replace electrolytic capacitors with solid state, Do i need to replace capacitors on a like for like basis?
john11
post Dec 21 2012, 06:22
Hi and thanks for reading this post.
Do you think it would be a good idea to replace the usual aluminium electrolytic capacitors on a Zero dac board for the better specs of a solid state (polymer) type capacitor.
I have a Zero dac which reproduces digital sound signals from my pc's usb port and it has 4 aluminium electrolytic's around the dac chip (47uf 35v) which are swollen and leaking and 4x 10uf 63v output coupling caps in the analog section, so 8 caps to replace in all, do you think a like for like replacement of the stock aluminium electrolytics for solid state polymer type caps would be okay in this situation.
I have done a google search and people have performed this on pc motherboards but there is not much on other types of equipment.
Many thanks in advance. John.
john11
post Dec 24 2012, 09:16
Hi. Thanks for the replies.
You are absolutely right concerning the panasonic fm series. I placed a few in a power supply last year and they were brilliant. The only problem is that they only go up to 50v.
About the panasonic fp and fk series i have found a few on mouser and farnel, in the values i need the esr is 0.18 ohms and cost 50 pence each. The nichicon rhu1h470mdn1ph is $2.50, okay a little more expensive but the esr is 0.02 ohms which is about a tenth of the panasonics. The panasonics do sound a little high in esr to me for a solid state capacitor so i am torn between the two deciding which to buy.
Talking about things to buy can anyone recomend a good desoldering iron for this job. I purchased this:
http://www.ebay.co.uk/itm/2-In-1-Welding-E...=item46019b4760
Thing is it melts the solder but the suction is very weak and it does not pick up any of the solder at all, can anyone recommend a 2-in-1 tool like this but with better suction. I don't want to spend a lot of money on a desoldering station for a one off job.
Many thanks. John.
- john11   replace electrolytic capacitors with solid state   Dec 21 2012, 06:22
- - Speedskater   I don't think that many people are familiar wi...   Dec 21 2012, 23:09
- - saratoga   The ESR won't be quite the same since the chem...   Dec 22 2012, 02:02
- - Dynamic   I'd have thought they'd be power supply sm...   Dec 22 2012, 04:26
|- - Glenn Gundlach   QUOTE (Dynamic @ Dec 21 2012, 19:26) I...   Dec 22 2012, 10:18
|- - Dynamic   QUOTE (Glenn Gundlach @ Dec 22 2012, 09:1...   Dec 22 2012, 17:03
- - Arnold B. Krueger   QUOTE Do you think it would be a good idea to repl...   Dec 22 2012, 15:49
- - john11   Hi. Thanks for the replies. You are absolutely ri...   Dec 24 2012, 09:16
|- - Glenn Gundlach   QUOTE (john11 @ Dec 24 2012, 00:16) Hi. T...   Dec 24 2012, 10:53
|- - Arnold B. Krueger   QUOTE (john11 @ Dec 24 2012, 03:16) Hi. T...   Dec 24 2012, 13:49
|- - Glenn Gundlach   Arny, try a Metcal and I ASURE you you'll have...   Dec 25 2012, 08:20
|- - Arnold B. Krueger   QUOTE (Glenn Gundlach @ Dec 25 2012, 02:2...   Dec 25 2012, 13:59
|- - Glenn Gundlach   QUOTE (Arnold B. Krueger @ Dec 25 2012, 04...   Dec 25 2012, 22:46
- - john11   Hi. Thanks for the replies. Can anyone support Gl...   Dec 25 2012, 08:37
|- - Glenn Gundlach   QUOTE (john11 @ Dec 24 2012, 23:37) Hi. T...   Dec 25 2012, 09:18
|- - Glenn Gundlach   Sorry about the extra post. How do you delete?   Dec 25 2012, 09:20
- - john11   Hi. Thanks for the replies. I saw on the amp boar...   Dec 28 2012, 04:05
- - Glenn Gundlach   QUOTE (john11 @ Dec 27 2012, 19:05) Hi. T...   Dec 28 2012, 04:24
|- - Soap   QUOTE (Glenn Gundlach @ Dec 27 2012, 22:2...   Dec 28 2012, 16:19
|- - Glenn Gundlach   QUOTE (Soap @ Dec 28 2012, 07:19) QUOTE (...   Dec 28 2012, 20:11
- - Arnold B. Krueger   QUOTE (john11 @ Dec 27 2012, 22:05) Hi. T...   Dec 28 2012, 15:05
RSS Lo-Fi Version Time is now: 4th September 2015 - 15:33
