EAC says last track’s quality=100%, but AccurateRip couldn’t verify it, [TOS #6: was “Weird AccurateRip result”]
audiomunky
post Jan 15 2013, 16:22
Hey there,
I was using my Plextor external USB drive to rip "Classical Hits" with EAC yesterday when something weird happened. The rip seemed to go fine (just like most of my rips do), but when I checked the log for AccurateRip I noticed that the last track couldn't be verified as accurate. What was strange was the track quality was 100% and test / copy CRCs matched. Another thing: if you notice, it's AR v2 and not AR v1 like the rest of the CD. Any ideas why this could have happened? Thanks in advance.
Exact Audio Copy V1.0 beta 3 from 29. August 2011
EAC extraction logfile from 14. January 2013, 23:40
Various Artists / Classical Hits
Used drive : PLEXTOR DVDR PX-708A Adapter: 1 ID: 0
Read mode : Secure
Utilize accurate stream : Yes
Defeat audio cache : Yes
Make use of C2 pointers : No
Read offset correction : 30
Overread into Lead-In and Lead-Out : Yes
Fill up missing offset samples with silence : Yes
Delete leading and trailing silent blocks : No
Null samples used in CRC calculations : Yes
Used interface : Native Win32 interface for Win NT & 2000
Gap handling : Appended to previous track
Used output format : User Defined Encoder
Selected bitrate : 224 kBit/s
Quality : High
Add ID3 tag : No
Command line compressor : C:\lame3.99.5\lame.exe
Additional command line options : -V2 --add-id3v2 --tt "%title%" --ta "%artist%" --tl "%albumtitle%" --ty "%year%" --tn "%tracknr%" --tg "%genre%" %source% %dest%
TOC of the extracted CD
Track | Start | Length | Start sector | End sector
1 | 0:00.00 | 3:27.15 | 0 | 15539
2 | 3:27.15 | 4:43.47 | 15540 | 36811
3 | 8:10.62 | 4:16.38 | 36812 | 56049
4 | 12:27.25 | 3:33.70 | 56050 | 72094
5 | 16:01.20 | 2:57.10 | 72095 | 85379
6 | 18:58.30 | 4:31.10 | 85380 | 105714
7 | 23:29.40 | 5:09.32 | 105715 | 128921
8 | 28:38.72 | 2:53.65 | 128922 | 141961
9 | 31:32.62 | 2:46.23 | 141962 | 154434
10 | 34:19.10 | 2:33.20 | 154435 | 165929
11 | 36:52.30 | 3:46.50 | 165930 | 182929
12 | 40:39.05 | 3:44.15 | 182930 | 199744
13 | 44:23.20 | 4:22.07 | 199745 | 219401
14 | 48:45.27 | 3:01.13 | 219402 | 232989
15 | 51:46.40 | 2:39.30 | 232990 | 244944
16 | 54:25.70 | 2:53.72 | 244945 | 257991
17 | 57:19.67 | 2:55.13 | 257992 | 271129
18 | 60:15.05 | 3:14.27 | 271130 | 285706
19 | 63:29.32 | 5:50.60 | 285707 | 312016
20 | 69:20.17 | 2:56.63 | 312017 | 325279
Track 1
Filename C:\Rips\Various Artists\Classical Hits\01 Pie Jesu.wav
Pre-gap length 0:00:02.00
Peak level 42.3 %
Extraction speed 4.0 X
Track quality 100.0 %
Test CRC C8A71C74
Copy CRC C8A71C74
Accurately ripped (confidence 3) [96317B69] (AR v1)
Copy OK
Track 2
Filename C:\Rips\Various Artists\Classical Hits\02 Victory.wav
Pre-gap length 0:00:01.70
Peak level 39.4 %
Extraction speed 4.6 X
Test CRC 2840931A
Copy CRC 2840931A
Accurately ripped (confidence 3) [B6BAAF6E] (AR v1)
Copy OK
Track 3
Filename C:\Rips\Various Artists\Classical Hits\03 Duel of the Fates (From Star Wars Episode 1- The Phantom Menace).wav
Pre-gap length 0:00:03.27
Peak level 99.9 %
Extraction speed 5.0 X
Test CRC 2AF4245F
Copy CRC 2AF4245F
Accurately ripped (confidence 3) [AF9DDA43] (AR v1)
Copy OK
Track 4
Filename C:\Rips\Various Artists\Classical Hits\04 Wishing You Were Somehow Here Again (From Phantom of the Opera).wav
