High Bitrate ~320kbps MP3 vs. Lossless audio, Spoiler: mp3s were TRANSCODED from Lame free-format.
Archimago
post Jan 15 2013, 21:11
Happy New Year and greetings everyone! I know the folks here at Hydrogen audio have been around and back with regards to these tests... Nonetheless, I've been collecting data from around the audio forums since early Dec 2012.
Since early December 2012, I've opened up a survey to see if music lovers & "audiophiles" around the world can tell the difference between high bitrate ~320kbps MP3 against the original un-lossy-compressed CD audio. I'm only planning to collect data until the end of January 2013.
So far, I have >70 responses from around the world with 5 continents represented. Folks have been using everything from inexpensive (but good) headphones to megabuck separates >$50K for this. There's 2 weeks left so if you've ever been curious about participating in a blind test or just want to add to the dataset, here's your chance :-).
The "test" is relatively simple and consists of 3 musical passages encoded as "Set A" vs. the same songs "Set B"; one of which was MP3 encoded.
Come to my blog to download the music and fill out the survey:
Archimago's Musings
Thanks and have a wonderful 2013!
OOps - the title should have read 'ends Jan 31'... [fixed]
This post has been edited by db1989: Jan 15 2013, 21:16
Archimago
post Feb 3 2013, 07:57
Hang on guys, you're perhaps misinterpreting the test and jumping to conclusions...
This was TRUE LOSSLESS vs. DOUBLE MP3 (free-form LAME) encoding so I could retain the full spectrum and have the MP3 set NOT look like the standard "easy to identify" MP3 spectrum.
Of course people could look at the spectrum while testing, there's no way I can control that EXCEPT by masking it with turning off the lowpass filter, but I could not do that and have the spectrum "look right" unless I went slightly above 320kbps - hence the double pass so I could get the "error" within the 320kbps level.
Even with the double LAME compression passes, people still thought the MP3 sounded better than lossless! As the report shows, those using >$6000 gear got it even more wrong than those using <$500.
Is it because those owning >$6000 gear were older and had bad hearing? Who knows, but the point was that I wondered if MP3 was really that atrocious compared to lossless as many claim (I know you guys here generally do not believe this). Clearly even running the music through 2 psychoacoustic passes with all the horrors of smearing, and hindering the algorithm further with turning off the lowpass filter, it was undetectable and in fact more respondents PREFERRED it.
An ABX methodology with a test like this would not be practical on a large scale IMO and doomed for multiple reasons.
No, I did not register just to solicit subjects... Been reading here for years in fact, so wanted to have some input from some of the folks here whom I honestly highly respect. If you haven't seen the results I suggest having a gander.
This post has been edited by Archimago: Feb 3 2013, 08:42
Canar
post Feb 3 2013, 08:40
QUOTE (Archimago @ Feb 2 2013, 22:57) *
I cannot rationalize the existence of these two claims with respect to each other. "An ABX methodology" is the foundational concept of this forum, for heaven's sake. This is a flagrant breach of TOS8. You're showing one of the most massive disrespects possible.
2. Assume good faith.
Archimago
post Feb 3 2013, 08:54
QUOTE (Canar @ Feb 2 2013, 23:40) *
Really? I'm not criticizing or questioning the ABX methodology, am I? I think the ABC/HR idea earlier looks very interesting and maybe if I had been aware of some software that could have approached it from that angle, it would have been the way to go.
My goal was to have an easily accessible test to reach the "audiophile" crowd (as can be seen from most of the forums solicited and the test introduction) since the idea and disagreement which started it all began there. In order to get input from the cohort, the test needed to be flexible enough so some could burn to CD, others could upload to music servers, etc... Not sit around a computer to flip between A & B. Sure, a proper ABX would be significantly more reliable but looking at the equipment people used to test (remember, many of these guys use stripped down computers, insist on Amarra/JPlay/Decibel, etc.), a large proportion unfortunately would not have accepted this type of methodology.
This post has been edited by Archimago: Feb 3 2013, 08:56
C.R.Helmrich
post Feb 3 2013, 16:01
Fair enough, given that you apparently didn't know about ABC-HR and given that the "result says no difference" issue pdq first mentioned did not occur. But the bottom line is: your listeners heard a difference between A and B. Proponents of lossy (but transparent) coding can now argue, "of course they heard a difference, the MP3 encoding was badly done", while opponents might argue, "this test used some enhanced (free-format, not low-passed) 350-kbps MP3 and doesn't tell you anything about whether listeners would have preferred real-life non-tandem-coded MP3". See what I mean?
I think we all understood this perfectly. The problem is that when you have to modify a lossy encoder to hide what it's doing from your test participants, your test is flawed.
Chris
This post has been edited by C.R.Helmrich: Feb 3 2013, 16:11
Archimago
post Feb 3 2013, 17:32
QUOTE (C.R.Helmrich @ Feb 3 2013, 07:01) *
Chris
Yes, Helmrich, I do fully understand this and talked about the "unorthodox" encoding and how it could affect the audio quality in a negative way. The hope in the test was to demonstrate that lossy encoding does not deserve a "bad rap" as has been generally portrayed and I think this has been achieved when I look at the response from the audiophile crowd.
