New lossless codec comparison (Jan '13), Lots of test results, lots of graphs
ktf
post Jan 5 2013, 21:58
Hi all,
For the last few weeks I've been busy writing a new lossless audio codec comparison, after lots of talk about it here and here.
The full test report can be found here (PDF), the raw data and graphs can be found here (zip).
While the full report has lots of graphs it also has lots of text, so the 'main' graphs of the report are posted below.
The CDs used
  • 30 Seconds to Mars - This Is War (rock)
  • Confido Domino Minsk - Sacred choral music from White Russia (choral, religious)
  • Daft Punk - Alive 2007 (electronic, live)
  • Dan Brown - Angels and Demons (audiobook)
  • Enya - Amarantine (new age)
  • Fanfare Ciocarlia - Baro Biao: World Wide Wedding (world music, brass)
  • Gilberto Santa Rosa - Esencia (salsa)
  • Giuseppe Verdi - Messa da Requiem (Berliner Philharmoniker feat. conductor Claudio Abbado) (classical, romantic)
  • Howard Shore - The Hobbit: An Unexpected Journey (soundtrack, orchestral)
  • Iron Maiden - Brave New World (metal)
  • John Coltrane - Live at the half note, vol. 1 (jazz)
  • Joss Stone - Mind, Body & Soul (soul)
  • J.S. Bach - Magnificat (orchestral, baroque)
  • Koninklijke Militaire Kapel - [no name] (military brass, vinyl rip)
  • Kraftwerk - Autobahn (electronic)
  • Lana del Rey - Born to Die (pop)
  • Lil Wayne - Tha Carter III (hip hop)
  • Martin O'Donnell & Michael Salvatori - Halo: Reach O.S.T. (ambient-ish, soundtrack)
  • Michael Bublé; - meets madison square garden (pop, live)
  • Mike Oldfield - Tubular Bells (not classifiable)
  • Rosenberg Trio - Djangologists (jazz)
  • Rush - Grace under Pressure (1997 remaster) (rock)
  • System of a Down - Mezmerize (metal)
  • Szakcsi - Virágom, virágom (world music)
  • Tiësto - In Search of Sunrise 7: Asia (dance)
  • Various - Jeff Waynes Musical Version of The War of the Worlds (radio drama-ish, rock, orchestral)
  • Various - Latin Village, CD 1: Salsa (compilation of salsa)
  • Xzibit - At the Speed of Life (hip hop)
  • Yann Tiersen - Le Fabuleux Destin d'Amélie Poulain (minimalism, soundtrack)
For more information on why I chose these CDs, what strange things happened with the pure speech data (Dan Browns audiobook) and tests on 96kHz/24-bit or surround sound audio, check the full report.
Its labeled revision 1 because I intend to keep it updated. Any comment (on my grammar too, as I'm not a native speaker) is welcome.
IgorC
post Jan 6 2013, 18:41
ktf,
Thank You for sharing interesting comparison.
What decoder and/or application have You used for TAK? Last time TAK native app decodes as fast as FLAC. TAK foobar plugin was somewhat slower.
I was curious to try Monkey's Audio c3000 ('High') on Galaxy II phone with Rockbox app for Android . Got 17 hours of a battery life. And it uses the lowest frequency step so I suspect APE 'Extra High' would last comparable time. Given that an energy efficiency of proccesors grows fast it's not crazy to think about Monkey's Audio on mobile devices. Anyway I don't use lossless on portable and use FLAC lossless storage for a fast transcoding to lossy formats.
http://listening-test.coresv.net/results.htm
ktf
post Jan 6 2013, 19:16
QUOTE (IgorC @ Jan 6 2013, 18:41) *
I've used the Takc.exe command line encoder which I downloaded straight from TAK's homepage. This was run over Wine, but that shouldn't make much of a difference, as Wine only emulates system calls.
The reason that TAK decodes as fast as FLAC with you is probably because not your CPU but your harddisk is the bottleneck. In this test, CPU-time was measured and the test were done with a ramdisk to bypass the harddisk, so this might be the difference. After all, those codecs decode so fast on desktop CPU's that harddisks can't keep up.
Regarding Monkey's Audio, I've seen some devices advertising supporting it recently, so your observation is correct.
