Limitations of a synthetic tests (THD, IMD etc.)
IgorC
post Jan 13 2013, 21:50
THD is measured on one single frequency (tone) at once, IMD with two tones.
So these measurements are made with synthetic signals while music and speech aren’t just pure tones but rather complex sounds.
For example IMD is calculated on two tones 19 kHz and 20 kHz like here. http://nwavguy.blogspot.com.ar/2012/04/odac-released.html
Just one example of possible many. IMD between 20 kHz and 19 kHz tones ends with 1 kHz tone (20-19 kHz) in audible band. But at the same time there can be 20.1, 20.11 … and 19.1, 19.11… kHz tones those will also cause the same 1 kHz tone in audible band. A classic IMD measurement is calculated only for one pair of tones and not for all other. Wouldn’t be it a huge oversimplification? I’m afraid a testing of audio equipment will be very hard on a real life signals (music, speech).
This post has been edited by IgorC: Jan 13 2013, 21:55
http://listening-test.coresv.net/results.htm
saratoga
post Jan 13 2013, 22:01
QUOTE (IgorC @ Jan 13 2013, 15:50) *
Thats one way you can do it, but not the only way. RMAA for instance will do an IMD sweep. The link you posted measures THD as a function of frequency. So you can look at just a few frequencies, or you can look at lots.
Its only an oversimplification if you expect non-linearity to be strongly frequency dependent. Generally if a device is linear at a couple frequencies, its linear at all the ones in between as well, so just testing a subset of combinations gives you a very good idea of the overall performance.
IgorC
post Jan 13 2013, 22:19
QUOTE (saratoga @ Jan 13 2013, 18:01) *
Let's suppose if IMD for 19-20 kHz is the same as for 19.1-20.1 kHz. However the measurement of IMD with 4 tones 19, 19.1, 20 and 20.1 will be as twice as worse comparing to IMD with 2 tones (?).
IMD 19-20 kHz, spurious tone at 1 kHz -100 dB.
IMD 19.1-20.1 kHz, spurious tone at 1 kHz too - 100dB.
IMD with 4 mentioned tones would be twice. -97 dB (?)
Edit: math
This post has been edited by IgorC: Jan 13 2013, 22:34
greynol
post Jan 13 2013, 22:29
Have you considered the math?
Anyone having rabbit for Easter?
IgorC
post Jan 13 2013, 22:33
This post has been edited by IgorC: Jan 13 2013, 22:33
saratoga
post Jan 13 2013, 22:34
QUOTE (IgorC @ Jan 13 2013, 16:19) *
IMD with 4 mentioned tones would be twice. -94 dB (?)
Usually tests like this are done at full scale amplitude, so if you want to do 2x as many tones, each has to have half the intensity. Nonlinear terms are obviously not linear, so the IMD intensity does not necessarily scale in proportion, but probably using 4 tones will result in lower peak intensity since you will now have cross terms (eg. f1+f2-f3) that will land out of the audible spectrum.
IgorC
post Jan 13 2013, 22:58
I see, will need to read about measurements and their standards more.
Thank You for your answers.
Mach-X
post Jan 14 2013, 07:08
Unfortunately the "standards" are far too loose and allow for inferior equipment makers to make dubious claims. For example I feel that amplifier makers should be forced to run full 20-20k white noise before publishing power handling/thd levels rather than "100 watts x 6......" (but only if you run one channel at once at 1khz)
Arnold B. Kruege...
post Jan 14 2013, 14:39
QUOTE (Mach-X @ Jan 14 2013, 01:08) *
Despite all that, most audio gear with high fidelity pretensions is sonically transparent as used. It really doesn't take a lot of technology by 21st century standards to fool the ear.
Compared to electronics, speakers are major POS with orders of magnitude more distortion of just about every kind.
RSS Lo-Fi Version Time is now: 2nd April 2015 - 06:09
