At long last, copy your digital collection to vinyl!
Apesbrain
post Dec 21 2012, 21:16
http://www.engadget.com/2012/12/21/3d-printed-record/
Enjoy the video!
splice
post Dec 22 2012, 03:42
The "stairstepping" of the printed groove walls is what causes the "fire siren" background sound. It's noticeable, but not as bad as you imply. The actual music distortion is due to two causes: Lack of RIAA pre-equalisation, and lack of printer resolution (the "wiggles" in the groove walls for the higher frequencies are smaller than the printer resolution.)
The point is not that the quality is poor at the moment. Printers (and thus the quality) will improve, and their costs will drop.
Regards,
Don Hills
mzil
post Dec 22 2012, 04:32
QUOTE (splice @ Dec 21 2012, 22:42) *
Considering normal records have absolutley none, I would consider it completly unlistenable, but if you deem it "not so bad", so be it.
To the needle, as it plays these impossible to properly track squares, the signal seems to be a signal which alternates between square waves to triangular waves, twice per 1.8 second rotation: square, triangle, square, triangle and then back to square. But since it largely just smashes through ignoring them, all we hear is the fire siren whine rendition. [and yes, some music too]
If that's true, then we also aren't hearing this LP played back with RIAA de-empasis either, via a phono preamp, because the music we hear does have a fairly normal bass content and is not thin and squeaky. [The "LP" play time per side would be much smaller too.]
I'm not claiming this method might not eventually be just as good if not better than conventional cutterheads and lathes as 3D printers improve (if there was any reason to continue making LPs), I'm just commenting on how terrible this version sounds, at least to my ears.
This post has been edited by mzil: Dec 22 2012, 04:50
Soap
post Dec 22 2012, 04:50
QUOTE (mzil @ Dec 21 2012, 22:32) *
Sure they do. Just at a much smaller scale. My point was that the needle doesn't care once you get past a certain point. I'm not sure 600dpi is that point, but it isn't far off.
But it isn't a series of squares and triangles to the needle. The needle is too large to "feel" the inner corner (triangle) and won't ride the flats (square) as the leading edge of the elliptical stylus is limited in its range of motion by the trailing edge is limited by the "side (and vise versa).
Creature of habit.
mzil
post Dec 25 2012, 01:33
QUOTE (Soap @ Dec 21 2012, 23:50) *
Considering normal records have absolutley none [fire truck siren noise], I would consider it completly unlistenable, but if you deem it "not so bad", so be it.
My point is that you are dead wrong; they don't have any, not at any scale, none, not even in theory. But feel free to use strawman arguments and change the subject to "but the real question is... blah-blah-blah" as much as you'd like. I don't care nor will address any such red herrings.
This post has been edited by mzil: Dec 25 2012, 01:35
- Apesbrain   At long last, copy your digital collection to vinyl!   Dec 21 2012, 21:16
- - Sunhillow   This brings the analog warmth back to digital sour...   Dec 21 2012, 21:25
|- - Arnold B. Krueger   QUOTE (Sunhillow @ Dec 21 2012, 15:25) Th...   Dec 24 2012, 14:47
- - mzil   I wouldn't advise this! The stylus isn...   Dec 21 2012, 21:53
|- - Soap   QUOTE (mzil @ Dec 21 2012, 15:53) I would...   Dec 21 2012, 22:31
|- - Glenn Gundlach   QUOTE (mzil @ Dec 21 2012, 12:53) I would...   Dec 22 2012, 10:46
|- - krabapple   QUOTE (mzil @ Dec 21 2012, 15:53) I would...   Feb 9 2013, 19:59
|- - mzil   QUOTE (krabapple @ Feb 9 2013, 14:59) I...   Feb 9 2013, 21:31
- - mzil   What matters is not the dimensions of the needle, ...   Dec 21 2012, 23:26
- - splice   The "stairstepping" of the printed groov...   Dec 22 2012, 03:42
|- - mzil   QUOTE (splice @ Dec 21 2012, 22:42) The ...   Dec 22 2012, 04:32
|- - Soap   QUOTE (mzil @ Dec 21 2012, 22:32) Conside...   Dec 22 2012, 04:50
||- - mzil   QUOTE (Soap @ Dec 21 2012, 23:50) QUOTE (...   Dec 22 2012, 05:16
|||- - Nessuno   The printing process is actually a downsampling an...   Dec 22 2012, 10:06
|||- - Soap   QUOTE (mzil @ Dec 21 2012, 23:16) QUOTE (...   Dec 22 2012, 11:47
|||- - Glenn Gundlach   QUOTE (Soap @ Dec 22 2012, 02:47) Glenn, ...   Dec 22 2012, 19:41
|||- - mzil   QUOTE (Soap @ Dec 22 2012, 06:47) QUOTE (...   Dec 24 2012, 06:36
|||- - Soap   QUOTE (mzil @ Dec 24 2012, 00:36) QUOTE (...   Dec 24 2012, 21:10
|||- - mzil   QUOTE (Soap @ Dec 24 2012, 16:10) QUOTE (...   Dec 25 2012, 00:58
|||- - Soap   QUOTE (mzil @ Dec 24 2012, 18:58) There...   Dec 25 2012, 01:14
|||- - BFG   When I first read this topic's title, I though...   Feb 9 2013, 19:09
||- - mzil   QUOTE (Soap @ Dec 21 2012, 23:50) QUOTE (...   Dec 25 2012, 01:33
||- - Soap   Again, the point is that your line: QUOTE (mzil ...   Dec 25 2012, 02:10
||- - Soap   QUOTE (mzil @ Dec 21 2012, 22:32) Conside...   Dec 25 2012, 03:47
||- - splice   QUOTE (mzil @ Dec 24 2012, 17:33) ... My ...   Dec 25 2012, 11:59
|- - splice   QUOTE (mzil @ Dec 21 2012, 19:32) QUOTE (...   Dec 23 2012, 01:33
|- - pdq   QUOTE (splice @ Dec 22 2012, 19:33) Do yo...   Dec 24 2012, 14:42
|- - splice   QUOTE (pdq @ Dec 24 2012, 05:42) QUOTE (s...   Dec 24 2012, 21:25
|- - washu   QUOTE (splice @ Dec 24 2012, 15:25) CGA d...   Dec 24 2012, 21:40
- - bryant   This is very cool! I recently had sort of the ...   Dec 23 2012, 00:05
- - lvqcl   AFAIR CGA graphics = 320x200 4 colors or 640x200 2...   Dec 24 2012, 21:33
- - splice   You're right. Memory is the second thing to go...   Dec 25 2012, 00:11
- - mccarthyk   That is amazing. I'm sure it's not too di...   Feb 9 2013, 17:58
- - splice   QUOTE (mccarthyk @ Feb 9 2013, 09:58) Tha...   Feb 10 2013, 03:02
RSS Lo-Fi Version Time is now: 28th March 2015 - 17:13
