ogg parameters problem libsndfile
hub2
post Jan 15 2013, 19:34
I made a function using libsndfile that should encode RAW PCM 16-bit file to OGG Vorbis file.Function that checks format says that something is wrong with parameters but when i tried to check what's wrong in this function manually i haven't found what's wrong.Could you tell me what's wrong here.
Here's my code.
static void encodeOgg (const char *infilename, const char *outfilename, int filetype)
{    static SAMPLE buffer [BUFFER_LEN];
    SNDFILE        *infile, *outfile;
    SF_INFO        sfinfo,sf_in;
    int            readcount;
    fflush (stdout);
    sf_in.samplerate=SAMPLE_RATE;
    sf_in.channels=NUM_CHANNELS;
    sf_in.format=SF_FORMAT_RAW | SF_FORMAT_PCM_16;
    if (! (infile = sf_open (infilename, SFM_READ, &sf_in))){
        error("Could not open input file");
        exit (1);
    sfinfo.samplerate=SAMPLE_RATE;
    sfinfo.channels=NUM_CHANNELS;
    sfinfo.format = SF_FORMAT_OGG | SF_FORMAT_VORBIS;
    if (! sf_format_check (&sfinfo)){
        sf_close (infile);
        error("Invalid encoding\n");
        exit (1);
    if (! (outfile = sf_open (outfilename, SFM_WRITE, &sfinfo))){
        error("Error : could not open output file");
        exit (1);
    while ((readcount = sf_read_short (infile, buffer, BUFFER_LEN)) > 0)
        sf_write_short (outfile, buffer, readcount);
    sf_close (infile);
    sf_close (outfile);
    return;
RSS Lo-Fi Version Time is now: 5th May 2015 - 20:58
