TAudioConverter, Multithreaded Audio Converter and Extractor
ozok
post Dec 14 2012, 01:21
TAudioConverter is a audio converter and extractor. It can convert almost any audio format to aac, ac3, mp3, flac, wav, ogg, opus, mpc, tta or tak. SoX is used to apply effects such as normalization, volume change etc. It can also extract audio streams from video files and encode them. Video files with more than one audio stream is supported.
It is possible to run up to 8 simultaneous processes to shorten encoding time.
If you want an encoder to be added please let me know.
TAudioConverter uses:
-FFMpeg to extract and decode audio streams.
-FAAC
-QAAC
-Lame
-OggEnc
-FLAC
-FHGAACEnc
-Opus
-MPCEnc
-MAC
-TTAEnc
-TAKc
Screenshot
You can download it from homepage.
Both portable and setup versions are available.
Beta release downloads are available here:
Beta Release Downloads
Also you can see source code from here.
Suggestions and bug reports are more than welcome.
This post has been edited by Garf: Dec 4 2013, 17:57
Reason for edit: Screenshot removed, see TOS #13
Rollin
post Dec 21 2012, 20:56
Extracting from 3gp works, but I cannot add 3gp using drag-and-drop, only File->Add files works.
Also extracted audio from 3gp in amr format is packed into 3gp again, why not amr itself?
And FLAC stream extracted from *.mkv file is packed into *.mkv...
- ozok   TAudioConverter   Dec 14 2012, 01:21
- - pdq   Aren't you going to get into trouble with the ...   Dec 14 2012, 02:48
|- - DonP   QUOTE (pdq @ Dec 13 2012, 20:48) Aren...   Dec 14 2012, 05:12
- - Seren   "It can also extract audio streams from video...   Dec 14 2012, 09:01
- - Destroid   Yes, extraction of audio using ffmpeg.exe does not...   Dec 14 2012, 12:36
- - ozok   QUOTE (pdq @ Dec 14 2012, 03:48) Aren...   Dec 14 2012, 15:43
|- - pdq   QUOTE (ozok @ Dec 14 2012, 09:43) QUOTE (...   Dec 14 2012, 16:15
|- - Seren   QUOTE (ozok @ Dec 14 2012, 22:43) Yes it ...   Dec 14 2012, 19:02
|- - ozok   QUOTE (Seren @ Dec 14 2012, 20:02) ... Bt...   Dec 14 2012, 23:58
|- - pdq   QUOTE (ozok @ Dec 14 2012, 17:58) I reall...   Dec 15 2012, 05:25
- - ozok   LameXP provides lame.exe AFAIK. I was wondering if...   Dec 14 2012, 16:25
- - dgauze   Does this compile on linux? Doesn't look like ...   Dec 15 2012, 00:16
|- - ozok   QUOTE (dgauze @ Dec 15 2012, 01:16) Does ...   Dec 15 2012, 00:37
|- - kwanbis   QUOTE (ozok @ Dec 14 2012, 23:37) No nati...   Dec 15 2012, 01:07
|- - ozok   QUOTE (kwanbis @ Dec 15 2012, 02:07) ... ...   Dec 15 2012, 01:47
- - ozok   Update: QUOTE --0.5 -Added: Support for .wma files...   Dec 15 2012, 01:48
- - eahm   Why did you update with older versions? qaac 2.07 ...   Dec 15 2012, 08:59
- - ozok   Ogg Vorbis is with aoTuV. Yes flac.exe that comes...   Dec 15 2012, 12:28
- - nu774   Try the following: CODEflac --input-size=987654321...   Dec 15 2012, 12:42
- - ozok   I managed to encode a 2.48GB wav file to FLAC with...   Dec 15 2012, 13:49
- - Seren   QUOTE I managed to encode a 2.48GB wav file to FLA...   Dec 15 2012, 14:04
- - francesco   hi wow , i 'm going to try it now is portable?...   Dec 15 2012, 15:59
|- - ozok   QUOTE (francesco @ Dec 15 2012, 16:59) hi...   Dec 15 2012, 17:27
