21:15
- - kennedyb4   Tags that would work in Rockbox would be great.   Feb 21 2013, 23:41
- - Omicron   QUOTE how would the said encoder know how good the...   Feb 22 2013, 22:01
|- - db1989   Is there something contagious going around Hydroge...   Feb 22 2013, 22:30
||- - NullC   QUOTE (db1989 @ Feb 22 2013, 13:30) Is th...   Feb 22 2013, 23:44
||- - jensend   QUOTE (NullC @ Feb 22 2013, 15:44) I will...   Feb 23 2013, 20:48
|- - jmvalin   QUOTE (Omicron @ Feb 22 2013, 16:01) I th...   Feb 23 2013, 02:29
- - darkbyte   I think a per channel bitrate setting would be use...   Mar 13 2013, 12:56
|- - jmvalin   QUOTE (darkbyte @ Mar 13 2013, 07:56) I t...   Mar 13 2013, 15:30
|- - darkbyte   QUOTE (jmvalin @ Mar 13 2013, 16:30) Actu...   Mar 13 2013, 17:19
|- - jmvalin   QUOTE (darkbyte @ Mar 13 2013, 12:19) Str...   Mar 13 2013, 21:10
- - polemon   All features I'd like to see in opus-tools, ha...   Jun 24 2013, 16:11
- - NullC   QUOTE (polemon @ Jun 24 2013, 08:11) All ...   Jun 27 2013, 11:25
- - polemon   QUOTE (NullC @ Jun 27 2013, 12:25) well, ...   Jun 28 2013, 05:55
- - NullC   QUOTE (polemon @ Jun 27 2013, 21:55) QUOT...   Jul 1 2013, 16:23
RSS Lo-Fi Version Time is now: 2nd August 2015 - 11:01
