Opus encoder with "q" setting?
radorn
post Dec 15 2012, 01:13
Well, title pretty much says it all.
Is there any such encoder or plans for it?
I was surprised opusenc doesn't have it, since vorbis had it even in the RC releases.
radorn
post Dec 16 2012, 01:03
Well, this is just user perception, but I thought the "quality" settings in modern codecs (wether it is audio or video) was an attempt to achieve a certain level of perceptual transparency where the actual bitrate is dependent on the variable complexity of the input without much constraint. Of course this results in a file where bitrate is variable, but from what I can grasp, a bitrate setting within a VBR "constraint" tries to sort of match the given bitrate as average instead of a given level of transparency, which is what I always thought vorbis did... So if you tell it to average to +/-96kbit it will depend on the complexity of the input how much perceptual quality the encoder can squeeze out of that given bitrate averaged, right?
What I always understood as a "q" setting is, in resume, a -more or less accurate- gauge of perceptual transparency, and the encoder is in charge of deciding just how much bitrate it needs to achieve it. but perhaps I was wrong...
This post has been edited by radorn: Dec 16 2012, 01:06
Garf
post Dec 18 2012, 16:59
Server Admin
Group: Admin
QUOTE (radorn @ Dec 16 2012, 01:03) *
Correct.
Not correct. Vorbis remaps the bitrate your select to a quality level that *probably* works out approximately to what you selected.
Not correct (for Vorbis and Opus). The real bitrate that your clip gets will change, not the quality.
Vorbis and Opus *can* enforce the bitrate rigidly if you so desire, but this requires extra settings (--managed in Vorbis, --cvbr or --cbr in Opus). By default they do *not* do this, and there is no guarantee you end up with the bitrate requested. But we know that, over a large collection of music, it will work out to that on *average*.
Vorbis and Opus default to quality-based encoding (instead of enforcing the bitrate) because this is generally what you want anyway.
RSS Lo-Fi Version Time is now: 6th May 2015 - 18:49