This post has been edited by Archimago: Feb 3 2013, 17:33
C.R.Helmrich
post Feb 3 2013, 20:48
QUOTE (Archimago @ Feb 3 2013, 17:32) *
Alright. Once some (positive or negative) criticism from that audiophile crowd appeared, it would be nice if you could summarize it or link to it in this thread. I'd be curious to know whether you convinced some long-term sceptics. And please, call me Chris smile.gif
Chris
Archimago
post Feb 3 2013, 23:56
QUOTE (C.R.Helmrich @ Feb 3 2013, 11:48) *
Chris
Hi Chris,
I don't know if I have time ahead to to summarize in great detail the response from audiophiles... Since this test started on AudioAsylum in the "PC Audio" subforum, it might be worthwhile following the thread there.
Nonetheless I have already received E-mail such as the little snip below...
"This test was VERY VERY educating. I write this not because I am in the
wrong-guessers camp, but because it demonstrated to me the following:
1. My very minor exposure to mp3 material had led me to assume that mp3
sounds BAD without actual listening to it in my life - less than several
dozen times and through smallish desktop speakers.
Truth is mp3 can sound very good."
He goes on to describe tests he did himself with the LAME procedure I used and his further thoughts... Great to see that this test has catalyzed some consideration on the matter.
This test was never aimed at scientific rigor (although I have tried to document and describe the procedure as best I can for full disclosure and critique); but rather allow questioning of a certain commonly held sentiment. Like the response above shows, it has at least affected some people who I suspect would never in their life sit down to try a properly controlled ABX.
This post has been edited by Archimago: Feb 4 2013, 00:03
- Archimago   High Bitrate ~320kbps MP3 vs. Lossless audio   Jan 15 2013, 21:11
- - pdq   Just out of curiosity, which forums have you been ...   Jan 15 2013, 21:31
|- - krabapple   QUOTE (pdq @ Jan 15 2013, 15:31) Just out...   Jan 16 2013, 09:02
- - Destroid   QUOTE I've opened up a survey to see if music ...   Jan 16 2013, 12:02
|- - db1989   QUOTE (Destroid @ Jan 16 2013, 11:02) 1. ...   Jan 16 2013, 13:00
- - Destroid   Ok, thanks for catching my rash assumption. So, I...   Jan 16 2013, 13:34
|- - DonP   QUOTE (Destroid @ Jan 16 2013, 07:34) My ...   Jan 16 2013, 14:50
- - Kohlrabi   Reading the test description one flaw seems to be ...   Jan 16 2013, 13:57
|- - DonP   QUOTE (Kohlrabi @ Jan 16 2013, 07:57) Som...   Jan 16 2013, 16:39
||- - Archimago   QUOTE (DonP @ Jan 16 2013, 07:39) QUOTE (...   Jan 20 2013, 01:08
|- - Archimago   QUOTE (Kohlrabi @ Jan 16 2013, 04:57) Rea...   Jan 20 2013, 01:11
- - pdq   There is a further problem. Suppose that a listene...   Jan 16 2013, 14:40
- - 2Bdecided   I'm sure there are examples of 320kbps mp3s be...   Jan 16 2013, 16:00
- - testyou   I'm going to decline your invitation Archimago...   Jan 17 2013, 04:28
|- - Archimago   QUOTE (testyou @ Jan 16 2013, 19:28) I...   Jan 20 2013, 00:57
- - Archimago   FINAL CALL! Closes next week. So far 124 resp...   Jan 25 2013, 21:10
- - Archimago   Study complete! Total respondents - 151. Fol...   Feb 1 2013, 22:39
- - C.R.Helmrich   From your blog: QUOTE This utilizes LAME's ...   Feb 2 2013, 18:07
- - greynol   Wow, I can't believe I once had this topic in ...   Feb 2 2013, 18:14
- - Kohlrabi   I (and others) did question the approach before th...   Feb 2 2013, 20:07
- - greynol   It's pretty obvious the OP registered here onl...   Feb 2 2013, 20:16
- - Archimago   Hang on guys, you're perhaps misinterpreting t...   Feb 3 2013, 07:57
|- - Canar   QUOTE (Archimago @ Feb 2 2013, 22:57) An ...   Feb 3 2013, 08:40
||- - Archimago   QUOTE (Canar @ Feb 2 2013, 23:40) QUOTE (...   Feb 3 2013, 08:54
||- - C.R.Helmrich   Fair enough, given that you apparently didn't ...   Feb 3 2013, 16:01
||- - Archimago   QUOTE (C.R.Helmrich @ Feb 3 2013, 07:01) ...   Feb 3 2013, 17:32
||- - C.R.Helmrich   QUOTE (Archimago @ Feb 3 2013, 17:32) The...   Feb 3 2013, 20:48
||- - Archimago   QUOTE (C.R.Helmrich @ Feb 3 2013, 11:48) ...   Feb 3 2013, 23:56
|- - Kohlrabi   QUOTE (Archimago @ Feb 3 2013, 07:57) Thi...   Feb 3 2013, 16:56
|- - Archimago   QUOTE (Kohlrabi @ Feb 3 2013, 07:56) QUOT...   Feb 3 2013, 17:37
- - db1989   I question whether some factor related to the spec...   Feb 3 2013, 19:05
- - Dynamic   It's always going to be tough to let people lo...   Feb 4 2013, 11:48
- - Archimago   Thanks for the eloquent response Dynamic. Would y...   Feb 5 2013, 01:38
RSS Lo-Fi Version Time is now: 27th April 2015 - 05:22
