High Bitrate ~320kbps MP3 vs. Lossless audio, Spoiler: mp3s were TRANSCODED from Lame free-format.
Archimago
post Jan 15 2013, 21:11
Happy New Year and greetings everyone! I know the folks here at Hydrogen audio have been around and back with regards to these tests... Nonetheless, I've been collecting data from around the audio forums since early Dec 2012.
Since early December 2012, I've opened up a survey to see if music lovers & "audiophiles" around the world can tell the difference between high bitrate ~320kbps MP3 against the original un-lossy-compressed CD audio. I'm only planning to collect data until the end of January 2013.
So far, I have >70 responses from around the world with 5 continents represented. Folks have been using everything from inexpensive (but good) headphones to megabuck separates >$50K for this. There's 2 weeks left so if you've ever been curious about participating in a blind test or just want to add to the dataset, here's your chance :-).
The "test" is relatively simple and consists of 3 musical passages encoded as "Set A" vs. the same songs "Set B"; one of which was MP3 encoded.
Come to my blog to download the music and fill out the survey:
Archimago's Musings
Thanks and have a wonderful 2013!
OOps - the title should have read 'ends Jan 31'... [fixed]
This post has been edited by db1989: Jan 15 2013, 21:16
Destroid
post Jan 16 2013, 12:02
Meaning no disrespect, but comparing those options are not indicative of a solution. I wonder what is the objective. To clarify:
1. To use such high bit-rates is to achieve transparency/archival.
2. Any user using either of those options is likely dealing with higher space confines.
Putting all cards on the table, I would not entrust to archive with 320kpbs MP3, nor I would put those massive MP3's on my player (i.e. LAME -V3 thru -V5 is "good enough" on my portable). Currently, I am content with AAC ~125kbps without any qualms. smile.gif
If I misunderstood that this was a listening challenge, then I apologize for my interruption. I probably could not ABX MP3 320kpbs and lossless.
db1989
post Jan 16 2013, 13:00
QUOTE (Destroid @ Jan 16 2013, 11:02) *
1. To use such high bit-rates is to achieve transparency/archival a warm and fuzzy feeling.
I hope Mooreís Law has taken us past the point where people feel a need to connect any lossy configuration to archival. IMO, the middle ground makes no sense: either choose a bitrate that (aside from in possible highly rare cases) is transparent, or use lossless. Space confines, obviously possible, but then donít waste space on 320 kbps for listening! If someone lacks the space to archive, then thatís a bit of a shame, but thereís no point in settling for anything other than lossless if one wants music in a reliable and future-proof form.
- Archimago   High Bitrate ~320kbps MP3 vs. Lossless audio   Jan 15 2013, 21:11
- - pdq   Just out of curiosity, which forums have you been ...   Jan 15 2013, 21:31
|- - krabapple   QUOTE (pdq @ Jan 15 2013, 15:31) Just out...   Jan 16 2013, 09:02
- - Destroid   QUOTE I've opened up a survey to see if music ...   Jan 16 2013, 12:02
|- - db1989   QUOTE (Destroid @ Jan 16 2013, 11:02) 1. ...   Jan 16 2013, 13:00
- - Destroid   Ok, thanks for catching my rash assumption. So, I...   Jan 16 2013, 13:34
|- - DonP   QUOTE (Destroid @ Jan 16 2013, 07:34) My ...   Jan 16 2013, 14:50
- - Kohlrabi   Reading the test description one flaw seems to be ...   Jan 16 2013, 13:57
|- - DonP   QUOTE (Kohlrabi @ Jan 16 2013, 07:57) Som...   Jan 16 2013, 16:39
||- - Archimago   QUOTE (DonP @ Jan 16 2013, 07:39) QUOTE (...   Jan 20 2013, 01:08
|- - Archimago   QUOTE (Kohlrabi @ Jan 16 2013, 04:57) Rea...   Jan 20 2013, 01:11
- - pdq   There is a further problem. Suppose that a listene...   Jan 16 2013, 14:40
- - 2Bdecided   I'm sure there are examples of 320kbps mp3s be...   Jan 16 2013, 16:00
- - testyou   I'm going to decline your invitation Archimago...   Jan 17 2013, 04:28
|- - Archimago   QUOTE (testyou @ Jan 16 2013, 19:28) I...   Jan 20 2013, 00:57
- - Archimago   FINAL CALL! Closes next week. So far 124 resp...   Jan 25 2013, 21:10
- - Archimago   Study complete! Total respondents - 151. Fol...   Feb 1 2013, 22:39
- - C.R.Helmrich   From your blog: QUOTE This utilizes LAME's ...   Feb 2 2013, 18:07
- - greynol   Wow, I can't believe I once had this topic in ...   Feb 2 2013, 18:14
- - Kohlrabi   I (and others) did question the approach before th...   Feb 2 2013, 20:07
- - greynol   It's pretty obvious the OP registered here onl...   Feb 2 2013, 20:16
- - Archimago   Hang on guys, you're perhaps misinterpreting t...   Feb 3 2013, 07:57
|- - Canar   QUOTE (Archimago @ Feb 2 2013, 22:57) An ...   Feb 3 2013, 08:40
||- - Archimago   QUOTE (Canar @ Feb 2 2013, 23:40) QUOTE (...   Feb 3 2013, 08:54
||- - C.R.Helmrich   Fair enough, given that you apparently didn't ...   Feb 3 2013, 16:01
||- - Archimago   QUOTE (C.R.Helmrich @ Feb 3 2013, 07:01) ...   Feb 3 2013, 17:32
||- - C.R.Helmrich   QUOTE (Archimago @ Feb 3 2013, 17:32) The...   Feb 3 2013, 20:48
||- - Archimago   QUOTE (C.R.Helmrich @ Feb 3 2013, 11:48) ...   Feb 3 2013, 23:56
|- - Kohlrabi   QUOTE (Archimago @ Feb 3 2013, 07:57) Thi...   Feb 3 2013, 16:56
|- - Archimago   QUOTE (Kohlrabi @ Feb 3 2013, 07:56) QUOT...   Feb 3 2013, 17:37
- - db1989   I question whether some factor related to the spec...   Feb 3 2013, 19:05
- - Dynamic   It's always going to be tough to let people lo...   Feb 4 2013, 11:48
- - Archimago   Thanks for the eloquent response Dynamic. Would y...   Feb 5 2013, 01:38
RSS Lo-Fi Version Time is now: 4th May 2015 - 18:12