Pre-gap length 0:00:02.45
Peak level 67.8 %
Extraction speed 5.2 X
Test CRC DB3080B8
Copy CRC DB3080B8
Accurately ripped (confidence 3) [A63DDA60] (AR v1)
Copy OK
Track 5
Filename C:\Rips\Various Artists\Classical Hits\05 Rose (From Titanic).wav
Pre-gap length 0:00:04.10
Peak level 36.9 %
Test CRC D7E04F23
Copy CRC D7E04F23
Accurately ripped (confidence 3) [7C998CEC] (AR v1)
Copy OK
Track 6
Filename C:\Rips\Various Artists\Classical Hits\06 Nella fantasia.wav
Pre-gap length 0:00:04.73
Peak level 38.2 %
Extraction speed 5.9 X
Test CRC EAD4ADCC
Copy CRC EAD4ADCC
Accurately ripped (confidence 3) [F25141CA] (AR v1)
Copy OK
Track 7
Filename C:\Rips\Various Artists\Classical Hits\07 Pavane.wav
Pre-gap length 0:00:03.68
Peak level 63.7 %
Extraction speed 5.4 X
Track quality 99.9 %
Test CRC 51E40C54
Copy CRC 51E40C54
Accurately ripped (confidence 3) [2375B3C8] (AR v1)
Copy OK
Track 8
Filename C:\Rips\Various Artists\Classical Hits\08 O mio babbino caro.wav
Pre-gap length 0:00:03.57
Peak level 100.0 %
Extraction speed 6.0 X
Test CRC 0B17DDDD
Copy CRC 0B17DDDD
Accurately ripped (confidence 3) [D3C02F6C] (AR v1)
Copy OK
Track 9
Filename C:\Rips\Various Artists\Classical Hits\09 Jesu, Joy of Man's Desiring.wav
Pre-gap length 0:00:04.40
Peak level 40.5 %
Extraction speed 4.7 X
Test CRC 527D23AC
Copy CRC 527D23AC
Accurately ripped (confidence 3) [17F43F3A] (AR v1)
Copy OK
Track 10
Filename C:\Rips\Various Artists\Classical Hits\10 'O sole mio.wav
Peak level 75.4 %
Extraction speed 6.3 X
Test CRC EB1D6643
Copy CRC EB1D6643
Accurately ripped (confidence 3) [9058872D] (AR v1)
Copy OK
Track 11
Filename C:\Rips\Various Artists\Classical Hits\11 Maria (From West Side Story Suite).wav
Pre-gap length 0:00:03.60
Peak level 98.8 %
Extraction speed 6.8 X
Test CRC FC41AE48
Copy CRC FC41AE48
Accurately ripped (confidence 3) [ECD84766] (AR v1)
Copy OK
Track 12
Filename C:\Rips\Various Artists\Classical Hits\12 The Second Waltz.wav
Pre-gap length 0:00:01.43
Peak level 77.6 %
Extraction speed 7.0 X
Test CRC 62F688A4
Copy CRC 62F688A4
Accurately ripped (confidence 3) [0F44A409] (AR v1)
Copy OK
Track 13
Filename C:\Rips\Various Artists\Classical Hits\13 Now We Are Free (From Gladiator).wav
Pre-gap length 0:00:03.20
Peak level 56.2 %
Extraction speed 7.5 X
Test CRC 15D2A292
Copy CRC 15D2A292
Accurately ripped (confidence 3) [313E1FD6] (AR v1)
Copy OK
Track 14
Filename C:\Rips\Various Artists\Classical Hits\14 The Eternal Vow (From Crouching Tiger, Hidden Dragon).wav
Peak level 60.7 %
Extraction speed 7.3 X
Test CRC C834BA62
Copy CRC C834BA62
Accurately ripped (confidence 3) [2A72ECE7] (AR v1)
Copy OK
Track 15
Filename C:\Rips\Various Artists\Classical Hits\15 O Fortuna (From Carmina Burana).wav
Pre-gap length 0:00:03.43
Peak level 100.0 %
Test CRC BD23F3A6
Copy CRC BD23F3A6
Accurately ripped (confidence 3) [DAD32CF3] (AR v1)
Copy OK
Track 16
Filename C:\Rips\Various Artists\Classical Hits\16 Main Title (From Braveheart).wav
Pre-gap length 0:00:03.48
Peak level 37.7 %
Extraction speed 5.8 X
Test CRC 66533F98
Copy CRC 66533F98
Accurately ripped (confidence 2) [1AEC0F01] (AR v1)
Copy OK
Track 17
Filename C:\Rips\Various Artists\Classical Hits\17 The Prince of Denmark's March.wav
Pre-gap length 0:00:04.42
Peak level 76.6 %
Extraction speed 7.7 X
Test CRC 0CD3AE2D
Copy CRC 0CD3AE2D
Accurately ripped (confidence 2) [7C7997B6] (AR v1)