- - Meeko   Logged in after many months of lurking around.... ...   Dec 16 2012, 15:48
|- - ozok   QUOTE (Meeko @ Dec 16 2012, 16:48) Logged...   Dec 16 2012, 16:48
- - jkauff   Thanks to ozok for a very nice program. I'm a ...   Dec 16 2012, 16:47
- - Meeko   Tried the newer exe file....same thing happens. A...   Dec 17 2012, 00:07
- - ozok   Sorry i understood the problem wrong. Can you se...   Dec 17 2012, 15:53
- - Rollin   Should it work with .VOB files? If I try to add vo...   Dec 17 2012, 17:51
- - ozok   Yes it should work. And i can reproduce that with ...   Dec 17 2012, 17:59
- - Meeko   This is what happens if I tell the encoder to outp...   Dec 17 2012, 21:09
- - ozok   What is the output folder in that example above? D...   Dec 17 2012, 21:30
- - Meeko   Yes, that folder does exist. Taking your recommen...   Dec 17 2012, 23:36
- - Meeko   Something else to put on your to-do list: the FHG ...   Dec 17 2012, 23:40
- - ozok   That might be a qaac bug or maybe something specif...   Dec 17 2012, 23:59
- - nu774   Thanks for reporting, it's regression on qaac ...   Dec 18 2012, 01:43
|- - nu774   FYI, it was basically the problem of mp4v2: http:/...   Dec 18 2012, 02:03
- - ozok   Thanks very much nu774.   Dec 18 2012, 13:04
- - Meeko   You may want to see if others report the qaac prob...   Dec 18 2012, 15:03
- - ozok   Did updating to 2.09 solved your problem, Meeko?   Dec 18 2012, 15:08
- - ozok   Update: QUOTE --0.6 -Added: Files without an audio...   Dec 18 2012, 16:18
- - Rollin   I think that when copied audio is in AAC, it is be...   Dec 18 2012, 18:26
|- - ozok   QUOTE (Rollin @ Dec 18 2012, 19:26) I thi...   Dec 18 2012, 19:38
|- - Rollin   QUOTE (ozok @ Dec 18 2012, 22:38) About P...   Dec 19 2012, 14:30
- - Meeko   Your latest update (0.6) works fine with QAAC now....   Dec 18 2012, 21:39
- - francesco   sadly i updated to the last version and i got thi...   Dec 19 2012, 07:59
- - ozok   Do you have QuickTime or Apple Application Support...   Dec 19 2012, 09:42
|- - francesco   QUOTE (ozok @ Dec 19 2012, 03:42) Do you ...   Dec 19 2012, 12:40
- - ozok   @francesco I suggest you download QuickTime setup,...   Dec 19 2012, 16:14
- - ozok   Rollin try this one.   Dec 19 2012, 16:29
|- - Rollin   New exe correctly extracts PCM from VOB, but extra...   Dec 19 2012, 17:27
|- - ozok   QUOTE (Rollin @ Dec 19 2012, 18:27) New e...   Dec 19 2012, 18:44
|- - Rollin   Thanks! Now audio from all VOBs is extracting ...   Dec 19 2012, 19:19
- - ozok   Update: QUOTE --0.6.1 -Added: Support for 3gp file...   Dec 21 2012, 01:13
- - botface   My Android voice recorder app produces .3ga files....   Dec 21 2012, 14:18
|- - ozok   @botface Thanks for your comment. I also added su...   Dec 21 2012, 15:00
|- - botface   QUOTE (ozok @ Dec 21 2012, 14:00) @botfac...   Dec 21 2012, 20:14
- - ozok   Latest version is 0.6.1. 3ga will come with next r...   Dec 21 2012, 20:37
- - Rollin   Extracting from 3gp works, but I cannot add 3gp us...   Dec 21 2012, 20:56
|- - ozok   QUOTE (Rollin @ Dec 21 2012, 21:56) Extra...   Dec 21 2012, 21:09
- - Stop the Noise   Hi Ozok, Thanks for this great app. This is the ...   Dec 25 2012, 22:15
|- - ozok   QUOTE (Stop the Noise @ Dec 25 2012, 23:1...   Dec 26 2012, 13:43
