EncSpot accuracy and alternatives?
SakuraFox512
post Dec 10 2012, 18:41
From what info I scrounged up, Encspot is supposedly abandoned and somewhat inaccurate nowadays. I've also heard that there have been modified versions, but I didn't find much on names or info about them.
So my question is this: are there any newer, more accurate programs out there in the same vein as Encspot? Or am I misinformed and EncSpot is still a valid program for its purposes?
Thank you for your time, and I apologize if I put this under the wrong category.
This post has been edited by SakuraFox512: Dec 10 2012, 18:49
Replies (1 - 15)
mjb2006
post Dec 11 2012, 01:09
What is the purpose of EncSpot, anyway? Guessing at what encoder was used to encode an MP3 was never very meaningful, given all the transcodes out there. Great, this MP3 has a LAME tag, so what... What are you hoping it will tell you?
psycho
post Dec 11 2012, 07:16
Try MediaInfo.
lame -V 0
Elbart
post Jun 5 2015, 06:40
Does anybody know another program which can show the bit graph of a given MP3?
EncSpot 2.1 has that feature, but the legend of the bit graph is non-existent, and there's no graphical distinction between the frames.
Thus interpreting the graph is more guesstimation than information.
mjb2006
post Jun 5 2015, 19:29
EncSpot was based on Naoki Shibata's mp3guessenc. EncSpot stopped being maintained ages ago, but mp3guessenc has been updated many times, and since 2011 has been under the curatorship of Elio Blanca at http://mp3guessenc.sourceforge.net/
It is a command-line tool but does give you the info from which a graph could be created (see the screenshots on that Sourceforge page).
Elbart
post Jun 6 2015, 11:45
It shows the histogram, but generating a graph of each frame's bitrate ain't possible, as far as I can see.
ash92
post Jun 6 2015, 16:43
I`m not sure that I understood your question but if you want to see the bitrate of every second,you can use VLC player. You can see how the program shows bitrate 260. So... I hope I helped you.. smile.gif
mjb2006
post Jun 6 2015, 20:57
QUOTE (Elbart @ Jun 6 2015, 04:45) *
Doesn't it give you enough info to make your own graphical histogram, though?
Or are you asking for something that shows the frames on the X axis and bitrate on the Y? EncSpot doesn't even do that.
saratoga
post Jun 7 2015, 03:56
If no tool exists that will dump the raw data from a file, it'd be easy to edit the scan_layerIII function in mp3guessenc to write the individual frame information to a file, then you could do whatever you wanted with it.
Enig123
post Jun 7 2015, 04:10
QUOTE (mjb2006 @ Jun 7 2015, 04:57) *
EncSpot Pro does.
mjb2006
post Jun 7 2015, 05:56
No it doesn't. It shows a histogram where the X axis is bitrate and Y axis is percentage of frames (rounded):
If you use "copy info" it will give you, among other things, the same info in text, with X and Y swapped:
Bitrates:
32 0.0%
128 0.6%
160 ||||| 7.7%
192 |||||||||||||||||||||||||||||||||||||||| 55.3%
224 ||||||||||||||| 22.1%
256 || 3.3%
320 ||||||| 10.9%
mp3guessenc gives you the exact same info, just without the bars (see frame histogram section):
Reading `Rotary Connection - Silent Night.mp3'...
Xing tag detected into the first frame (417 bytes long).
Tag offset : 0 (0x00000000)
File size : 9469753 bytes
Number of frames : 13671
Quality : 78 (-q 2 -V 2)
TOC : 100 bytes (100 entries, 1 byte each)
Lame tag : yes
Lame tag details...
Lame short string : LAME3.90.
Tag revision : 0
Bitrate strategy : VBR method old/rh, min unknown
Lowpass value : 19000
nspsytune : yes
nssafejoint : yes
nogap continued : no
nogap continuation : no
ATH type : 4
Encoder delay (start) : 576 samples
Encoder padding (end) : 1776 samples
Encoding mode : joint stereo
Unwise settings : not used
Source frequency : 44.1 kHz
Preset : No preset.
Originally encoded : 9469753 bytes
First frame found at 417 (0x000001A1).
Detected MPEG stream version 1 layer III, details follow.
Audio stream size : 9469336 bytes (including tag: 9469753)
Length : 0:05:57.120 (357.120 seconds)
Data rate : 212.1 kbps
Blocks per frame : 4 (granules per frame 2, channels per granule 2)
Audio samples per frame : 1152
Audio frequency : 44100 Hz
Length of original audio : 15746640 samples
Min global gain : l=134 r=133
Max global gain : l=208 r=208
Flags
Error protection : no
Copyrighted : no
Original : yes
Emphasis : none
Mode extension: stereo mode frame count
Simple stereo : 12197 (89.2%)
Mid-side stereo : 1474 (10.8%)
sum : 13671
Block usage
Long block granules : 48266 (88.3%)
Switch block granules : 3482 ( 6.4%)
Short block granules : 2936 ( 5.4%)
sum : 54684
Ancillary data
Total amount : 9948 bytes (0.1%)
Bitrate : 0.2 kbps
Min packet : 57 bytes
Max packet : 579 bytes
Max reservoir : 511 bytes
Scalefactor scaling used : yes
Scalefactor select information used : yes
Padding used : no
Frame histogram
32 kbps : 1 ( 0.0%), size distr: [ 1 x 104 B]
128 kbps : 86 ( 0.6%), size distr: [ 86 x 417 B]
160 kbps : 1047 ( 7.7%), size distr: [ 1047 x 522 B]
192 kbps : 7560 (55.3%), size distr: [ 7560 x 626 B]
224 kbps : 3023 (22.1%), size distr: [ 3023 x 731 B]
256 kbps : 457 ( 3.3%), size distr: [ 457 x 835 B]
320 kbps : 1497 (11.0%), size distr: [ 1497 x1044 B]
0 header errors.
Encoder string : LAME3.90.3
Maybe this file is encoded by Lame
EncSpot also shows the distribution of simple and mid-side stereo frames, and long vs. short blocks:
Again, this info is provided by mp3guessenc, and with more accuracy.
This post has been edited by mjb2006: Jun 7 2015, 05:59
Enig123
post Jun 7 2015, 06:25
QUOTE (mjb2006 @ Jun 7 2015, 13:56) *
What I mean is EncSpot PRO, which was for sale back then.
Elbart
post Jun 7 2015, 10:14
QUOTE (mjb2006 @ Jun 7 2015, 06:56) *
No it doesn't.
EncSpot 2.1 does, 2.2 does not.
http://i.imgur.com/nAL6jxA.png
This post has been edited by Elbart: Jun 7 2015, 10:17
mjb2006
post Jun 7 2015, 21:24
I always use(d) 2.2 Pro.
It never occurred to me that 2.1 would have a unique feature!
I don't think I've seen a graph like that in any other MP3 software.
This post has been edited by mjb2006: Jun 7 2015, 21:26
AiZ
post Jun 8 2015, 08:52
Post #15
Hello,
If something like this can float your boat:
Two years ago, I borrowed ideas from this post to make my own dirty script.
It uses gnuplot, ffprobe from ffmpeg package, it is far from being user friendly and it (surely) can be full of bugs BUT it can graph any audio format ffmpeg can decode, for instance:
If you have some time to waste...
AiZ
AiZ stupid homepage - http://aiz.free.fr
Elbart
post Jun 8 2015, 16:02
Post #16
Thank you!
RSS Lo-Fi Version Time is now: 31st August 2015 - 22:49
