libfaac encoding problem, libfaac gets me weird output
hub2
post Jan 15 2013, 13:01
I'm making a C++ program that recordes audio from microphone and encodes it to MPEG4 MAIN AAC file . I made a function for encoding to AAC using libfaac and i got weird output file.I don't know what i'm doing wrong .Could you tell me what's wrong in my function.This is my RAW PCM 16-bit file File and this is output file File
Here's my code.
static void encodeAac( const char *infilename,const char *filename)
    faacEncHandle codec;
    faacEncConfigurationPtr conf;
    SAMPLE* samples;
    uint8_t*    outbuf;
    unsigned long* one;
    unsigned long* two;
    int outsize;
    one=new unsigned long;
    two = new unsigned long;
    codec=faacEncOpen(SAMPLE_RATE,NUM_CHANNELS,one,two);
    if(!codec){
        error("Something went wrong");
        return;
    conf=faacEncGetCurrentConfiguration(codec);
    conf->mpegVersion=MPEG4;
    conf->aacObjectType=MAIN;
    faacEncSetConfiguration(codec,conf);
    FILE *f = fopen(filename, "wb");
    FILE *fin=fopen(infilename,"rb");
    if (!fin) {
        error("could not open temporary file");
    if (!f) {
        error("could not open output file");
    samples = new SAMPLE[*one];
    outbuf = new uint8_t[*two];
    while(fread(samples,sizeof(SAMPLE),*one,fin)){
        outsize=faacEncEncode(codec,(int*)samples,*one,outbuf,*two);
        fwrite(outbuf,sizeof(uint8_t),outsize,f);
    while(outsize != 0){
        outsize=faacEncEncode(codec,NULL,NULL,outbuf,*two);
    fclose(f);
    fclose(fin);
    delete outbuf;
    delete samples;
    faacEncClose(codec);
nu774
post Jan 15 2013, 13:36
If your input is 16bit PCM and type of SAMPLE is int16_t or short, probably you need
conf->inputFormat = FAAC_INPUT_16BIT;
before passing conf to faacEncSetConfiguration().
Why don't you read faac and frontend source?
hub2
post Jan 15 2013, 13:43
Thanks nu774 that helped. I read pdf that was with libfaac and there in faacEncConfiguration reference wasn't anything about inputFormat . Thanks i'll read source code before asking again.
RSS Lo-Fi Version Time is now: 2nd August 2015 - 20:24
