Can you change the Foobar default folder?
Tiger-Heli
post Dec 10 2012, 13:26
I'm kind of a long time casual FooBar 2000 User.
I'm still using FooBar2000 0.9.4.3, but I didn't see a way to do this in Foobar 1.1.8 either - but it seems like it should be simple enough.
I only use FooBar for converting files, but it's a great program.
Anyway - when I launch FB and select Add Directory, it points to G:\My Documents (I think). I want it to point to something like G:\Data\Music\Temp\New\ (and then I can drill down from there).
I tried typing that in manually, but it didn't work the next time I opened FB.
FB will typically open to the last folder I selected, but I typically move the files so that folder no longer exists.
Thanks in advance!!!
kode54
post Dec 12 2012, 07:52
Group: Admin
The presets dropped the vbr-old switch some time ago, they only still contain that switch if you haven't reset the presets to their defaults since it was changed. They currently don't specify either --vbr-new or --vbr-old, and the default in current versions is vbr-new, as far as I know.
Tiger-Heli
post Dec 12 2012, 18:58
Kode54 - Agreed - I was responding to Kohlrabi who said the best solution was to just use the presets, and I didn't word my reply correctly.
In my case, I was using an old version of Lame (probably 3.97), with a new 1.1.8 version of Foobar. In that case, the presets result in the -old switch configuration b/c you are not specifying the -new switch and -old was the previous LAME default.
I didn't mean to imply that FB2K was specifically sending the -old preset, but with that version of LAME, that is essentially what was happening.
All is good now.
This post has been edited by Tiger-Heli: Dec 12 2012, 18:59
RSS Lo-Fi Version Time is now: 29th August 2015 - 04:29
