[WASAPI] Unrecoverable playback error: Unsupported stream format: 1764
nomos
post Jan 19 2013, 01:33
Dear hydrogenaudio,
This is probably simply a case of hardware not supporting this, but when I try to play a 176400 Hz FLAC with foobar through the WASAPI 3.1 plugin, I get:
Unrecoverable playback error: Unsupported stream format: 176400 Hz / 24-bit / 2 channels
Whereas 88200, 96000 and 192000 files play fine. I'm using the FiiO E17 over optical SPDIF, WASAPI in event mode @ 24bit. Obviously the 176400 file does play through the regular audio output [the Windows resampling one].
Thank you for your time.
nomos
post Jan 20 2013, 13:27
That is most definitely the problem [or at least the best indicator of the problem] as when I uncheck other sample rates and try to play them I get the same error.
That is to say, foobar's error stems from this not being 'enabled' in the properties.
I suppose the actual question then is: Why does 88200 show up there (while not being officially supported)?
* Never mind! *
Sorry for wasting your time.
My motherboard's audio chipset: Realtek ALC892 supports 32k/44.1k/48k/88.2k/96k/192kHz which makes complete sense that this is what shows up in the properties of the output... Somehow I didn't realise these properties are hardware bound to my motherboard's SPDIF out chipset.
Closed TopicStart new topic
RSS Lo-Fi Version Time is now: 2nd April 2015 - 02:45