Copy OK
Track 18
Filename C:\Rips\Various Artists\Classical Hits\18 Spring (From The Four Seasons).wav
Pre-gap length 0:00:04.00
Peak level 69.7 %
Extraction speed 7.9 X
Test CRC 3FCF24C4
Copy CRC 3FCF24C4
Accurately ripped (confidence 3) [1F2346B2] (AR v1)
Copy OK
Track 19
Filename C:\Rips\Various Artists\Classical Hits\19 Appalachia Waltz.wav
Pre-gap length 0:00:03.35
Peak level 33.6 %
Extraction speed 8.6 X
Test CRC D0721770
Copy CRC D0721770
Accurately ripped (confidence 3) [F35C6534] (AR v1)
Copy OK
Track 20
Filename C:\Rips\Various Artists\Classical Hits\20 Nessun dorma!.wav
Pre-gap length 0:00:03.50
Peak level 89.1 %
Extraction speed 9.5 X
Test CRC 112AFA6B
Copy CRC 112AFA6B
Cannot be verified as accurate (confidence 9) [22D0D879], AccurateRip returned [D69A8FDD] (AR v2)
Copy OK
19 track(s) accurately ripped
1 track(s) could not be verified as accurate
Some tracks could not be verified as accurate
No errors occurred
End of status report
==== Log checksum 8D1E082C5CB6F285850E54EAD286D73C5FA967DF1579EB79FCE62A017F279BDB ====
Replies (1 - 5)
Rollin
post Jan 15 2013, 16:50
There can be many reasons.
One possible reason: This is last track and your drive can "overread". Most of drives can't overread. So maybe your rip is even more "accurate" than results in database.
audiomunky
post Jan 15 2013, 16:52
QUOTE (Rollin @ Jan 15 2013, 10:50) *
Agreed Rollin, thanks. It's just interesting that AR tried to compare it to a different rip using AR v2 instead of AR v1...
db1989
post Jan 15 2013, 16:53
From a few days ago, posts #9 and #10.
audiomunky
post Jan 15 2013, 17:11
So you think the rip is bad then?
greynol
post Jan 15 2013, 20:20
QUOTE (audiomunky @ Jan 15 2013, 08:11) *
On the contrary, I think your rip is probably good and the hashes in the database for your specific pressing may be from errant rips that are consistent by virtue of a bug (read more below). Still, rip the tracks as lossless and let CUETools have a look at them. It may reduce the amount of blind speculation.
QUOTE (Rollin @ Jan 15 2013, 07:50) *
AR ignores the last five frames of the last track, so this shouldn't be an issue.
That said, there are situations where EAC will repeat the last 1176 samples of non-null data (where the last non-null sample is the 1176th sample of the set, regardless of whether it falls on a frame boundary) when a drive that is configured as not being able to overread and those repeated samples may fall before the final five frames of the track, affecting the AR hash. Note this may explain some (most?) of Spoon's findings which he is attributing as being "more difficult to rip". These instances have to do with a bug in EAC; they have nothing to do with the disc being "difficult to rip". To my knowledge there is no mechanism in AR to catch this problem.
Perhaps before checking a lossless version against CUETools, I'd rip the last track again with overreading disabled and see what AR says. If it says the tracks are accurate then I'd say keep the ones done with the setting enabled. Personally I'd also compare lossless versions of each to see the differences for myself and to verify my suspicion about the submissions in the AR database being consistent errors due to defective software, but that's just me.
This post has been edited by greynol: Jan 16 2013, 04:02
RSS Lo-Fi Version Time is now: 31st August 2015 - 12:02