This post has been edited by ktf: Jan 6 2013, 19:17
- ktf   New lossless codec comparison (Jan '13)   Jan 5 2013, 21:58
- - IgorC   ktf, Thank You for sharing interesting comparison...   Jan 6 2013, 18:41
|- - ktf   QUOTE (IgorC @ Jan 6 2013, 18:41) What de...   Jan 6 2013, 19:16
- - ktf   I know lossless audio codec comparisons have lost ...   Jan 19 2013, 22:23
|- - urak   QUOTE (ktf @ Jan 19 2013, 21:23) but only...   Jan 20 2013, 00:29
- - knutinh   what kind of pc hardware did you use? did you use ...   Jan 19 2013, 22:30
- - Fabiolander   What a job ! Thank you but could you translat...   Jan 19 2013, 22:33
- - ktf   QUOTE (knutinh @ Jan 19 2013, 22:30) what...   Jan 19 2013, 22:41
- - romor   Is sourceforge slowly dying? This is not the first...   Jan 19 2013, 22:46
- - Gregory S. Chudov   Great job! Shameless self-promotion on my par...   Jan 20 2013, 09:21
|- - C.R.Helmrich   QUOTE (Gregory S. Chudov @ Jan 20 2013, 10...   Jan 20 2013, 12:18
- - ktf   QUOTE (romor @ Jan 19 2013, 22:46) Is sou...   Jan 20 2013, 14:31
|- - Dynamic   QUOTE (ktf @ Jan 20 2013, 13:31) So, in s...   Jan 21 2013, 11:17
|- - ktf   QUOTE (Dynamic @ Jan 21 2013, 11:17) I su...   Jan 21 2013, 14:42
- - Dynamic   I was meaning the average compression for a partic...   Jan 21 2013, 21:13
- - ktf   QUOTE (romor @ Jan 19 2013, 22:46) If I m...   Mar 19 2013, 09:44
- - ktf   Once again hi all, Today I've been busy tryin...   Mar 21 2013, 22:10
- - lvqcl   BTW, there are command-line WMAL encoder and decod...   Mar 22 2013, 15:09
- - spicymeatball77   I've got a bit of a noob question. I just Roc...   Apr 5 2013, 14:26
|- - marc2003   QUOTE (spicymeatball77 @ Apr 5 2013, 14:2...   Apr 5 2013, 18:33
|- - ChronoSphere   QUOTE (spicymeatball77 @ Apr 5 2013, 15:2...   Apr 7 2013, 14:31
|- - ChronoSphere   QUOTE (ChronoSphere @ Apr 7 2013, 15:31) ...   Jun 22 2013, 13:16
- - Dynamic   Yes, and the flac -8 point is the leftmost value o...   Apr 5 2013, 17:13
- - Propheticus   If I look at those graphs I see no point in using ...   Apr 5 2013, 18:10
- - db1989   QUOTE (Propheticus @ Apr 5 2013, 18:10) I...   Apr 5 2013, 18:34
- - Propheticus   Yes -4 is the most clear point as you said. But -5...   Apr 5 2013, 19:15
- - spicymeatball77   I transcoded my FLACs from -8 to -5 and there was ...   Apr 5 2013, 20:13
|- - Soap   QUOTE (spicymeatball77 @ Apr 5 2013, 14:1...   Apr 5 2013, 23:44
- - TBeck   I should have replied a lot earlier, because your ...   Jun 21 2013, 22:19
|- - ktf   QUOTE (TBeck @ Jun 21 2013, 23:19) I shou...   Jun 22 2013, 10:43
|- - TBeck   QUOTE (ktf @ Jun 22 2013, 11:43) As the i...   Jun 23 2013, 22:14
|- - ktf   QUOTE (TBeck @ Jun 23 2013, 23:14) Do you...   Jun 23 2013, 23:12
- - ozok   QUOTE (ktf @ Jun 22 2013, 12:43) ... Anyw...   Jun 22 2013, 10:49
|- - ktf   QUOTE (ozok @ Jun 22 2013, 11:49) What is...   Jun 22 2013, 11:07
|- - marc2003   QUOTE (ktf @ Jun 22 2013, 11:07) It's...   Jun 22 2013, 13:35
- - Wombat   I hope this time your Windows computer can run fla...   Jun 22 2013, 14:13
- - ozok   Thanks ktf.   Jun 22 2013, 15:57
- - ktf   QUOTE (marc2003 @ Jun 22 2013, 14:35) jus...   Jun 23 2013, 08:16
|- - lvqcl   QUOTE (ktf @ Jun 23 2013, 11:16) Yes, I s...   Jun 23 2013, 08:51
|- - lvqcl   QUOTE (ktf @ Jun 23 2013, 11:16) I'm ...   Jun 23 2013, 11:25
- - [JAZ]   Since common PCs do have more than one running cor...   Jun 23 2013, 10:19
- - ktf   QUOTE (lvqcl @ Jun 23 2013, 09:51) I thou...   Jun 23 2013, 14:10
- - ktf   I just finished a new revision of this codec compa...   Aug 11 2013, 11:19
- - ChronoSphere   It's interesting to see that TAK starts where ...   Aug 11 2013, 11:31
- - DARcode   Fantastic work, many thanks for your time and shar...   Aug 11 2013, 12:43
- - Propheticus   Interesting to see the 4th node of TAK (from right...   Aug 11 2013, 16:04
|- - TBeck   From TAK's Readme: QUOTE Each preset selects ...   Aug 11 2013, 17:49
- - Propheticus   The CPU used in this test might have been too fast...   Aug 11 2013, 23:47
|- - TBeck   Depending on the profile TAK is using up to 4, 12,...   Aug 12 2013, 08:25
- - Propheticus   Thats a clear explanation. The lack of difference ...   Aug 12 2013, 08:59
Closed TopicStart new topic
RSS Lo-Fi Version Time is now: 30th May 2015 - 14:32