- - Meeko   QUOTE (Stop the Noise @ Dec 25 2012, 22:1...   Dec 26 2012, 04:17
- - ozok   Update 0.6.2: QUOTE --0.6.2 -Added: Support for Mo...   Dec 26 2012, 14:42
- - Stop the Noise   Hi Ozok, Just tried the latest version and the ...   Dec 26 2012, 17:23
|- - ozok   @Stop the Noise, no it is TAC's fault date is ...   Dec 26 2012, 17:51
|- - Stop the Noise   QUOTE (ozok @ Dec 26 2012, 11:51) @Stop t...   Dec 26 2012, 18:13
- - o-l-a-v   Sweet program! How about adding "MP3 repa...   Dec 26 2012, 22:06
- - ThinkX   Like this app. Thanks for that! Have two kind...   Dec 26 2012, 22:48
|- - Stop the Noise   QUOTE (ThinkX @ Dec 26 2012, 16:48) Have ...   Dec 26 2012, 23:04
- - ozok   QUOTE (o-l-a-v @ Dec 26 2012, ...   Dec 26 2012, 23:13
|- - o-l-a-v   QUOTE (ozok @ Dec 26 2012, 23:13) QUOTE (...   Jan 2 2013, 12:36
- - goa pride   drag & drop is not working on my Windows 7 64 ...   Dec 30 2012, 15:25
|- - ozok   QUOTE (goa pride @ Dec 30 2012, 16:25) dr...   Dec 30 2012, 21:16
- - botface   I'm running 0.6.2 b459 and would like to repor...   Dec 31 2012, 17:29
|- - ozok   Thanks everyone and happy and healthy new year to ...   Jan 1 2013, 21:53
|- - botface   QUOTE (ozok @ Jan 1 2013, 20:53) Thanks e...   Jan 2 2013, 11:53
- - cyberdux   Hi ozok, Thank you so much for this program which...   Jan 1 2013, 00:38
- - jkauff   Happy New Year to ozok, who helped make my 2012 mo...   Jan 1 2013, 16:28
- - ozok   Update: QUOTE --0.7 -Added: A new GUI layout -Adde...   Jan 2 2013, 01:32
- - db1989   Notwithstanding the patent-related technicalities ...   Jan 2 2013, 19:52
- - jkauff   Ozok, you should ask the mods to update the news o...   Jan 3 2013, 13:32
- - gottkaiser   Hi ozok, this transcoding program looks very prom...   Jan 3 2013, 15:00
- - ozok   QUOTE (jkauff @ Jan 3 2013, 14:32) Ozok, ...   Jan 3 2013, 23:03
|- - gottkaiser   Thanks for the fast reply. QUOTE (ozok @ Jan...   Jan 4 2013, 01:42
|- - ozok   @gottkaiser, wow I did not know that, I most certa...   Jan 4 2013, 02:05
- - gottkaiser   Foobar2000 only has a "Bitrate" setting ...   Jan 4 2013, 02:20
- - db1989   https://mf4.xiph.org/jenkins/view/opus/job/...enc....   Jan 4 2013, 02:57
|- - gottkaiser   @db1989 Thanks for the reply   Jan 4 2013, 12:27
- - cyberdux   ozok, I am using your wonderful program every day...   Jan 4 2013, 03:05
- - ozok   Update: QUOTE --0.7.1 -Added: Setup and portable v...   Jan 5 2013, 14:03
- - jkauff   New installer works great. You'll be ready for...   Jan 5 2013, 18:08
|- - ozok   QUOTE (jkauff @ Jan 5 2013, 19:08) New in...   Jan 5 2013, 19:19
- - jkauff   ozok, I converted some tagged FLAC files to TAK, ...   Jan 7 2013, 23:36
|- - ozok   QUOTE (jkauff @ Jan 8 2013, 00:36) ozok, ...   Jan 8 2013, 17:26
|- - jkauff   QUOTE (ozok @ Jan 8 2013, 11:26) QUOTE (j...   Jan 8 2013, 19:42
- - emte   I have an issue with portable version that doesn...   Jan 8 2013, 08:31
- - ozok   I can't believe it. I have been writing ...   Jan 8 2013, 20:43
- - dreamliner77   ozok, This software looks great! Just in tim...   Jan 9 2013, 05:29
- - jkauff   QUOTE (dreamliner77 @ Jan 8 2013, 23:29) ...   Jan 9 2013, 13:52
8 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 2nd June 2015 - 12:33
