Crashes unless booted in safe mode
Haro10bmx00
post Jan 12 2013, 22:29
Foobar has been working fine for months and today when I clicked on it i get a "Foobar2000 has stopped working" error. Here are the error details from that window:
Problem signature:
Problem Event Name: APPCRASH
Application Name: foobar2000.exe
Application Version: 1.2.1.0
Application Timestamp: 50f01419
Fault Module Name: KERNELBASE.dll
Fault Module Version: 6.1.7601.17651
Fault Module Timestamp: 4e211319
Exception Code: 0eedfade
Exception Offset: 0000b9bc
OS Version: 6.1.7601.2.1.0.256.1
Locale ID: 1033
Additional Information 1: d383
Additional Information 2: d38322db1fb530dab91d5490fe2c0303
Additional Information 3: 08d9
Additional Information 4: 08d924223fd0a32af2fd2f66fe98b11b
When i try to open again it gives me the option to start normally, safe mode, or troubleshoot. Both starting normally and troubleshooting result in the same error. I can boot in safe mode fine. Here is my component report:
Core (2013-01-11 13:31:06 UTC)
foobar2000 core 1.2.1
foo_albumlist.dll
foo_audioscrobbler.dll
foo_burninate.dll
foo_cdda.dll
foo_converter.dll
foo_customdb.dll
foo_dop.dll
foo_dsp_eq.dll
foo_dsp_std.dll
foo_fileops.dll
foo_freedb2.dll
foo_input_std.dll (2013-01-11 17:31:32 UTC)
Standard Input Array 1.0
foo_podcatcher.dll
foo_rgscan.dll
foo_softplaylists.dll
foo_ui_columns.dll
foo_ui_std.dll (2013-01-11 13:27:10 UTC)
Default User Interface 0.9.5
foo_uie_dragpanel.dll
foo_uie_elplaylist.dll
foo_uie_esplaylist.dll
foo_uie_panel_splitter.dll
foo_uie_vis_channel_spectrum.dll
foo_uie_wsh_panel_mod.dll
foo_unpack.dll
Not too sure what could've caused a change. Foobar and components are up to date. I don't ever get a dialog to send an error report. OS is Windows 7 64
RSS Lo-Fi Version Time is now: 8th July 2015 - 02:04
